2005 Rubicon Lockers???? - JeepForum.com
post #1 of 7 Old 05-08-2009, 07:06 AM Thread Starter
msbs80
Just bought a 05 Rubicon, how do I check to see if the lockers work, without being in any mud. Can I check them on dry pavement as long as I dont drive it?? Thanks Guys
msbs80 is offline
post #2 of 7 Old 05-08-2009, 07:10 AM
Noxian
2011 JK Wrangler
Yes, just make sure you dont turn the wheels too much while on dry pavement, you can roll it forward and backwards and they should lock, sometimes you have to wiggle the steering wheel abit to get the front to lock and to unlock.
Noxian is offline
post #3 of 7 Old 05-08-2009, 08:36 AM
red rubi
So long pal!
red rubi's Avatar
A couple of things. make sure the locker lights on the dash turn on. When it is flashing the locker is not engaged for whatever reason. That is not unusual unless it does not stop flashing. When I had a pump go out I turned the key to run, without the engine running, and turned the lockers on one at a time. If you listen carefully you can hear the pumps working (there are two mounted on the skid plate) but only for a second. If you don't hear a pump or if the pump doesn't shut off then you have problems.
red rubi is offline
post #4 of 7 Old 05-08-2009, 08:43 AM
Noxian
2011 JK Wrangler
^x2
Also if the light keeps flashing and you check the pump is activating and the diff is infact locked, it may be the sensor in the diff (a little switch) I had mine replaced in the fall. Very expensive since they have to pull the diff apart to replace a 20$ switch(sensor).
Noxian is offline
post #5 of 7 Old 05-08-2009, 08:50 AM
red rubi
So long pal!
red rubi's Avatar
Originally Posted by Noxian View Post
^x2
That's the first I have heard of that
The Rubi lockers are very effective but they seem to be a little fragile.
red rubi is offline
post #6 of 7 Old 05-08-2009, 09:03 AM
Noxian
2011 JK Wrangler
Yeah it was the first I had heard about it until it happened to me, even the dealership couldn't troubleshoot it properly I has to rip out my FSM and do some troubleshooting myself after they told me "4x4 working fine" even though I told the service adviser to put in "Front Axle lock light flashing, locker engaging, pump working, suspect sensor in diff"
its not common for the sensors to fail, unless someone over tightens the fill plug, which wasn't the case cause it was working fine while 4x4ing then just started flashing instead instead of showing locked.
The dealership even told me before opening the diff that it would only be a hour of work, even though the FSM said they had to pull the diff apart and I read online it could be closer to a couple hours, sure enough when I picked it up latter that day it was 7 hours of labour...
Noxian is offline
post #7 of 7 Old 05-08-2009, 12:29 PM
bojang
Both of my indicators work when ever they want to. I just kind of assume they are working unless something says otherwise.
Chris
Freedom from nags, cranks, government, do-gooders, control-freaks and idiots is all that I ask for.
Never trust a lumpy fart.
bojang is offline
Rubicon Air Lockers vs ARB Lockers MLA 97TJ TJ Wrangler Technical Forum 17 07-09-2012 04:37 PM
Do any 2005 Rubicon Lj's come without lockers? cabell TJ Wrangler Technical Forum 21 03-20-2009 02:00 PM
Lockers in TJ Rubicon Gymguyjeep TJ Wrangler Technical Forum 6 02-29-2008 04:57 PM
2005 TJ Rubicon vs 2006 TJ Rubicon vic777 TJ Wrangler Technical Forum 6 10-27-2007 09:44 PM
05 rubicon lockers munzaruby TJ Wrangler Technical Forum 11 02-11-2006 07:03 PM
