2800 Idle problem just put power steering in - JeepForum.com
post #1 of 4 Old 01-12-2013, 09:52 AM Thread Starter
KoolAidMan888
Hey guys power steering let go just put it in went to start it to bleed system and it idles at 2900 rpm. tap the gas it goes up and stay for a second then comes back to 2900. I check the vacuum lines and cant find anything wrong.. had a code for the coolent sensor. the one that goes on the thermostat. put a new one in and it still idles at 2900. I can not FIGURE THIS >>>> out, 01 2.5 wrangler. has 167. put in a new crank sensor along with new TPS sensor. i blew all the connections out that i could see with air incase they got wet or oil in them.. i am at a loss.
Any help is appreciated.
KoolAidMan888 is offline
post #2 of 4 Old 01-12-2013, 10:29 AM Thread Starter
KoolAidMan888
just clean i IAC and this did not fix my issue either.. Wtf
post #3 of 4 Old 01-12-2013, 12:46 PM
Moezer
2015 JK Wrangler
I don't own a 2.5 nore have had any exp with one.
Try driving the jeep around for a bit tell the new sensors register with your computer or disconnect your battery for 15 mins to 30 mins then try again
Moezer is offline
post #4 of 4 Old 01-12-2013, 05:23 PM Thread Starter
KoolAidMan888
i did do that but it did not work...... found it though.. I took the intake tubes off AGAIN..... cleaned the throttle body AGAIN.. was putting it back on. and i see the two manifold bolts just sitting in there holese backed out about to fall out... tighten the hell out of them and Fixed. blahhh wana talk about annoying.
thanks for the input though
