24v electrical equipment - JeepForum.com
post #1 of 14 Old 11-12-2002, 06:39 PM Thread Starter
Bob J
Bob J's Avatar
1984
What's an easy way to run 24v lights off my Jeeps 12v electrical system?
1984 AMC Eagle
2006 TrailBlazer
Sig v.55
Bob J is offline
post #2 of 14 Old 11-12-2002, 06:52 PM
Jami
1973 CJ6
Dual Batteries. It isn't a cheap option but it would work.
73 CJ-6 in the works
Jami is offline
post #3 of 14 Old 11-12-2002, 07:33 PM
JPMan-TJ
JPMan-TJ's Avatar
Bob... check your PM's in a day or two... I have a write up from about 2 years ago that showed how u could do it without running 2 batts...
Just give me a chance to find it... I wil PM it or find you on AOL IM
JPMan-TJ
JPMan-TJ is offline
post #4 of 14 Old 11-12-2002, 07:50 PM
K9JEEP
Registered Abuser
K9JEEP's Avatar
Just plug them in direct and they'd only be half power...
Hey, I'm getting suspicious of all Military equipment questions now...! Reveal your project!!!
K9Jeep
K9JEEP is offline
post #5 of 14 Old 11-12-2002, 07:53 PM
JPMan-TJ
JPMan-TJ's Avatar
I know what it is and you don't!!! hahahahahahaha
JPMan-TJ
JPMan-TJ is offline
post #6 of 14 Old 11-12-2002, 08:08 PM
K9JEEP
Registered Abuser
K9JEEP's Avatar
Hrrmmm... Two more options here since it's hush-hush!!
DC-DC converters. Sometimes can be more expensive than a dual battery setup. Dunno what the power requirements are yet! But you can find them pretty cheap, no bigger than a pack of CD's for 500w units..
If it's not sealed beam, an option might be to exchange the bulb(s) to a 12v unit.
Throwing some options out... Dual battery would be justified if you've got a winch ready to use it.
K9Jeep
K9JEEP is offline
post #7 of 14 Old 11-12-2002, 08:21 PM
JPMan-TJ
JPMan-TJ's Avatar
Not a bad set of options K9...
BTW, where do I get tickets to the musical... and who is playing me? If your not sure yet may I make the suggestion of Sly?
JPMan-TJ
JPMan-TJ is offline
post #8 of 14 Old 11-12-2002, 08:25 PM
K9JEEP
Registered Abuser
K9JEEP's Avatar
Casting?? Dunno, nobody's failed a drug-test yet!! I do admire the Avatar!!
K9Jeep
K9JEEP is offline
post #9 of 14 Old 11-12-2002, 08:47 PM Thread Starter
Bob J
Bob J's Avatar
1984
ah you found me out!
a trailer with small winch on it.
Can I get one alternator to charge both batterys if they are a different voltage?
1984 AMC Eagle
2006 TrailBlazer
Sig v.55
Bob J is offline
post #10 of 14 Old 11-12-2002, 08:48 PM
JPMan-TJ
JPMan-TJ's Avatar
what amp is your alt?
A 117 should be ok
JPMan-TJ
JPMan-TJ is offline
post #11 of 14 Old 11-12-2002, 08:55 PM Thread Starter
Bob J
Bob J's Avatar
1984
Yeah, 117.. but I could always upgrade
1984 AMC Eagle
2006 TrailBlazer
Sig v.55
Bob J is offline
post #12 of 14 Old 11-12-2002, 09:01 PM
K9JEEP
Registered Abuser
K9JEEP's Avatar
Your not getting a 12v and a 24v battery. You'll just run 2 each 12volts.
It's the way you wire them together that determines if you have Double the voltage or double the amperage. The alternator will charge them both at the same time. The trailer taps will feed off a seperate circuit for 24volts..
I can draw this on a napkin.
K9Jeep
K9JEEP is offline
post #13 of 14 Old 11-12-2002, 09:14 PM
JPMan-TJ
JPMan-TJ's Avatar
But can you draw on a napkin riding in a train? Can you draw it on a napkin in a car? Can you draw it on a napkin in a plane?
JPMan-TJ
JPMan-TJ is offline
post #14 of 14 Old 11-13-2002, 07:46 PM
Mark K
Mark K's Avatar
LOL!!! SOMEBODY has kids!!!!!
I'm 42, kids mostly grown and gone... still can say those damn books in my sleep...
Mark K
Don't ask me! I just post what my dog [Emma] tells me to.
Member of:
Mark K is offline
24v , electrical , equipment , tj
Questions on equipment. YJfiend Wrangler General Discussion 3 09-05-2009 06:50 PM
Need lift and equipment help Tcormier106 TJ Wrangler Technical Forum 1 04-19-2009 12:18 PM
CB equipment Slickdaddydax YJ Wrangler Technical Forum 19 01-05-2008 07:39 PM
OMD HD / JKS 1.25 BL with heavy equipment? thejafe TJ Wrangler Technical Forum 1 07-27-2006 06:33 PM
stock equipment allaboutjeep YJ Wrangler Technical Forum 2 08-31-2003 06:27 PM
