2006 rubicon with tapping noise - JeepForum.com
post #1 of 4 Old 04-29-2013, 04:59 PM Thread Starter
tomskibum
I've had this tapping noise come about when I hit about 190,000 miles. It is loud when cold but goes to more of an off and on when hot. It will almost go away after a long hwy drive. I've been told it might be a lifter. I was also told to try sea-foam and Rislone. Anyone got any advise??? Thanks
tomskibum is offline
post #2 of 4 Old 04-29-2013, 05:23 PM
wwch99tj
My 4 banger did the same thing and it ended up being a broken piston skirt...
Sent from my Galaxy Tab
wwch99tj is offline
post #3 of 4 Old 04-29-2013, 05:29 PM
Mick VT
Mick VT's Avatar
Lifter would be pretty high on the list of suspects. Broken skirt somewhat lower IMO
Mick VT is offline
post #4 of 4 Old 04-29-2013, 08:13 PM Thread Starter
tomskibum
Have you guys heard of anyone using the rislone stuff? I was told to subsuit it for a quart of oil when I do an oil change. Then change oil again at about 1000. Do it again and noise should go away. I was told it would clean up inside of lifters area.
noise , tapping , tj
