2006 TJ 2.4l won't start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 2006 TJ 2.4l won't start
2007-2014 Jeep Wrangler Black (Paint to Match) Grille2007-2014 Jeep Wrangler Black Sun Shade (Rugged Ridge)Advance Adapters SYE Kits
Unread 05-20-2014, 06:58 AM   #1
JockHiltz
TJ Wrangler
I started my TJ and backed out if the garage this morning, turned it off to lock the garage door, went to start it again and it just went 'click click click click' really fast... Like when the battery is dead but much faster. The gauge needles also bounced around a bit.
Any thoughts?
JockHiltz is offline   Reply With Quote
Unread 05-20-2014, 07:09 AM   #2
JeepCares
You've checked the battery, terminals and connections?
Lee
U.S. Top Care
Chrysler Group LLC
JeepCares is offline   Reply With Quote
Unread 05-20-2014, 07:12 AM   #3
JBTJ
JEEPer For Life
JBTJ's Avatar
I'd remove the battery cables, clean them both up really well along with the posts on the battery and reinstall. Be sure they are on there good and tight. Lets see if that helps first.
JBTJ is offline   Reply With Quote
Unread 05-20-2014, 08:49 AM   #4
JockHiltz
TJ Wrangler
Great thanks! I didn't have chance to even look at it, it was raining and I was late for work, had to grab my wife's jeep and take off.
Thanks again, I'll post update tonight
Unread 05-21-2014, 08:36 AM   #5
JockHiltz
TJ Wrangler
Turned out the battery called it quits, thanks for the help
