2006 Rubicon Unlimited Crank No Start - JeepForum.com
post #1 of 10 Old 04-09-2011, 05:07 PM Thread Starter
smoghog4
HI guys,
Wife was driving, vehicle stalled. Brought it home intermittent spark and injector pulse. Changed the crank sensor. Same Thing. Tested the signal on Crank and Cam Sensor with lab scope. Good clean signals. I have intermittent spark and injector pulse. Thinking I have a Bad PCM, anyone run into this problem before? ( 50,000 miles on the engine 4.0l Manual trans Rubicon Unlimited ). Any help would be appreciated.
thanks in advance.
smoghog4 is offline
post #2 of 10 Old 04-09-2011, 05:20 PM
DerekXJ
Maybe a potential bad coil pack?
I always tend to start with the cheap stuff.....I would have guessed the two things you checked first also though.....Curious to see how this one turns out..
DerekXJ is offline
post #3 of 10 Old 04-09-2011, 06:54 PM Thread Starter
smoghog4
took the coil pack off my cherokee just to make sure. No Dice. I am going to borrow a buddies scanner as mine is not updated. Hopefully I can command the coils to spark and see if the PCM is good.
smoghog4 is offline
post #4 of 10 Old 04-09-2011, 09:47 PM
jondotcom
Does it have the security light illuminated on the dash (sentry)? Could be that... if yours has it I'd try another coded key first.
It will take time to restore chaos- GW Bush
jondotcom is offline
post #5 of 10 Old 04-09-2011, 10:06 PM Thread Starter
smoghog4
I tried my key just to be sure. The key or security light goes off. What happens is the engine will crank and I will get 1 spark for every 5 or six seconds out of each coil pack, when this happens it also pulses the injector once. It almost seems like it cant sync the crank and cam sensor and does not know when to fire the ignition/injectors. I initially thought it would be a bad crank sensor so I changed it. Thought I would post here in case someone else had a similar problem before.
smoghog4 is offline
post #6 of 10 Old 04-09-2011, 10:45 PM
Redz72
Redz72's Avatar
Did you check for any codes?
BLACK JEEP SOCIETY #218
Redz72 is offline
post #7 of 10 Old 04-10-2011, 09:49 AM
jkp
Check the OPDA gear:
http://www.jeepforum.com/forum/f9/20...ilure-1144202/
'92 Islander
'06 Rubicon
jkp is offline
post #8 of 10 Old 04-10-2011, 10:07 PM Thread Starter
smoghog4
There was a noise that sounded like a belt noise a couple days prior. I am the second owner. Would the dealership warranty this with 49k original miles. If not is there a permanent fix. This problem makes sense for my symptoms, hopefully my cam is not wiped out. Will an earlier dist ( like the one in my 2001 cherokee send the same type of signal? )
Thanks for the info.
smoghog4 is offline
post #9 of 10 Old 04-11-2011, 04:31 AM
jkp
You can try to see if the dealer/Jeep will help you out with part of it. Most likely not since you are out of warranty and not the original owner.
Only the OPDA/Cam Sensor from a '05 - '06 will work. They were backordered recently.
'92 Islander
'06 Rubicon
jkp is offline
post #10 of 10 Old 04-11-2011, 07:15 PM Thread Starter
smoghog4
I would like to thank all of you that offered me help Mystery solved. See my posts in the following link
http://www.jeepforum.com/forum/f9/20...2/index67.html
smoghog4 is offline
2006 Rubicon Unlimited-did it come with lift kit? radebaugh03 TJ Wrangler Technical Forum 5 04-06-2011 09:56 AM
2006 Rubicon has power but won't crank Futhy TJ Wrangler Technical Forum 13 02-05-2010 11:07 AM
Old Man Emu on a 2006 Rubicon Unlimited classicinjectio TJ Wrangler Technical Forum 11 03-28-2009 07:28 PM
I'm getting rid of my 2006 Rubicon Unlimited Iceman0502 Wrangler General Discussion 0 07-17-2008 10:35 AM
2006 Rubicon Unlimited LT1 350? lift. BOTTCAVE TJ Wrangler Technical Forum 14 01-17-2007 10:16 AM
