2005-06 Jeep OPDA_CPS_Distributor Failure - Page 8 - JeepForum.com
 10Likes
post #106 of 5527 Old 01-21-2011, 04:39 PM
Jeffro06
Jeffro06's Avatar
Originally Posted by TJXTWO View Post
I assume this is because of the higher ZDDP levels? I am running Mobil 1 10-30 full synthetic and adding ZDDP to the oil. Is there another reason to run the TD oil?
I was recommended in post #9. I tried it, it seems to be working.
Jeffro06 is offline
post #107 of 5527 Old 01-21-2011, 04:44 PM
TJXTWO
Cool, just wondering if I missed something in the thread.
BTW: you are lucky if your dealer has the OPDA. I just talked to my dealer today, and they only show two dealers in their system with one in stock each. One of the dealers has a note saying the part is not for sale. I am actually going to call the other dealer monday and see if they are willing to sell. Good luck.
03 TJ Sport, 4.5" RE SuperFlex short arm lift, Tereflfex ST swaybar, 33" MTR's, Body Armor bumpers @ sliders, 5 speed manual... 06 TJ Rubicon, 4.5" RE long arm lift, Currie Antirock front and rear , OR Fab bumpers @ sliders, K@N intake, custom exhaust, 1" BL , 1" motor mount lift, 35" MTR's on Pro Comp Alloys, 6 speed manual.
TJXTWO is offline
post #108 of 5527 Old 01-21-2011, 04:57 PM
Jeffro06
Jeffro06's Avatar
I don't think they have one, but I'm not as worried about failure now as I was, thanks to the advice here about the oil, and that I've got my "claim" number on file with Chrysler. If it starts chirpping I'll stop driving it.
I think we all need some luck with this issue. Chrysler needs to fix it, not just throw a band-aid on it.
Jeffro06 is offline
post #109 of 5527 Old 01-21-2011, 04:58 PM
ChaseB
Best of luck, I know another member had already tried that dealer with no luck. What the hell are they going to do with it then? Bastards
And I'm changing my oil Monday, not going to wait another two thousand miles. Diesel TJ here I come lol
1984 CJ-7 Renegade
2005 TJ X (daily driver)
ChaseB is offline
post #110 of 5527 Old 01-21-2011, 05:03 PM Thread Starter
willydigger
This movie is taking forever. I would expect it to be done late tonight. Then however long it takes to upload to Youtube.
willydigger is offline
post #111 of 5527 Old 01-22-2011, 05:45 AM Thread Starter
willydigger
Wow that was really complicated. I had to convert it, enable, edit, save, and upload. Anyway here it is. I ran out of daylight so I didn't get any video of inserting the screwdriver. Hopefully this should give people some confidence with the removal.
T20 torx for the lid bolts
1/2 -6 point wrench for the retaining bolt
I few interesting comments. I recommended the 6-point wrench and then ended up using the open end. To clarify, I did work on an OPDA where the bolt was rounded. A 12-point would not engage and the open end slipped as well. With a 6-point you'll get a good grip on a rounded bolt. If your bolt is in good shape (like mine was in the video) a 12-point will work.
Also at the end (11:19) I misspoke and said "don't turn the engine off". I should have instead said "don't turn the engine on". NEVER turn the engine on unless you are comfortable with the reinstallation.
Finally, I'll likely do another video in the spring. When it's times to pull the OPDA for inspection. I'll put this video on the first page and then when I do a better one, I'll replace it.
post #112 of 5527 Old 01-22-2011, 06:42 AM
ChaseB
The video really cleared things up! Thanks for taking the time to make it. Just to clarify what happens exactly with the oil pump when the OPDA won't go back in? When using the flat head in the hole, do you turn it in a certain direction?
1984 CJ-7 Renegade
ChaseB is offline
post #113 of 5527 Old 01-22-2011, 06:50 AM Thread Starter
willydigger
I was afraid of that question. For whatever reason (cold, rushing, whatever) the oil pump moved a little when I pulled out the OPDA. The bottom has a flat key that will fit into the slot on the oil pump. You have to take the screwdriver and put it in the oil pump slot and tweak it so that when the OPDA shaft goes in, it lines up right. The oil pump will spin easily. Generally it's a little to the left or right. Place the target wheel match mark on the start mark (not the sensor mark) and look at how the bottom slot is facing. They turn the oil pump to get close to that alignment. It takes a little trial and error. I ran out of daylight or I would have shown the whole process. It is probably the most nerve-wracking part.
When I redo the video I will purposely mess it up and fix on camera.
post #114 of 5527 Old 01-22-2011, 07:02 AM
ChaseB
I understand now, the bottom of the OPDA fits into that slot and and you just have to turn it (on the oil pump) so that when the OPDA goes back in it will fall into that slot?
My lack of knowledge of anything engine related is apparent!
1984 CJ-7 Renegade
ChaseB is offline
post #115 of 5527 Old 01-22-2011, 07:50 AM
chutta
Either my chirping is the OPDA or a pass side U-joint I swapped out(ears werent perfect straight).
It will chirp briefly when cold, can not duplicate stopped, nor does it rise/fall in pitch with the revs, only go away below about 7mph.
disco'd the front driveshaft to rule out those joints.
Pretty sure it's the OPDA and maybe more, as the motor ticks/clicks after the chirping like a lifter failing.
When all is warm things smooth out.
It's friggin 12 degrees out up here, going to try to do it Sunday aft and get it back together right this time
05x 4.0 6sp 30/35, aussie front, 3.73's, r/c 4"x lift, adv adptr sye, shifter bracket, tw cv ds, 33 t/c skid, 33x12.5 dunlop mud rovers on steelies, psc sport cage/rockers, warn fr bump/steer and 30 diff skid, sirius,cb, hand throttle 1"bl/mml 265/16's pepboys at's on orig moabs for street. Lowrance H20c for gps
chutta is offline
post #116 of 5527 Old 01-22-2011, 08:40 AM
Peterpsc
I'm a backyard mechanic and your video Willydigger of the R/R of the OPDA is terrific. Thank you for your effort. The Fog deserves much credit too.
Peterpsc is offline
post #117 of 5527 Old 01-22-2011, 01:22 PM
Mud Machine
Jeep Addict
Mud Machine's Avatar
Just want to say "THANK YOU" for freezing you *** off for us. It is certainly appreciated. Exceptional job!
BDS Springs, MetalCloak Arms, Fox Shocks, Warn Winch, Savvy Ft Bumper, Antirock, GenRight Fenders, GR8 Top, 35" Pittbulls, 5.13's, Revolution Axle Shafts, LS-III, 4L80e
'76 CJ-7, 33" Swampers, 6-Point Cage, 4-Speed, Dana 300 Twin Stick
Mud Machine is offline
post #118 of 5527 Old 01-22-2011, 06:35 PM
lope
lope's Avatar
Not bad Willy, but tell that gal running the camera she did awesome!
lope is offline
post #119 of 5527 Old 01-23-2011, 01:55 AM
2006_Sport
http://www.youtube.com/watch?v=A3qJxlV_GJ4
You're the man. It was cold as **** today and yesterday in MD, and windy.
2006_Sport is offline
post #120 of 5527 Old 01-23-2011, 06:55 AM
jeffjeep1
jeffjeep1's Avatar
Wily - Great video.
Looks like you ended up with a "flush" grease fitting. Did I see it correctly?
Jean - Wonderful wife
2003 Toyota Sequoia
2005 FA64 (aka LJ) Khaki
Heidi - Golden Retriever/Jeep Dog
jeffjeep1 is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
