3' to 3.75' suspension lift - JeepForum.com
post #1 of 11 Old 07-29-2012, 02:33 AM Thread Starter
YoTeach
Does anyone know who makes a lift that is 3 to 3.75 inches
I'm currently running the rc 2.5 lift and I want more lift but dont want 4' due to chance of needing sye
YoTeach is offline
post #2 of 11 Old 07-29-2012, 03:38 AM
rda616
4" isn't some magic number for where you need a sye and dc drive shaft. Any lift that requires a case drop should have these things in place of that case drop.
rda616 is offline
post #3 of 11 Old 07-29-2012, 04:11 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Add 1" spacers up front or a 1.25" BL.
TheBoogieman is offline
post #4 of 11 Old 07-29-2012, 04:17 AM
Necko2529
Necko2529's Avatar
Doing an sye can only benefit your future mods and shouldn't be avoided.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #5 of 11 Old 07-29-2012, 10:21 AM Thread Starter
YoTeach
See I have 2.5 suspension, 1.25 body, mml and 3/4 spacers up front
YoTeach is offline
post #6 of 11 Old 07-29-2012, 12:06 PM
Marauder_Pilot
Marauder_Pilot's Avatar
Don't bother changing to all suspension. You won't gain any performance benefits, but your driveline angles will go all to hell.
"Buying a Jeep for on-road handling is like downloading porn to savor the cinematography."
-TTAC
2000 Jeep Wrangler TJ Sport-OME HD Lift, ProComp bumper, 32" BFG TA K/Os
2010 Kawasaki KLR650-Stock
2006 Ford F-250-Stock
Marauder_Pilot is offline
post #7 of 11 Old 07-29-2012, 12:11 PM
OR-TJ
I just did my SYE and new driveshaft install after a year of having a t case drop. I don't know how I went so long with out it. And like someone said earlier 4 inches isn't a magic number, with 3.75 inches you'll need the sye or you'll just be lowering the skid and not really using the lift to its full potential
OR-TJ is offline
post #8 of 11 Old 07-30-2012, 12:03 AM Thread Starter
YoTeach
True
I might just run 1" coil spacer front and back, that way it'll save me money and I can get the sye
I'm not running a transfer case bc I have a mml
YoTeach is offline
post #9 of 11 Old 07-30-2012, 04:59 AM
rda616
Originally Posted by YoTeach
True
Then you will most likely need a case drop, or sye. Highline it and leave the lift alone.
rda616 is offline
post #10 of 11 Old 07-30-2012, 01:11 PM Thread Starter
YoTeach
Another few questions I have
What size bump stops do I need to go to if I had 3/4 spacers on to my 2.5 lift? Do I need extended brake lines and longer rear sway bar links
I'll be at 3.25 of lift
YoTeach is offline
post #11 of 11 Old 07-30-2012, 01:38 PM
Necko2529
Necko2529's Avatar
If your current bump stops are working with your tires you wont need new bump stops.
