2006 Wrangler Unlimited Door Removal - JeepForum.com
post #1 of 5 Old 08-02-2010, 10:45 AM Thread Starter
Mikesurf
Ok so Ive seen postings for door removal all over this forum, but not for my year/make. Are the doors to the 2006 2 door unlimited easily removable? Ive tried carefully with the limited tools I have, but I am afraid of scratching the paint or the door because its so close to the bolt. Ill put more elbow grease into it if its as simple as that but wondering if there is a special tool or something I need.
Thanks!
Mikesurf is offline
post #2 of 5 Old 08-02-2010, 10:55 AM
mdm
Farm Wheeler
13mm wrench.
All TJ doors are removed the same way. Remove nuts on the bottom of the hinge pins, remove limiting strap from tub, lift door.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 5 Old 08-02-2010, 10:56 AM
DevilDogDoc
They are all the same. Take the nuts off of the bottom on the hinge and lift the door off. How hard you have to do the last part depends on how stuck they are. My 97's had never been off before I got it 2 years ago, took some moderate lifting.
An ugly Jeep with some stuff.
DevilDogDoc is offline
post #4 of 5 Old 08-02-2010, 10:57 AM
zachbh
It'll take a good amount of force upwards the first time you take the doors off. Also, they aren't that heavy, just awkward to carry.
zachbh is offline
post #5 of 5 Old 08-02-2010, 10:59 AM
ParaCAD
Love my half doors So light
A.J.
ParaCAD is offline
door , removal , removing , tj , lj , wrangler
Soft Top - 2006 Jeep Wrangler Unlimited chadwick1875 TJ Wrangler Technical Forum 16 05-23-2014 09:38 AM
Lifting a 2006 wrangler unlimited. badjamman TJ Wrangler Technical Forum 5 08-12-2009 07:32 PM
2006 Jeep Wrangler Unlimited - TIRES chadwick1875 TJ Wrangler Technical Forum 6 04-10-2009 11:54 AM
2006 Wrangler Unlimited Cracked Windshield...HELP! andijeep TJ Wrangler Technical Forum 21 01-05-2009 09:55 AM
2006 Wrangler Unlimited Tonneau Cover johnnyz3333 TJ Wrangler Technical Forum 17 06-08-2008 09:59 PM
