2005-06 Jeep OPDA_CPS_Distributor Failure - Page 75 - JeepForum.com
 10Likes
post #1111 of 5534 Old 04-25-2011, 09:34 AM
pwmac
OPDA replacement
I had a good private engineer to engineer discussion with the Mopar chief engineer at the Jeep Safari
Chrysler is well aware of our issue. Briefly he told me there will be a TSB released in July and new parts to follow.
We discussed the failure and he said so far it appears to be a tolerance issue bushing to shaft. Nothing new there. He is not happy that there is not positive lube for the bussing built into the old design. He made no comments about the gear because I forgot to ask about it. Anyway at this time new part candidates are undergoing dyno endurance testing.
His advice to me with 18+k on my '06 is to take the thing out a look at it and decide if it will survive for a few more months.
No further guidance was offered.
PaulW
pwmac
Durango, CO
06 Rubicon, modified
pwmac is offline
post #1112 of 5534 Old 04-25-2011, 10:04 AM
Bigbob
Bigbob's Avatar
PaulW
Well that's cool, if they follow though. I need to check my warranty. I'd figure they would just send out a notice to all '05-'06 owners and replace it. I wonder what the parameters are to get this done? If they came up with a better mousetrap I'd be willing to buy the part and install it myself. Thanks for the post.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #1113 of 5534 Old 04-25-2011, 10:38 AM
pizzle
pizzle's Avatar
PaulW
So, they're issuing a TSB and not a recall? I wonder how the dealer will react to seeing OPDAs that have been modded (like mine), for folks that weren't comfortable with waiting to see if it will "survive for a few more months".
pizzle is offline
post #1114 of 5534 Old 04-25-2011, 10:52 AM
JeepScrap
Now there's some encouraging news. Lets hope this actually happens. Thanks for the info and talking to your buddy at Chrysler.
Sent from my Droid using JeepForum
"Science will win in a battle with religion because it works." -Stephen Hawking
JeepScrap is offline
post #1115 of 5534 Old 04-25-2011, 11:11 AM
Rubi4MyMrs
Rubi4MyMrs's Avatar
PaulW
I guess that is classic good news/bad news. Good that we may get an "improved" part, bad they are testing them but apparently they don't even know there is no lubrication getting to one of the affected areas.
Wonder what the improved ones will cost if the bad ones list for $377.
I also wouldn't hold my breath on their timetable. They claimed that a redesigned gas tank check valve was coming last Feb. So far no one that I know of has been able to verify that has happened. They have more than doubled the price (like the OPDAs) but as far as we can tell, they have not been improved yet.
Does your gas tank overflow at the pump? FILE COMPLAINT HERE
Check this thread: http://www.jeepforum.com/forum/f176/...recall-974337/
Rubi4MyMrs is offline
post #1116 of 5534 Old 04-25-2011, 11:27 AM Thread Starter
willydigger
Agreed. I'll believe it when I see it.
willydigger is offline
post #1117 of 5534 Old 04-26-2011, 11:22 AM Thread Starter
willydigger
I got the parts from McMaster Carr. The below images are for those with a 1/4-28 FogMOD'ed fitting.
44705K36 Low-pressure Aluminum Threaded Pipe Fitting, 1/8" Pipe Size, Coupling, 15/16"l (.93"), 19/32"od
1227K16 Threaded Elbow-style Oil-hole Cover, 1/8"-27 Npt Thread, 1/4" L Thread, 25/32" H O'all
9006T11 Grease Fitting Adapter, Stl, Straight, 1/4"-28 Taper Male X 1/8" Nptf Fem
44665K111 Standard-wall Aluminum Threaded Pipe Nipple, 1/8" Pipe Sz, Fully Threaded, 3/4" Length, Sch 40
The below images show fitment. They are not tightened.
Now that I have the pieces I think it would have been better to get a 90 Elbow and a straight oil cup. As seen above the oil will only cover the bottom half of the upper bushing. The top half (which is actually in the target wheel housing) will get minimal oil. That may be fine considering the images of heat marks we've seen on the upper shaft are on the lower end of the shaft.
post #1118 of 5534 Old 04-26-2011, 11:31 AM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Willy, Looks good!
post #1119 of 5534 Old 04-26-2011, 12:03 PM
NextJeep
Looks good, Willy. So, the plan would be to alter the FogMod with the oil cup setup above (or use an elbow asn straight cup) and run what kind of oil in it's place? I have not been following this thread for a while...
EDIT--Light Spindle oil...got it.
Is this really worth doing? Has anyone seen issues from the original FogMod? Methinks I will wait before modding the OPDA again--see how it works for a few of you boys. When will this madness end?
NextJeep is offline
post #1120 of 5534 Old 04-26-2011, 12:09 PM Thread Starter
willydigger
Originally Posted by NextJeep View Post
Looks good, Willy. So, the plan would be to alter the FogMod with the oil cup setup above and run what kind of oil in it's place? I have not been following this thread for a while...
No plan yet. I'm going to let Rubi be the oil cup guinea pig. I would think regular motor oil. You may want to try a thicker gear oil too. The key to the oil cup is the upper seal condition. If the seal does not hold the oil cup will fail (unless you plan to lube it often). The relatively low speed of the OPDA allows for a high quality grease to work, however the oil cup is a great alternative provided the seal cooperates.
I wanted to get the pieces because I want to understand the delivery. The holes are small and the oil is gravity fed. It is an easy option for oil instead of grease.
post #1121 of 5534 Old 04-26-2011, 12:15 PM
NextJeep
Understood. Thanks for leading all of this R&D.
NextJeep is offline
post #1122 of 5534 Old 04-26-2011, 01:25 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Willy, glad to be the guinea pig. You are right, there are still unanswered questions. That is why I followed the FOGMod procedure so that if this whole thing fails, I can put the zerk in. We know that works.
If I was sure of this, I could have tapped into the factory fill hole, drilled the bushing & turned the OPDA for access.
I will keep you posted.
post #1123 of 5534 Old 04-26-2011, 01:31 PM
TheRealKTrain
JK Wrangler
Holy cow. This is pretty complicated. Im in the market for an 05 LJ, and this has me second guessing it...
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." Aristotle
Μολὼν λαβέ
TheRealKTrain is offline
post #1124 of 5534 Old 04-26-2011, 02:57 PM
PA_LJ
Update:
So a couple weeks ago willydigger and myself modded and replaced my new opda to fix my laughing monkey prblem. I put a call in to jeep and they called back today offering to cover my parts purchase minus a 100 dollar deductible. I have to send them proof of my purchase via email. So I will end up bein out 160 dollars. 100 parts and 60 fogmod.
I guess this is a positive outcome though I told the jeep guy that there is pretty much no permanet solution to our problem and money doesn't really make me feel better about driving my jeep around like a ticking time bomb....he had no answers.
PA_LJ is offline
post #1125 of 5534 Old 04-26-2011, 03:14 PM
chutta
Sad isn't it. 70k drivetrain warranty and for what if the dealer lies about the cam gear and then you are out there back on the timebomb
05x 4.0 6sp 30/35, aussie front, 3.73's, r/c 4"x lift, adv adptr sye, shifter bracket, tw cv ds, 33 t/c skid, 33x12.5 dunlop mud rovers on steelies, psc sport cage/rockers, warn fr bump/steer and 30 diff skid, sirius,cb, hand throttle 1"bl/mml 265/16's pepboys at's on orig moabs for street. Lowrance H20c for gps
chutta is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
