2005 Jeep Rubicon w/ Benz NSG-370-6 speed manual tranny problems - JeepForum.com
post #1 of 2 Old 11-11-2011, 08:31 PM Thread Starter
firefly88
Hello,
I have a 2005 Jeep Rubicon with a Benz NSG-370 6 speed manual transmission.
In about 2007, she began to jump/bump/or pop violently out of first geat from a standing stop. I have tried everything in the tranny: switching to Penzoil Synchromesh & Royal Purple's Synchromax. Right now I am using Royal Purple & it is has given me the best results so far. As a rule, I change my tranny oil once a year.
Both have worked better than the standard NV3550 Mopar Manual Transmission Fluid. I don't know why this fluid was recommended for a completely different transmission & particuarly a Benz transmission. But I am not an auto expert.
I also find that if I go into Neutral after a stop & then shift into 1st before accelerating & hold to the stick, it is less likely to happen. Also, a higher rev prior to acelleration from a standing stop seems to help. It could (?) be that I am not paying attention & don't do the things I mentioned or I am not shifting all the way into 1st gear.
I have also been told I could have a bad synchronizer for 1st gear & that there is a Chrysler TSB on this problem, but Chrysler is not likely to tell you about it.
Has anyone else out there had this problem? When it occurs, is sounds & feels like someone has hit you in the rear end & the transmission has jumped back into Neutral. It is that violent as its worst.
Any thoughts or suggestions for me & how much it would cost to have this problem corrected?
Again many thanks in advance for your help,
firefly88
firefly88 is offline
post #2 of 2 Old 11-11-2011, 08:59 PM
grnsporty
I have had this also happen quite a few times. It's been months since the last one though.
grnsporty is offline
2005 Jeep Rubicon problem. When in 4 low, delayed engagement of auto tranny trailerjeep TJ Wrangler Technical Forum 16 01-09-2016 11:43 PM
2005 6 speed manual, 1st gear very, very low. mmmhoss TJ Wrangler Technical Forum 43 11-19-2009 12:48 PM
2005 6-Speed Manual slips out of reverse randomly FrankGG TJ Wrangler Technical Forum 9 09-06-2007 02:51 PM
2005 Rubicon rpm's at 65 MPH (Manual Tranny Only) cpleasant TJ Wrangler Technical Forum 13 05-09-2007 09:53 AM
Identification of 2005 6-speed manual transmission??? dpowers46 TJ Wrangler Technical Forum 13 12-07-2006 12:49 PM
