2006 Jeep Wrangler Codes P0032-38-52-58 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 2006 Jeep Wrangler Codes P0032-38-52-58
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectJKS Now Available at www.baseline4x4.com, Trackbars, SkidsFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread Today, 08:07 AM   #1
A1racing
I have a 2006 Jeep Wrangler with the 4.0L and the check engine light come on about a week ago. I checked the codes and it flashed P0032-P0038-P0052-P0058. I ran some "Sea Foam" through a couple of tanks and cleared the codes and it went away. I drove it for about 62 miles and the check engine light comes on again showing the same codes.I have not noticed any performance issues during any of these events. Can all four O2 Sensors go bad at the same time?
Any help would be appreciated.
A1racing is offline   Reply With Quote
Unread Today, 06:42 PM   #2
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Its possible... IMO
TSB Information: http://www.automd.com/tsb/jeep_m/wrangler_mm/2000_y/
Knuckelhead is offline   Reply With Quote
Unread Today, 07:43 PM   #3
wtroger
Make sure the wiring to the o2 sensors didn't get up against the exhaust pipe and melt. Have seen that before and caused those codes
wtroger is offline   Reply With Quote
Unread Today, 09:21 PM   #4
kdsk2071
. Is it possible to get a code for high voltage at an o2 sensor from the wire burning or getting too close ? I get a code of p0132 that deals with the o2 sensor
kdsk2071 is offline   Reply With Quote
