2006 driveability issue?Flat spot!
| Truck-Lite's New LED Headlamp Series | GR8TOPS Introduces the Exogate HD Tire Carrier | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
I have had my new rubicon for 3 mos now and have noticed a definate flat spot in the throttle from about 1500 to 2000 rpm's ,right where you need it!.I have taken it to the dealer and was told there were no software updates and the comp was probably designed to run that way for emissons reasons.Has anyone else with an '06 come up with this problem or am I the exception? It is bad enough that I can feel myself falling forward when I romp on it at around 1200 to 1500 rpm's for about a second or a second and a half.then it leaps to life and jumps up really well.Thanks in advance,I love this site! So much info and advice,So little time and money!
#2 |
Jeep
I have the same problem on my '04... there was a topic a while back on this too, everyone had the same problem. No fix as of yet other than shifting at a higher RPM.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear 2.25" Suspension Lift with Old Man Emu Shocks Performance Accessories 1" Body Lift Daystar 1" Motor Mount Lift Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires |
#3 |
2006 LJ Rubi, 2500 miles. Flat spot most pronounced in 3rd gear. Rig pulls fine from 0 to 1800 rpm, gets stuck in molasses, then recovers at 2500 rpm. Dealer says "nothing wrong". Yea, some friends with a 99 TJ and 2001 XJ don't have this feature...
#4 |
I have an 06 Rubi Inlimited with 3K miles. Same problem and most promounced in third as well. I just thought it was all in my head. Nice to know that I am not the only one.... Now we need to find an engineer from Jeep... 8)
JEEPLESS... :( |
#5 |
I have a 2006 as well, same problem. Between that and the grinding 6 speed tranny, i'm pretty pissed about my purchase.
#6 |
No flat spots or tranny problems with my 98 2.5L!
Insert flame here> |
#7 | |
There you go! ![]() |
#8 | |
Jeep
#9 |
no flat spots on my auro rubicon....but i also installed the edge kit
03 rubi....growing bigger and better every day... |
#10 |
I have the flat spot and grinding gears in my '05 LJ too, but I have noticed that after 7500 miles, the gearing is getting smoother and the flat spot is less pronounced.
“This isn’t the Old West, because the New West has never arrived. It’s just the West, like Wyatt Earp died yesterday.” ─ Michael Martin Murphey talking about the Eastern Sierra during an interview in 1996. |
#11 |
My 05 clashes a bit shifting into second, and I to have a flat spot...most noticable in third.
If anyone has a solution I'd be happy to hear it as well. Otherwise, I've learned to live with it.
2005 Silver Rubicon, 6 speed, Dual Tops + bikini, 2" BB, 1" BL, 33x12.5x16 Boggers, Cobra 75, KC 130W slimlights, OR Fab Rock Doors, and some poison spyder diff guards |
#12 |
BTW - Synthetic in the tran is supposed to help with the grind. I see synchro grind mostly on 2-3 shift. I can deal with that...
THe flat spot has been enough that for a while I wondering if my clutch was slipping or something. Everyone says TB spacers and bored TBs are a waste. However, if it helped with this I would actually consider it...
JEEPLESS... :( |
#13 | ||
Yea my 06 X with a 6 speed has all the same issues, and yea i thought i was going crazy also when i pushed the gas down heavy o man on ramp and nothing happened then it launched, i relize its a jeep and not ment for speed but i was irked at first. What i do now is just deal with the lag around town and when i am enteringa highway just shift a bit later and the problem is gone, and also the grinding is starting to let up with almost 9 k on the trans.
06 Red Wrangler X 6 speed hard top Ford 8.8 Detroit locked, 4 inches of lift, 33 inch BFG KM2's and some other stuff. |
#14 |
interesting stuff, guys. i'll check to see if i have a flat spot, too. i do have the grind between 1 & 2, and sometimes between 2 & 3. if i shift really slow, like with the SM465 that i had in my CJ, then i can shift and not grind, but people behind me tend to give me dirty looks as the blow past. any idea as to why the grind exists? also, what is it doing to the tranny? i thought that the 6-speed was supposed to have triple synchros between 1 & 2. weird. glad i'm not the only one, though.
Current Jeep: 2006 Unlimited Rubicon Previous Jeep: 1981 CJ7, 4.2L, Muncie SM465, Dana 300 t/c, Dana 30 Front, AMC 20 Rear |
#15 |
I have a 06 Rubi with the same problem. I was not sure I had a problem because the thing is not a ball of fire anyway.
Good to see I'm not crazy!!!
2006 Rubi Unlimited4.0/ 6spd/4.5" RESF with RE shocks/305/70/16 Cooper ATR on Moabs/5 KC Slimlights/Big Daddy Bumper- tire carrier/Outland Seat covers |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
