2006 Unlimited rebuild - Page 38 - JeepForum.com
post #556 of 1398 Old 09-21-2011, 11:52 AM Thread Starter
Jankoid
Originally Posted by unlrubicon05
It could warp your frame slightly. If your happy with it, you should think about drilling through and fastening it on the other side of the frame with a longer bolt to distribute the load. That along with having a sleeves on the bolts inside the frame.
One of the bolts on each side has a crush sleeve. I can't go all the way through the frame with the other bolt because it would interfere with the upper control arm. When I weld it I will put a gusset on the frame rail that will take the place of the 3rd bolt that is supposed to be up up above where I have the 2 bolts now. I would think that would be stronger than mounting it the way Currie says. But like I said, I don't want to do any welding until I know for sure it wont be moving.
Jankoid is offline
post #557 of 1398 Old 09-21-2011, 04:51 PM Thread Starter
Jankoid
Most of the front axle is done, and most of the way mounted. Hopefully I will finish everything up tomorrow. Saturday is the deadline, so I have 2 days left.
Thought this was a pretty funny pic of installing the passenger side johnny joint:
Once I finish installing everything I plan on doing an in depth write-up on the Clayton kits in a new thread.
Jankoid is offline
post #558 of 1398 Old 09-24-2011, 09:48 AM Thread Starter
Jankoid
Done.
Jankoid is offline
post #559 of 1398 Old 09-25-2011, 09:51 PM
Sgt_Utz
Hahahahahahahahahahahahahaha you're hilarious
It wasn't my fault it was in reverse
No matter what... If I'm going to start it and release the clutch I always wiggle the stick to ensure it's in neutral... Might want to get into this habit too... Strictly safety habit...
Sgt_Utz is offline
post #560 of 1398 Old 09-26-2011, 05:47 AM Thread Starter
Jankoid
Ive had that habit for a long time actually. I was a total newb with a straight drive back then.
Jankoid is offline
post #561 of 1398 Old 10-05-2011, 10:34 AM Thread Starter
Jankoid
I got kind of lazy with the build thread since finishing my suspension. I took it to URE last weekend to test it out, and tomorrow I'm headed to Coal Creek (Windrock) in Tennessee to REALLY test it out. After I get back I will go in to more detail about the suspension and my thoughts about it's performance.
I was trail leader at URE, so I don't have very many pics of my own Jeep. Here are the few I have, as well as a good zoomed in shot of my suspension as I was coming up a steep ledge. None of them really show off the new suspension, though the last picture shows the lack of control arms/shocks hanging below the axle tube.
Jankoid is offline
post #562 of 1398 Old 10-05-2011, 02:27 PM
MCDavis
Jeep looks good, bud!
We were at SCC Sunday for a soccer game. Nice looking school!
MCDavis is offline
post #563 of 1398 Old 10-05-2011, 04:05 PM Thread Starter
Jankoid
Thanks, and you should have told me you were at SCC! I live like 2 miles from there!
Jankoid is offline
post #564 of 1398 Old 10-06-2011, 08:01 AM
MCDavis
I thought we were playing in Kannapolis until right before we left for some reason, so I wasn't thinking about being in your town. If we go back in the spring, I'll give you a heads up. I'd like to see your Jeep in person if I get the chance!
MCDavis is offline
post #565 of 1398 Old 10-06-2011, 07:48 PM
G Beasley
Your rig has come a long ways , wish I could have made one of the trips this year . I still havent made it to Uwharrie this season , but at least I have the back yard for fun .
G Beasley is offline
post #566 of 1398 Old 10-09-2011, 04:45 PM Thread Starter
Jankoid
Just got back from a 3 day wheeling trip at Coal Creek OHV. I had a blast and the new suspension performed excellently. There are a few minor things I need to tweak, but overall I am very pleased with the result. I got some good pictures for TJ of the month too. Here are a few teasers:
Jankoid is offline
post #567 of 1398 Old 10-16-2011, 09:53 PM
Crawler_Offroad
I thought this joint on the Currie front track bar was supposed to be offset?
Your LJ kicked *** this past weekend at Coal Creek! That setup is working well.
If you are having problems with that track bar you can swap it out. Let me know what you want to do.
Crawler_Offroad is offline
post #568 of 1398 Old 10-16-2011, 10:15 PM Thread Starter
Jankoid
Thanks!
The track bar works fine with the stock diff cover, but it is close. If I had ordered the Riddler cover from you like I had originally planned I doubt it would clear. Its not the track bars fault though. Because of the Clayton axle brackets I had to adjust my Currie lowers as short as they can go. The arms still need to go a bit shorter to get the pinion angle perfect and to get more clearance for the track bar, but it works the way it is now. Oh well. Looks like I'm getting a Warn diff cover instead.
Sent from my Droid
Jankoid is offline
post #569 of 1398 Old 10-16-2011, 10:57 PM
Crawler_Offroad
You could always get the riddler and grind it down where it would hit. The cover is plenty thick enough to shave it some.
post #570 of 1398 Old 10-17-2011, 12:27 AM
Xtremegameroom
Just read through all 38 pages... There went 3 hours.. Haha. Really good read. Amazing build.
Props to you and your pops it looks great.
I'm hoping to get metal cloaks in the next year after I finish up other things on my to-do list that are more important first.
Subscribed
Xtremegameroom is offline
nc guys
What would you say about the 2006 Unlimited tylertj TJ Wrangler Technical Forum 56 02-21-2010 03:58 PM
2006 Unlimited ZIMM18 Wrangler General Discussion 9 08-12-2009 09:26 AM
2006 Rubicon Unlimited Totalled -- Highline Rebuild MountZionOffroa TJ Wrangler Technical Forum 6 12-21-2008 04:22 PM
2006 unlimited rider251 TJ Wrangler Technical Forum 38 08-29-2007 10:08 AM
2006 Unlimited TJ csidoug TJ Wrangler Technical Forum 3 01-31-2006 04:25 PM
