2006 TJ clunking noise when turning - JeepForum.com
post #1 of 5 Old 07-14-2010, 07:34 PM Thread Starter
ktmdoc
I think i have narrowed the noise to the lower control arm bushings but when I went to the parts store I discovered that they could only get the replacement arms and not the bushings. They said to contact Jeep to see if the 2006 had replaceable bushings or did I have to buy factory sealed replacements. Thanks
ktmdoc is offline
post #2 of 5 Old 03-28-2011, 06:14 PM
KaptinNemo
Check Quadratec.com you will be able to buy bushings, better than OEM, but I dont know if you can buy them individualy.
KaptinNemo is offline
post #3 of 5 Old 12-22-2013, 01:43 PM
bbottabing
@ktmdoc was that the problem? I'm really going to revive an old thread but what was the noise like?
bbottabing is offline
post #4 of 5 Old 12-22-2013, 02:18 PM
JPNinPA
Check your sway bar connectors.
Alsohttp://www.moog-suspension-parts.com...s.asp?cat=3060
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #5 of 5 Old 12-22-2013, 02:58 PM
Haoleb
I used to have all sorts of clunking sounds on my tj, I ended up replacing all of the control arms upper and lower along with the track bars front and rear. No more noises now! I purchased all of the parts from amazon, pretty much replaced the entire suspension except the coil springs but the jeep had about 115k on it when I did the work and I think it was definitely due.
Haoleb is offline
tj , wrangler , noise , clunking , knocking , turning , control arm , bushing
clunking noise from the rear when turning right Squeeky TJ Wrangler Technical Forum 9 03-28-2011 06:16 PM
loud clunking noise when turning sharp right kmoore24 TJ Wrangler Technical Forum 9 10-10-2009 11:56 PM
clunking noise when turning...what is it? yoda13 TJ Wrangler Technical Forum 4 08-11-2008 07:30 AM
clunking noise below feet while turning and bumps elkriverjeep TJ Wrangler Technical Forum 3 06-27-2002 12:21 PM
clunking noise below feet while turning and bumps elkriverjeep TJ Wrangler Technical Forum 1 05-26-2002 12:29 PM
