Quantcast 3.07 gear w/ 33's - auto trans - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 3.07 gear w/ 33's - auto trans
Old 08-04-2009, 03:46 PM   #1
outlanderbz
I did a search and read many posts but I think it just made me even more confused. Hopefully you guys can help me and give me some advice on my exact situation. I am planning on moving from a stock 2002 wrangler sport 6cyl automatic trans to this setup. I am also assuming I have 3.07.....
2.25" BB + 1" BL + soft 8's 15x8 and duratrac 33x12.50x15
that being said, I know absolutely nothing about gears other then what I have read for the last 2 hours. Will I need to regear or change things out? Is it strictly a personal preference thing or can I cause damage to my Jeep?
My Jeep lives a life of driving to bike trails, hiking trails, geocaching, dirt/mud trails out at a cottage in Michigan and Wisconsin. It spends time on highways to get to those places. I am a light driver, usually dont go any faster then 70 MPH. I want to get more into wheelin.
go easy on me....and speak slowly....thanks guys!
outlanderbz is offline   Reply With Quote
Old 08-04-2009, 05:38 PM   #2
mobyjeep
33" tires and 3.07's won't hurt anything, but you will have a severe drop in performance. You will prolly want 4.56's.
mobyjeep is offline   Reply With Quote
Old 08-04-2009, 05:52 PM   #3
IslandTJ
Drink Oregon Craft Beer!
IslandTJ's Avatar
Location: where I wheel: N 45º 36.663' W 123º 20.935', Oregon
If you have the 3 speed auto, 4.10 will bring you back to a stock power band level with the 33s. This would be optimal for a DD.
1998 TJ Moss Green Sahara w/ numerous scratches & dents whose playground is on a tropical island that's 33 miles long and 4-12 miles wide, in year-round 82 degree weather.
[Edit] "Now jeepin in Oregon" [/Edit]
IslandTJ is offline   Reply With Quote
Old 08-04-2009, 07:35 PM   #4
outlanderbz
so in order to get back to 4.10, you either regear or swap out the dana 35 for a dana 44? speaking extremely simple of course, I am sure there is more to it but am I at least in the correct ballpark?
Old 08-04-2009, 08:15 PM   #5
noise_maker
noise_maker's Avatar
Even if you find a d44 w/ 4.10s you will still have to re-gear your d30 up front.
Your other option is a d30/d35 combo out of a 4 banger tj - they came with 4.10s
noise_maker is online now   Reply With Quote
Old 08-04-2009, 08:46 PM   #6
outlanderbz
ah okay, that is what I saw people talking about getting them from the 4 bangers when I searched and read on the topic. that makes sense. so, basically, if I am unhappy with the performance after I get my 33's, I just need to save and then regear.
anyone else running 33's with 3.07 automatic trans, what are your opinions?
Old 08-04-2009, 08:53 PM   #7
outlawjosywales
3.07's with 33's is definately doable. this is my rig when i first got it lifted. 3" springs,3.07's,3 speed auto,open 30/35, 33x12.5's on 15x8's. u do feel the power loss on the big stuff but you can still do it without much trouble as long as you're controlled in your driving. i have a 44,lockers & 4.56's now & the difference is huge
Go Anywhere.
outlawjosywales is offline   Reply With Quote
Old 08-04-2009, 08:56 PM   #8
Boodyrider
Mine was a dog on the 33s with 3.07. You get used to it, but it's poor acceleration and hard to climb hills in D.
I like it a lot better with 4.10s and 33s.
With an auto, arguably you also put more strain on the trans if you don't regear. 410s are about right with the 33s, 4.56 if you think you might ever go to 35s and can put up with 3000 rpm at 65. Otherwise I run about 2750 rpm with my 4.10s on 33s.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline   Reply With Quote
Old 08-04-2009, 09:20 PM   #9
outlanderbz
so when you regear, you need to regear the front and back to say 4.10? From what I have read this can cost in the $1000 - $1500 range?
Also, when you guys say you are geared up to 4.56, can you do this with the dana 30 front and dana 35 rear or does this require swapping them out for something else, say a 44?
once again, thanks for answering all my questions, these forums are great and have enjoyed learning.
Old 08-04-2009, 09:25 PM   #10
Apex
Recon death squad
Apex's Avatar
regear..or if you can do some work yourself do what I did.
Find some stock axles from a 4cyl TJ and swap them out. They come stock with 4.10 gears
EDIT: Also, if you find a D44 with 4.10 gears then I would go out and look for a stock d30 from the 4cyl and call it a done deal.
I went 4.10 with 33s/4.0/3spd auto in my 02...good combo for all around on and off road use.
If you use it mainly on the highway, 3.73 would probably be a tad better for you
SOLDSilver 02 TJ Apex Edition. "Pandora"
3.5"RE LA--35" MT/Rs--Savvy--MetalCloak--Superior--Currie--ARB--and stuff
IndyORV
Apex is online now   Reply With Quote
Old 08-04-2009, 09:32 PM   #11
Photog2000
I am running 3.07's and 32's I don't notice it too bad. My only complaint is having to ride the brakes all the time at idle. It tends to roll along a bit fast.
Photog2000 is offline   Reply With Quote
Old 08-04-2009, 09:34 PM   #12
chainsaw620
just switched my 33's and 07s to 488s 488s are a lot nicer, however I think they wll be awesome with 35s
I'm automatic also
Gear'd lock'd and ready to rock!
chainsaw620 is offline   Reply With Quote
Old 08-04-2009, 09:35 PM   #13
Apex
Recon death squad
Apex's Avatar
I'm automatic also
oh god...have you gone on the highway yet? redline at 65?
IndyORV
Old 08-04-2009, 09:47 PM   #14
RogueSpear2023
JF is my second home.
As every one else has said if you want 4.10s and this will be just about right, swap the axles in from a 4cyl, it will be far cheaper about $500 for both at most. And you can do it your garage, with limited tools, and knowledge. If you have a D44 now then get the front from a 4 cyl and regear the rear. The easiest way to tell a D35 and a D44 apart, is the D35 has a rubber fill plug and the D44 has metal one.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
TJ Tech Boot Camp
TJ Specs
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline   Reply With Quote
Old 08-04-2009, 09:49 PM   #15
outlawjosywales
i went to 4.56 to go to 35's in a little while. you can go up to 4.88's in both axles,but you will need a larger carrier. you can get a carrier off of ebay for around $40-50.
Go Anywhere.
Glock Forum
