2006 Unlimited rebuild - Page 69 - JeepForum.com
post #1021 of 1398 Old 06-29-2013, 08:38 PM
G Beasley
Not with my MTZs. BFG ATs on the other hand suck *** at that pressure.
Nope.
Alright then , I was afraid we were seeing a pattern !
G Beasley is offline
post #1022 of 1398 Old 06-29-2013, 08:50 PM
G Beasley
Found this in some random searching and I had to post it in your thread after you didnt buy used tires from Galloways ... They are after you
post #1023 of 1398 Old 06-29-2013, 08:55 PM Thread Starter
Jankoid
Ummmm... Okay?
Jankoid is offline
post #1024 of 1398 Old 06-30-2013, 10:10 AM Thread Starter
Jankoid
Picked up the tires and u joints this morning. Very happy with my purchase. Here is the deal though. The Super Joints still have chromo inner axle shafts attached to them. I had to pay more for the joints because the guy didn't want to separate, but I still got a great deal anyway and can sell the chromos for ~$100-150 if I want (only paid $200 for the joints and shafts). The chromos are for a F150 hp44. Im currently building a F250 hp44 though, and for some stupid reason they have slightly different axle shaft lengths. As I ranted about a couple pages back, I still need a driver side inner chromo for my f250 housing. The f150 driver side inner that I bought with the u joints is exactly 0.29" longer than the f250 shaft. That is completely stupid. They are from similar year model vehicles, why not have interchangeable parts? What I need to know is if that .29" is enough to make a difference. I'm hoping there is enough leeway in the carrier to allow the slightly longer shaft. That would keep me from having to spend $100 on a new chromo. Anyone have a definitive answer for me? If not Im gonna post a thread about it.
The passenger side f150 shaft is well over an inch shorter than the f250 shaft, so I know that one is of no use to me. Even a cheapo USA Standard passenger inner shaft is $150 new for a f150, so even selling it alone I should be able to grab $75 or so (pretty sure these shafts are Alloy USA).
Jankoid is offline
post #1025 of 1398 Old 07-02-2013, 08:19 AM Thread Starter
Jankoid
Synergy Suspension track bar mount and control arm mounts came in yesterday. Very nice stuff.
Jankoid is offline
post #1026 of 1398 Old 07-02-2013, 08:34 AM
NotURMailman
For the 1/4" longer shaft it is easy enough to cut it off with a grinder and cut off wheel and re-bevel it with s grinder and flap wheel. There should be plenty of splines. For the 1" longer one, not so much.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #1027 of 1398 Old 07-02-2013, 09:14 AM Thread Starter
Jankoid
I'm more worried about the seal surface lining up. I'll need to check that first. I don't want to just start grinding on it and find out I ruined a perfectly good shaft.
Jankoid is offline
post #1028 of 1398 Old 07-02-2013, 12:14 PM
NotURMailman
I really don't think you'll have any issue with 1/4". My Superior shafts were 1/4" too long and bottomed out on my E-Locker cross pin. Hacked off 1/4", re-bevelled, installed and moved on. The front shafts are going to move in and out on whier own when you turn, and the seal surface is usually far enough out and large enough to allow for that. But, it would be easy enough for you to measure and be sure.
Just trying to save you some cash toward the RockMonsters...
post #1029 of 1398 Old 07-03-2013, 12:44 PM Thread Starter
Jankoid
Trying to decide between MetalCloak Duroflex joints and Barnes 4wd Enduro joints for my front 3 link. I have a couple of Enduro joints on my TJ, they are high quality. I need 5 joints for the front. Right now I can get the enduro joints for $204 plus shipping, while the duroflex are $295 plus shipping.
Advantages for enduro joints:
Chromoly housing
5/8" bolt
Cheaper to rebuild ($6)
Advantages for duroflex joints:
Better ride quality?
The better ride quality of the duroflex would be nice, but I'm not sure they are worth $90 more. That $90 would cover the rest of the parts I need for the 3 link.
Any thoughts?
Jankoid is offline
post #1030 of 1398 Old 07-03-2013, 12:46 PM
NotURMailman
I wouldn't worry about the joints as related to ride quality. As long as you don't have worn out joints with excessive play you won't notice a defference.
post #1031 of 1398 Old 07-03-2013, 12:56 PM
clintrivera
Do you have experience with both joints? My Duroflex joints ride nicer than my old RE joints and I know Imped has said the same.
clintrivera is offline
post #1032 of 1398 Old 07-03-2013, 01:13 PM
mcannon111
Chris may ran those enduro Barnes joints on his race truck and never had one slop out on him. And he beat the snot out of them. I'd so go barnes
no doors, no top, no problems
live in sc? join OffroadSC.com
mcannon111 is offline
post #1033 of 1398 Old 07-03-2013, 01:16 PM Thread Starter
Jankoid
Personally, I'm less concerned about ride quality than durability. I really like the fact that the Enduro joints have a larger bolt size and are chromolly instead of forged steel like the Duroflex. Will I ever damage a duroflex joint? Probably not, but I do know that I may end up turning this Jeep into a race rig several years from now, so I want to use the strongest parts possible instead of replacing parts later on. Plus, Barnes has been testing their joints for over a year now without failure on buggys that have been able to damage johnny joints before. Even ignoring cost I'm really leaning more towards the enduro joints. Strength outweighs ride quality in my book.
Jankoid is offline
post #1034 of 1398 Old 07-03-2013, 01:16 PM
NotURMailman
I'm not sure if your gaol for today is running around contradicting all of my posts, or running around pimpimg duroflex joints...
Let me fix my statement for you:
In my opinion I wouldn't worry about the joints as related to ride quality. As long as you don't have worn out joints with excessive play I feel that you won't notice a defference.
Jake,
If you want my opinion and reasoning behind it, give me a call. I'm not going to clog your thread up with the same old argument.
post #1035 of 1398 Old 07-03-2013, 01:17 PM
NotURMailman
I think you just answered your own question.
Have you considered the billet Johnny Joints?
nc guys
What would you say about the 2006 Unlimited tylertj TJ Wrangler Technical Forum 56 02-21-2010 03:58 PM
2006 Unlimited ZIMM18 Wrangler General Discussion 9 08-12-2009 09:26 AM
2006 Rubicon Unlimited Totalled -- Highline Rebuild MountZionOffroa TJ Wrangler Technical Forum 6 12-21-2008 04:22 PM
2006 unlimited rider251 TJ Wrangler Technical Forum 38 08-29-2007 10:08 AM
2006 Unlimited TJ csidoug TJ Wrangler Technical Forum 3 01-31-2006 04:25 PM
