241OR 2-Low Kit - JeepForum.com
 2Likes
post #1 of 39 Old 02-06-2014, 02:26 PM Thread Starter
A4LiterV8eater
241OR 2-Low Kit
http://www.teraflex.biz/tj-wrangler-...roduction.html
Does anyone have any experience with the 241OR 2-low kit? Better yet can someone make a knock-off thats not $276
A4LiterV8eater is offline
post #2 of 39 Old 02-06-2014, 02:35 PM
bnine
Wow. Cheap people suck.
bnine is offline
post #3 of 39 Old 02-06-2014, 03:06 PM Thread Starter
A4LiterV8eater
I was just joking about making a knock-off, but it appears to just be some peices cut out of plate and a very high price. I think they could still make huge profit if it were $90 and at that price they'd be flying off the shelves.
I wonder how it compares to the stock shifter. It would be awesome if a template could be made to modify the stock shifter to accomplish the same thing.
post #4 of 39 Old 02-06-2014, 06:01 PM
popeyesides
popeyesides's Avatar
Wow, you just don't understand!!
popeyesides is offline
post #5 of 39 Old 02-06-2014, 09:27 PM
JeepnBlake
You two are being ridiculous, seriously look at that thing, a shifting sector for a 231 goes for about $30 all over the place on the internet. Hell even a brand spanking new one for a 241 from Mopar is $35.
The 231 is a bit of a different story cause you get a new shift fork with it, but still for what it is you're paying quite a bit.
Notice that all the TJ 231, TJ 241, and JK 241 2 low shifters all cost the same price. So obviously it's not like this is a materials cost issue, they're obviously trying to recoup some R&D.
I personally have one, and have installed them in both the 231, and 241. They're slick little units, and they give you exactly what they say they do.
In the 241 I know my 4wd light no longer works in high range, it only works in low range, both 4 and 2 . A slight annoyance, but an annoyance none the less.
It should be noted the difference between shift patterns between the 231 and 241, 2lo and 4 lo switch spots on the two.
I'll go on to say that I would prefer to see a different shift lever inlay or shift lever all together instead of some gimmicky sticker.
If those things don't bother you though, and you are looking for 2wd low range is is probably the least expensive way to get that short of removing a driveshaft. It is plug and play, and the craftsmanship is good.
I can tell you the sector plates are fairly different if you compare TF and stock side by side, so as far as milling your own it might be a bit tough.
A4Liter has it right though, I got mine for $100 to the door, had it been higher and had I not needed to fix a cracked tcase half I would not have even bothered.
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #6 of 39 Old 02-07-2014, 09:58 AM
bnine
Its just a fun gimmick anyways and serves no practical purpose. Of course they would recoup RnD money.
Whats next, you guys think a starbucks coffee should only be 17 cents because it only cost them 11............
bnine is offline
post #7 of 39 Old 02-07-2014, 10:39 AM
bbradUSMC
YES!!!
OT: Useless kit and way over priced.
bbradUSMC is offline
post #8 of 39 Old 02-07-2014, 12:46 PM
T-Mav
I would love too have two low! How hard is it to install in a 231?
T-Mav is offline
post #9 of 39 Old 02-07-2014, 12:52 PM
Jankoid
I would snatch one up in a heartbeat for $100, but not at that ridiculous price.
Jankoid is offline
post #10 of 39 Old 02-07-2014, 12:55 PM
JeepnBlake
If you're doing a SYE at the same time it literally takes 2 minutes.
The biggest deal is you have to pop the back half of the tcase off.
-Blake-
Build Thread:
Dad's Build Thread:
post #11 of 39 Old 02-07-2014, 05:09 PM
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
I've had the ability to run in 2 low in a couple of my previous Jeeps, and I never once had the need to use it...
Necromancer_tat is offline
post #12 of 39 Old 02-07-2014, 07:24 PM
T-Mav
^ Thanks that clears a lot up for me, since you don't need it I guess I also don't need it.
T-Mav is offline
post #13 of 39 Old 02-07-2014, 10:24 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
I spend 90% of my time on the trail in 2 low and its also shift on the fly. When you need front axle drive you just bump the transfer case shift lever.
I've been using it for over 8 years and it works very well...
Knuckelhead is offline
post #14 of 39 Old 02-08-2014, 06:54 PM
Necromancer_tat
How come you want this mod?
Why do you need it and what would you use it for instead of just using 4 low?
I spend half the time in 2wd, 1/4 in 4 high, and 1/4 in 4 low. There has never been a time when I was in 4 low that I ever wished I was only running 2 low. What's the benefit achieved in 2 low that isnt achieved in 4 low?
post #15 of 39 Old 02-08-2014, 07:56 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Some of you folks need to develop a product, just one that takes more than 3 seconds to copy and then you will figure it out.
Take this one, how many times do you think they had that case in and out of the rig before they were satisfied with it being a viable product? How many prototypes did they build? How many times was the case taken apart, put back together, put in the rig and then tested? How many did they build at a cost of a couple of hundred each and send out for testing before they decided it would work?
You act like that crap is free and it doesn't need to be paid for and then after it is figured out, all the rest of the crap that it takes to get it to market doesn't cost anything either.
You ever have any plating done? Try it sometime. It's a couple of hundred for 10 parts, 1 part, or 100 parts, so to keep your cost per item down, you do the 100. What if the 100 have some flaw, who eats those?
Don't get me wrong, I'm no fan of theirs, but you folks that don't understand the value of what it takes to get something in your hands as a product are way messed up.
According to the way you value stuff, it should sell for 15 bucks because that is all the material is worth.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
