2005-06 Jeep OPDA_CPS_Distributor Failure - Page 91 - JeepForum.com
 10Likes
post #1351 of 5527 Old 05-31-2011, 04:40 PM
JeepScrap
Originally Posted by steitsma
The 7 year 70,000 powetrain only applied to the 2005 year right?? I'm the 2nd owner of an 06 with 55000 miles. Is there anything I can transfer??
Model year 2006 only had a 3 year/36k mile warranty.
Sent from my Droid using JeepForum
"Science will win in a battle with religion because it works." -Stephen Hawking
JeepScrap is offline
post #1352 of 5527 Old 05-31-2011, 04:43 PM
biffgnar
biffgnar's Avatar
True, although we did get the federally mandated 8/80 emissions warranty. Not sure about transferability of that. Not that that helps here.
Romney in 2020!
biffgnar is online now
post #1353 of 5527 Old 05-31-2011, 08:50 PM
yellowismellow
Custom User Title
yellowismellow's Avatar
I have an 06 and I have the 7/70 powertrain warranty.
2006 TJ Sport
2004 WJ Special Edition
yellowismellow is offline
post #1354 of 5527 Old 05-31-2011, 09:05 PM
JeepScrap
How so? Did you have an option to purchase a longer warranty? Are you the original owner? All the warranty books that came with my Jeep only show a 3/36. I even called Chrysler to verify and they confirmed 06's only have a 3/36 powertrain warranty.
post #1355 of 5527 Old 05-31-2011, 10:11 PM
ajt976
The paperwork I have with my '06 states 3/36 as well, this is why I thought I'd be wasting my time at a dealer trying to get them to replace anything.
ajt976 is offline
post #1356 of 5527 Old 06-01-2011, 10:33 AM
yellowismellow
Custom User Title
I purchased the warranty when i bought the jeep. i am the original owner.
2006 TJ Sport
post #1357 of 5527 Old 06-01-2011, 02:03 PM
Xlr8n
1967 JK Wrangler
You bought an extended warranty. Posts here were referring to the factory warranty which is 3/36 for an '06 and 7/70 for an '05.
Xlr8n is offline
post #1358 of 5527 Old 06-03-2011, 06:23 AM
Fusco
2016 JK Wrangler
Well it finally happened. Started her up this morning, 55 degrees out. Drove her less than 40 yards and received 5 seconds of "laughing monkey" then it stopped. Pulled over, she was idling around 500 rpms, oil gauge was normal.
But thankfully she's not my DD, turned around and parked her for the car. I'll schedule appointment with dealer once they open and thankfully she's still covered under the CPO warranty until 80k or June 2012. She has 68,700 miles
So....before I call dealer...
What should I say? If I say OPDA and laughing monkey any chance they'll have any idea?
Wondering if I should just give them link to thread, for Service Mgr.
I'll push to have OPDA and CAM replaced if I see major wear. What about lifters?
Any feedback and what and not to say is greatly appreciated.
Thanks!
2016 Jeep JK 2D Sport S
2006 Jeep TJ Rubicon Impact Orange - SOLD :-)
Fusco is offline
post #1359 of 5527 Old 06-03-2011, 06:27 AM
keithert
keithert's Avatar
Fucso, are you going to drive it to the dealer or have it towed?
Current: 2016 Ram 1500 Sport - Past: 05 Wrangler LJ, 90 and 92 Trackers and 98 Wrangler SE
keithert is offline
post #1360 of 5527 Old 06-03-2011, 06:31 AM
Fusco
2016 JK Wrangler
i have towing with my USAA insurance. just have them bring it in.
easier, especially if this thing starts singing again....
Fusco is offline
post #1361 of 5527 Old 06-03-2011, 07:31 AM Thread Starter
willydigger
If the dealer isn't going to replace the cam I see no reason to go. You will be frustrated. I don't know the warranty deductible (mine was $100) but they will likely decline knowledge of the situation. If not I've heard reports of the OPDA being listed as electronic and not powertrain (as evident by the search criteria for dealer parts). My dealer said it wasn't covered until I argued with him. He also said the cam gear was fine. I'd expect a lot of headache's. There have been reports of complete cam coverage though so I suppose it's worth a shot.
I think this is a good example of what doing nothing will yield. You are fortunate to have the laughing monkey warning. I wish you luck with the dealer. You have all the info you need to push them. I would also be insistent on a new OPDA not just a gear replacement. The laughing monkey means the bushings/shaft is shot.
willydigger is offline
post #1362 of 5527 Old 06-03-2011, 07:54 AM
Fusco
2016 JK Wrangler
Originally Posted by willydigger View Post
My dealer said it wasn't covered until I argued with him. .
What points did you bring up so they did cover the OPDA under warranty?
Did you CAM have abnormal wear?
You make valid points, but I have to at least try. When they do replace OPDA...then it would be a no brainer to Mod.
Fusco is offline
post #1363 of 5527 Old 06-03-2011, 08:21 AM
keithert
keithert's Avatar
Not necessarily if you are still under warranty. Having a modded OPDA could negate your warranty. If you can please get some pics of your OPDA wear.
keithert is offline
post #1364 of 5527 Old 06-03-2011, 08:32 AM
Fusco
2016 JK Wrangler
the idea was to replace current non-mod OPDA under warranty.
then modding the new unit, as the CPO warranty should be up by the time, if/when the OPDA goes again.
i will get detailed pics of the OPDA and CAM when I go to the dealer.
appointment scheduled for Tuesday AM.
Fusco is offline
post #1365 of 5527 Old 06-03-2011, 08:37 AM Thread Starter
willydigger
I used logic. When he said it wasn't covered under the powertrain I asked him how an engine component the drives the oil pump wasn't covered under the powertrain. He then told me he would check again and wouldn't you know it was covered. Some here have reported that their dealer said it was an electrical/ignition component.
Once it was replaced I modded it. My warranty was 7/70 and it failed at 60K. The measly 1/12K warranty on the OPDA was not "warm and fuzzy" enough knowing what we all know now.
Also the dealer specifically said the cam gear was okay. I have no reason to trust that and side with others who think that one affects the other. I would suspect your cam gear is worn, but I don't know the lifespan after that point. The OPDA is the weaker sacrificial component. It will wear more severely.
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
