3/4" spacers - JeepForum.com
post #1 of 4 Old 08-05-2010, 11:28 PM Thread Starter
nwco4x4
3/4" spacers
I am looking at putting 3/4" spacers on my jeep. the jeep has a 4" lift with transfer case drop. I am running 35" tires and would like just a little more room to flex. Will I have any issues with drive line vibrations?
nwco4x4 is offline
post #2 of 4 Old 08-06-2010, 04:05 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
I've done that to mine and my brother's Jeeps with no problems.Instead of a large t case drop,I did an MML and 1/2" t case drop with washers.Why not just do a 1" BL? It's a lot less work and won't cause vibes.You might want to update your profile too.
TheBoogieman is offline
post #3 of 4 Old 08-06-2010, 12:49 PM Thread Starter
nwco4x4
mostly because the spacers i found were cheaper and I'm installing the lift at the same time so there won't be any extra work to do it.
nwco4x4 is offline
post #4 of 4 Old 08-06-2010, 01:05 PM
robncar
robncar's Avatar
With a short arm lift, the higher you go, the more the ride may suffer. I'd go with the BL and MML like Boogie suggested.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
spacers , suspension , flex , tj , wrangler
Rough Country 2.5" spring & 3/4" spacers extended sway bar links? drewtj05 TJ Wrangler Technical Forum 24 11-04-2009 12:18 PM
11" wide tires; spacers or no spacers? Hilldweller JK Wrangler Technical Forum 19 07-01-2008 05:38 AM
1"-1.75" Coil Spacers w/ Existing 4" Lift - Any Considerations? DeepSky JK Wrangler Technical Forum 3 06-12-2008 01:42 PM
1/2" or 3/4" coil spacers for a full traction lift after winch install? rescue6 TJ Wrangler Technical Forum 10 08-07-2007 09:23 PM
.75" spacers on back...need to put on 2" lift coils...need a good spring compressor? Sparty TJ Wrangler Technical Forum 11 03-30-2006 09:22 PM
