3/4" Front Coil Spacer - JeepForum.com
post #1 of 10 Old 09-01-2010, 07:45 PM Thread Starter
Barker540
Just a quick question... what are the benefits to adding a set of 3/4" front coil spacers to my front end? Does it really make a big difference and is it worth my time/effort to add them? Because I am fairly new to making my own modifications... are they difficult to add?
If someone has any pictures of them or their jeeps with them in... send them my way, it would be greatly appreciated.
Barker540 is offline
post #2 of 10 Old 09-01-2010, 07:56 PM
AFjeepMan
^ equal lift front and rear.
^ 1" extra up front.
I have the RC 3.25" lift and the .75" spacers on top of the coil didn't level my jeep like I wanted so I changed the front .75" spacer out for a 1.75" spacer. Not .75" but the difference is just splitting hairs, but as you can tell it levels the jeep out nicely and makes a pretty noticeable difference.
Hope this helps.
2005 Wrangler TJ, 3 1/4" RC lift, Cragar Soft 8's 32" BFG Mud Terrains, Smittybilt SRC D-Ring bumpers, Smittybilt XRC8 winch, Body Armor Rockcrawler side guards
[_l_,[____],
l----L - OlllllllO-
(o)_) (o)_)--)_)
Wife≥Jeep>GF
Relearn your priorities.
WANTED: SYE and cv shaft...good condition and good price. for a TJ with about 5-6" of lift.
AFjeepMan is offline
post #3 of 10 Old 09-02-2010, 06:14 AM Thread Starter
Barker540
Maybe it's the camera angle at which you took the picture, but I can really tell the difference by adding a 1.75" coil spacer to the front - compared to a 3/4" spacer.
What are the advantages to having your ride leveled off? Can coil spacers be an inexpensive way to obain a little more height to the jeep? Can you add them to the rear and front to gain ride height?
Since I'm adding a 1.25" BL and 1" MML (whenever it arrives), if I added a coil spring spacer, will it affact the drive line at all? Are they still safe on the trail and road?
post #4 of 10 Old 09-02-2010, 06:20 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
its just for leveling the rake front to rear. there is no benefit other than aesthetics.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #5 of 10 Old 09-02-2010, 06:24 AM
NotURMailman
NotURMailman's Avatar
You can add spacer front and rear to gain a little height. That's exactly what budget boosts are. I personally don't like any spacers over 1", but that's just an opinion...
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #6 of 10 Old 09-02-2010, 06:38 AM Thread Starter
Barker540
Why exactly don't you like anything over 1"? Is it the look? ride quality? safety?
post #7 of 10 Old 09-02-2010, 07:13 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
I always add 3/4" more up front.RC 3.25" lift with 4" springs up front.Pretty level.
TheBoogieman is offline
post #8 of 10 Old 09-02-2010, 07:21 AM
Unlimited04
x2...
for me, its because spacers do nothing for suspension travel - its a bit technical, but....the larger they are, the more they reduce uptravel....you need some place for the spring to compress to, thats one function of the spring tower & bumpstopping...so when adding spacers, you need to add bumpstop extension to give the spring the same amount of space to compress. shock length obviously comes into play as well...but most people aren't smart enough to realize this....and some people who lift their Jeep do it just for looks, and they'll never compress the suspension enough to notice the negative effects.
spacers also do nothing for spring rate...which is usually why people add them to level rake...winch, heavy bumpers, etc...
Useful Write-Ups:
Funny:
post #9 of 10 Old 09-02-2010, 07:48 AM
MountainMan864
Yea I think I need to get a set of .75'' spacers. I just put TnT tube fenders that I had rhinolined on my jeep and now it sits down in the front even before. Im sure my springs have sagged a little too. I also have no rear bumper or armor or tire carrier.
MountainMan864 is offline
post #10 of 10 Old 09-02-2010, 04:24 PM
AFjeepMan
x2...
When done properly and taking all the "adverse" side affects into account, and adjusting the suspension for them, ie bump stops, longer shocks/BPE's, etc, they can be very beneficial and help tires that clear easily in the rear clear the front as well by giving the additional needed clearance.
And they do not limit travel if you take the shocks into account because the spring will only travel so much and you are not actually shortening the spring to limit up travel, rather just pushing the whole spring down so the path of travel is just lowered relative to the frame by the amount of spacer.
[_l_,[____],
l----L - OlllllllO-
(o)_) (o)_)--)_)
Wife≥Jeep>GF
coil , spacer
What size Coil spacer should I get? 3/4" or 1 3/4" with new coil springs? ieatchickens TJ Wrangler Technical Forum 5 01-24-2011 11:24 AM
Skyjacker " Front Coil Spacer Thunderstrike TJ Wrangler Technical Forum 7 11-20-2006 08:36 PM
Looking for a 3"coil spacer for front springs WildDuke TJ Wrangler Technical Forum 4 01-30-2006 01:52 PM
Is 2 1/2" too much for a front coil spring spacer? Falcor TJ Wrangler Technical Forum 8 08-14-2004 11:16 PM
Who makes 3/4" and 1" coil spring spacer fr and rear and best price. 97grntjsahara TJ Wrangler Technical Forum 3 06-07-2004 02:41 PM
