2005 Rubicon Axle Locks - JeepForum.com
post #1 of 15 Old 07-21-2010, 12:55 PM Thread Starter
FLKRUZN
I've searched the forum so don't flame me please (Yes, I'm a newbie)
Is there an advantage to modifying the stock axle lockers to provide independent control of the front and rear lockers? The mods I have seen end up allowing the lockers to be set at any speed in any t-case position. Is this a worthwhile mod and what are the dangers?
FLKRUZN is offline
post #2 of 15 Old 07-21-2010, 12:58 PM
dcope17
You have 3 positions already, Both open, rear locked and both locked.
You don't have the option to lock the front only.
At least that's the Rubi setup.
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #3 of 15 Old 07-21-2010, 01:15 PM Thread Starter
FLKRUZN
Ah I see. I thought they were either open or locked. Good to know; however, the modification allows me to control them independently.
Open
Front Locked
Rear Locked
Both Locked
My question is whether this is advantageous and whether the resulting ability to engage these at any speed and any t-case position is dangerous.
Thanks!
FLKRUZN is offline
post #4 of 15 Old 07-21-2010, 01:19 PM
Sundowner
Sure, there are advantages...you get more precise control over which axle is locked and which isn't by being able to lock the front only. Some drivers like this, especially if they're doing more technical crawling. What I don't like, personally, is the speed-sensitive lockout override...I don't want someone hitting that switch accidentally on the highway.
Incidentally, it's not a modification to the locker itself...you're actually modifying the workings of the switch/relay.
If it helps, I thought about doing it and decided not to do so...I don't do a lot of crawling where I'd need a locked front and open rear, and I actually prefer the safety of the speed lockout. For now.
Sundowner is offline
post #5 of 15 Old 07-21-2010, 01:39 PM
-dirt-
I've done this mod. I don't feel it makes my Jeep more dangerous.
Say the locker switch is accidentally pressed while going down the highway.
#1 - It may not even engage.
#2 - Even if it does, it only locks the rear axle. You (or a passenger) would have to press it again to lock the front. Only then would steering be affected.
#3 - You can always just press up on the switch to disengage it.
There are "what-ifs" with everything in life. If you aren't comfortable with the mod don't do it. Same goes for bigger tire, lifts, etc.
-dirt- is offline
post #6 of 15 Old 07-21-2010, 01:39 PM
Xlr8n
1967 JK Wrangler
The main advantage to the mod is you can lock the rear in 2Wd, or front or rear in 4WH. Both helpful in snowy climates.
The popular version of the mod won't allow for engagement over 10mph as factory set but installing a separate inline toggle switch will prevent accidental engagment at speeds under 10mph as well which is a cheap and worthwhile step while the dash is already taken apart.
Xlr8n is offline
post #7 of 15 Old 07-21-2010, 01:40 PM Thread Starter
FLKRUZN
Thanks for the feedback sundowner! I had the same concerns about my wife or kids accidentally hitting the switch (even though it would be covered) on the highway. I won't be doing much rock crawling...more mud than anything because I live in South Florida.
Is there any advantage to the mod for mud or is it primarily just for rock crawling?
FLKRUZN is offline
post #8 of 15 Old 07-21-2010, 01:42 PM
-dirt-
Locker + 4HI + mud = fun
The 241 4LO is generally considered too low for mud.
-dirt- is offline
post #9 of 15 Old 07-21-2010, 02:01 PM Thread Starter
FLKRUZN
Thanks all! I think I'm going to give it a go. I'm leaning toward the mod in the attached. If I understand how this works, according to dirt_j00:
So, by flipping the switch, 1 press on the factory switch will lock the rears in 2H or 4H position under 10 mph and a second press will lock the front. Is this right?
Also, according to the write-up, I can remove the 10mph restriction entirely by bridging pin 1 in the attached setup. Is this a better approach for mud?
I appreciate all the help
FLKRUZN is offline
post #10 of 15 Old 07-21-2010, 02:07 PM
BriansCJ
1994 XJ Cherokee
Ive used the 4.1 in mud plenty of times. Sure its too low for general trail riding, but for pulling people out its great. And sometimes the mud we have hear is very sticky and sucks you down, I have to use low to get it moving again when 4HI just wouldnt get the torque to the wheels.
This is what I did. It was great. I reccomend this to anyone doing sand, snow or mud, or high speed hill climbs.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #11 of 15 Old 07-21-2010, 02:14 PM
Xlr8n
1967 JK Wrangler
The factory restriction simply keeps the locker from being engaged at speeds under 10mph but does not prohibit the lockers from staying engaged above that speed. Once they're locked, they stay locked until you release them via the switch.
From my perspective, there is no rational reason to want to attempt to engage the lockers above 10mph anyway as it would likely be a fine display of grinding and possible breakage, so I'm not sure why that method would be attractive??
Xlr8n is offline
post #12 of 15 Old 07-21-2010, 02:25 PM
-dirt-
yes
yes
more/different info here: Rubi Locker Switch Bypass - 1
-dirt- is offline
post #13 of 15 Old 07-21-2010, 02:28 PM
-dirt-
I assume you have this info: Rubicon Locker Bypass
But just in case you don't...there it is.
-dirt- is offline
post #14 of 15 Old 07-21-2010, 02:28 PM Thread Starter
FLKRUZN
Guess that answers my question, Thanks! Now all I need is my Jeep back from the shop...$%!# mechanic left the door open when he put it on the lift...CRUNCH!
Yep. That's the one I'm using. Thanks for the other version...the pictures are bigger ;-)
FLKRUZN is offline
post #15 of 15 Old 07-21-2010, 02:40 PM
-dirt-
Food for thought: Has anyone installed an ARB and then put various defeat mechanisms on it?
-dirt- is offline
rubicon , locker , mod , modification , switch , override , tj , wrangler
JK Rubicon - diff locks on and ESP/ABS off in H4 with switch ThalerDesign JK Wrangler Technical Forum 7 02-16-2010 01:27 AM
Wheel locks for JK Unlimited Rubicon 4dr? boltsnnuts JK Wrangler Technical Forum 17 08-11-2009 10:44 AM
Power locks on a 2005 TJ calnhobes TJ Wrangler Technical Forum 35 08-08-2008 05:45 PM
2005 TJ Rubicon vs 2006 TJ Rubicon vic777 TJ Wrangler Technical Forum 6 10-27-2007 09:44 PM
Rubicon Hub locks? 5artist5 TJ Wrangler Technical Forum 12 01-19-2007 10:05 AM
