#1 | |
2005 6 speed tranny question
Sorry , yet another questions. I had a 93 cherokee, and a 2003 jeep tj. Both had the 5 speed tranny, and the 03 shifted very smoothly. I have an 05 tj with the 6 speed. Has 43,000 kms on it. The tranny doesnt seem as smooth as the 5 speed. Especiallly going into 2nd gear. Sometimes seems like its catching as it goes into gear. Not silky smooth like the 5 speed. Don';t know how else too expalin it, kinda like the sincro gear is not right. Is this normal with anyone else with the 6 speed.
Thanks Mike
#2 | |
You can't shift them fast. They are a truck tranny. But, here's something to look for, Many of the NSG 370's came from the factory a quart, sometimes more, low on trans oil. My '06 was a quart low. Check that oil and better yet, put the Royal Purple Synchomax in there. Mine shifts much smoother now. I would presume being a quart low affected it, but the shifting is very noticeable better now. There was also a couple TSB's on the '05 models in regards to clutch linkage and also the reverse gear shift fork bending/failing. Check that oil now. 14MM allen head to check, 17MM allen head to drain. If you don't have really good socket type allen head wrenches in those sizes, buy them. Those plugs are on there tight and they look easy to strip. I got mine at Autozone. They came in a 3 pack. Well worth the $10.00 investment. Bob
2006 Solar Yellow Rubicon Unlimited Jeep Club Member #1340 6 Speed, Hardtop Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come! |
#3 | |
#4 |
The allen head is huge, just get under there and look, the 17mm will be on the bottom, and the 14 on the side (I think the drivers).
04TJ 3.5 RE Extreme Duty Long Arm, ARB F&R, 4:88's, Cromo shafts, 35 MTRS, Rokmen Armor. TJ's gone. See you on the trail in my Toyota :). |
#5 | |
Dad and Son
2005 Yellow TJ, 4.5 RE SF (3.5 Springs). A-Z Rockers and Swing Away Rear Bumber, RE Monotubes, Front and Rear RE Adj. Track Bars, TeraLow SYE, Tom Woods DS, Mickey Thompson 33X12.5 MTZ and 15x10 Classic Locks, Buschwacker Flares, Warn 9000i and Grill Guard, OME Stearing Stabilizer, Banks Monster Cat Back Exhaust, KC Fogs and Spots, JL sound system LP# TWEETEY
#6 |
I'll have to check those tomorrow...that would explain why every time I start forward I think of trucks in a WWII movie.
Was installing mods before the temporary tags were off. |
#7 |
Mine is rough too.. I plan on changing the fluid this weekend. I hope it improves as it has gotten worse over the past two weeks.
www.DurtyRoK.com Carolina Offroad |
#8 |
X2 on the RP Synchromax.
I changed it at about 10K in my O5 and there is a huge difference. But, it is still a truck tranny and needs to be shifted slower than a sports car. The fill plug is on the right (passenger) side of the tranny. HTH, Dave |
#9 |
Nsg370
Wow a quart low!! I just checked my FSM and it claims the refill capacity is only 3.17pts, that's just over a quart and a half. Some of your trannies must have been all but empty. Guess I better get a 14mm and check mine asap. Thanks for the heads up.
Flame Red 2005 Rubicon Unlimited, 4.0L, 6sp, dual tops, Valvoline VR-1 10w30 engine oil/M0-090 Mopar filter, Amsoil Synchromesh 5W30 trans. oil, IPF 920hc head light conversion with PIAA Xtreme White plus bulbs, PIAA Xtreme White Plus H-3 fogs, Armadillo front/rear bumper caps and Olympic grille guard. Amsoil SevereGear 75W140. |
#10 |
Ive noticed the same rough shifting in the lower gears since the day I drove it off the lot. I assumed it had to do with the HD transfer case, I'm going to check the fluid this weekend maybe change it out with the good stuff(Purple crap).
It is a toy,and you should play with it. |
#11 |
The check/fill plug (14MM) is on the right/passenger side of the trans a little past midway back. The drain (17MM) is on the bottom in the rear and center. Mine took a little more than 3.17 PTs to fill. When I said it was a quart low that is an estimate. But it was a fairly close estimate. Over on the ROF there are a couple guys who had the same low oil condition. The RP synchromax really does make them shift smoother. I have no idea why, but it does seem to work. Bob
#12 |
So its the pass side...im running the 5speed on the 04, and its different....just doing my best to help.
#13 |
Yeah, mine does it too. I think all the 05's have the same problem with the 1-2 shift. I've noticed it's much worse when it's cold out. Just shift slower. As you shift from 1-2 you'll feel a "pause" while the shifter slips into 2nd. Use a light touch when shifting. Don't fight it. Remember, it's a Jeep, not a race car.
Joe 2005 Solar Yellow X 2" Skyjacker BB - 31X10.5\15 Cooper STT www.wnyoffroad.org |
#14 | |
Yikes
#15 | |
Oh yea, X10 on the synthetic tranny oil. Just drain and replace. you only need a couple quarts!
Silver '06 TJ w/ neat stuff on her! "New" 1987 YJ Project for my son! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
