3.07 Gears - JeepForum.com
post #1 of 11 Old 08-25-2012, 03:38 PM Thread Starter
Buckeyescott5
3.07 Gears
I just bought a 2002 Wrangler and found out it has 3.07 gears. It's a 4.0 and 5 speed. I want to install 31 or 33 inch tires. Should I do it???
Buckeyescott5 is offline
post #2 of 11 Old 08-25-2012, 04:01 PM
Jeepsr4me
You will then have a 4 speed...... with 33s 31s you will be okish.. Not the best set up but the 4.0 is able to torque those tires along.
Jeepsr4me is offline
post #3 of 11 Old 08-25-2012, 04:16 PM
tjcj
Ya 33's with 3.07's sucks. You lose 5th gear.
Yakima Valley Mountaineers.
tjcj is offline
post #4 of 11 Old 08-25-2012, 05:05 PM
Border Dave
Got Sand?
Border Dave's Avatar
You won't have much of a first gear, either. From a stop it will be a dog. You'll start to really dislike driving your jeep. Don't upgrade your tires until you regear.
Border Dave is offline
post #5 of 11 Old 08-25-2012, 05:34 PM
gmiller0737
I would stick with the 31's I ran My 4.0 TJ for a while with the 3.07 & 31" Tire Combo it's not the best but will do for a while,I can't say I would want to run 33's & 3.07's,I got a sweet deal on a Rear that already has 3.73's & also got a Deal on the stuff to regear the front to 3.73 & it's a fairly decent combo I was going to go with 4.11's but the deal on the 3.73's was too good to pass up.
gmiller0737 is offline
post #6 of 11 Old 08-25-2012, 06:20 PM
Timmay82
Stay where you are until you plan it out better. Going to a bad ratio to tire size like that will make you hate that Jeep. I learned the lesson the hard way.
Timmay82 is offline
post #7 of 11 Old 08-26-2012, 07:22 AM Thread Starter
Buckeyescott5
Thanks, that's what I was afraid of.
post #8 of 11 Old 08-26-2012, 09:50 AM
SideshowBob024
3.07's with 32's was miserable. Liveable, but miserable. I didn't realize just how bad it was until I got 4.56's
SideshowBob024 is offline
post #9 of 11 Old 08-26-2012, 02:02 PM
BigFish
I've run 33x10.5's with 3.07 gears for the last 3 years. It's not that bad, 5th is only good for 60mph+ and then a downshift is required for a pass or on inclines. It's not the greatest, but for the street and mild trail riding, I'm fine w/ it.
BigFish is offline
post #10 of 11 Old 08-26-2012, 02:14 PM
LittleBluE
Obviously you've never had 4.56's.
Everyone that's only had 3.07's says that. Then they change and they won't ever go back.
LittleBluE is offline
post #11 of 11 Old 08-26-2012, 02:23 PM
EDM
I have on 03 TJ with 3:07's and a 5spd. I went with 30x9.50-15's and even with the 30's I wish it had 3:73's or 4:10's. When I bought a second set of wheels they had 31's and it was pretty weak with them on.
EDM is offline
Yukon 4.88 gears on back order, what gears would be just as good? N2SPD TJ Wrangler Technical Forum 20 02-06-2011 08:19 PM
Jk Rubicon 4:10 gears vs. 1974 Chevy 4:10 gears (pics) Xtremjeepn JK Wrangler Technical Forum 15 12-03-2009 09:09 PM
Removing side gears and spider gears... Mudbug1979 TJ Wrangler Technical Forum 2 10-08-2009 06:34 AM
Can u put spider gears dana 30 with out resetting the gears? magnum629 TJ Wrangler Technical Forum 2 02-19-2007 09:55 AM
Will a differnece be noticed from 3.07 gears and 33" tires to 3.73 gears chaznad TJ Wrangler Technical Forum 9 08-26-2005 10:54 AM
