2006 Neutral safety switch question - JeepForum.com
post #1 of 3 Old 03-07-2011, 01:06 PM Thread Starter
mohillbilly
My switch is bad. I know I can replace it, possibly put a 10 amp fuse in the #28 slot, or possibly run a toggle switch to bypass.
Is there a reason that the two wires running from the connector to the switch just can't be wired together to complete the circuit to bypass the switch? I'm not an electrical type guy.
Thanks,
Bret
mohillbilly is offline
post #2 of 3 Old 03-07-2011, 01:44 PM
mdm
Farm Wheeler
Why not just put a fuse in #28? That's what it's there for.
For the record, you have a six speed. You have no neutral safety switch.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 3 Old 03-07-2011, 01:46 PM Thread Starter
mohillbilly
Maybe I called it the wrong name. It is the round jobby on the end of the clutch that only allows the jeep to start when the clutch is all the way in. I do have that on my jeep and it is faulty right now. Just checking my options.
Thanks,
Bret
04 tj safety neutral switch dailydriven04 TJ Wrangler Technical Forum 10 08-09-2010 05:53 PM
Quick Question about Neutral Safety Switch... jwh21236 TJ Wrangler Technical Forum 0 09-09-2009 11:39 AM
AX% Neutral Safety Switch Canfourjeep YJ Wrangler Technical Forum 3 01-09-2008 12:39 PM
Neutral safety switch nolo263 YJ Wrangler Technical Forum 6 04-13-2007 10:41 AM
Neutral Safety Switch? oh88fan YJ Wrangler Technical Forum 6 04-20-2006 06:06 AM
