2015 Wrangler stock wheels on 2002 stock wrangler - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 2015 Wrangler stock wheels on 2002 stock wrangler
The Original 3/8" Ruffstuff Diff Cover!3" BDS Suspension Lift Kit - Jeep JK 07-11Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 08-17-2015, 04:34 PM   #1
eagle12
I know I would have to use adapters to go to 5X5 but has anyone put Bridgestone Dueler A/T tires mounted on factory 2015 Jeep Wrangler wheels under a 2002 stock Wrangler?
eagle12 is offline   Reply With Quote Quick reply to this message
Unread 08-17-2015, 05:05 PM   #2
TheBoogieman
Caught you looking!
TheBoogieman's Avatar
Yes.
If you can tolerate the Bilsteins, that will invalidate any discussion you and I may have from now on.They are quite possibly the most annoying damper I've ever used.
TheBoogieman is offline   Reply With Quote Quick reply to this message
