2005-06 Jeep OPDA_CPS_Distributor Failure - Page 72 - JeepForum.com
 7Likes
post #1066 of 5510 Old 04-22-2011, 04:59 PM
TJJP77
TJJP77's Avatar
Originally Posted by Rubi4MyMrs View Post
I also wonder about mating a new gear to a worn cam gear. If the wear isnít great (deep) is it better to keep the mated surfaces together rather than changing one. Of course both new is ideal but certainly a lot costlier.
What will happen is what happened to mine: the wear on the camshaft gear will transfer itself to the new OPDA gear very quickly - in short order, a new OPDA gear will look exactly like your old one.
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline
post #1067 of 5510 Old 04-22-2011, 05:01 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Originally Posted by willydigger View Post
Rubi, what type of oil do you plan to try?
Iím leaning towards the Valvoline VR1 10-40 in the engine. I definitely want to try to improve this situation (gear wear, not top bushing wear).
As far as in the cup, I will probably use the VR1 also. The clearances are tight & its gravity fed so I donít want a thick oil, especially for winter, but I still need max protection. One of the guys at M-Dale was very sharp. After I explained what & why I was doing what I was doing, he really got into helping me. Believe it or not, he asked me what viscosity I planned to use, pointing out how small the passage was on the adapter. We actually considered a cup with 1/16 pipe threads, but I considered the hole too small. What do you think? Would a synthetic be better because of the lower viscosity?
Originally Posted by Peterpsc View Post
That oil cup is clever. Thank you for the effort. I did the fogmod but darn if I don't like the oil-cup idea. Has it leaked?
Donít know about leaks. Havenít installed it yet. I still have to do a little work on the shaft (clean & polish the lower scratches) then decide whether to replace the gear before final assembly. Then I can at least fill it. Iím in CA now & the Jeep is in NV so it will be a couple weeks before I can actually test it.
Rubi4MyMrs is offline
post #1068 of 5510 Old 04-22-2011, 05:13 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
That's what I thought. At this point I may as well keep the old one for now & watch it. When it gets thin replace it & decide then on a cam replacement. I hope that with a better oil it will slow the wear somewhat.
post #1069 of 5510 Old 04-22-2011, 05:27 PM
Baseplate
Ultimately, the fix for me is:
1. New Roller Cam....something like this http://www.shop.505performance.com/p...&categoryId=31
2. FogMod
3. ZDDP Plus in the oil with a synthetic oil (I live in a hot climate)
I am going to look at the Hesco bronze gear as well.
Baseplate is offline
post #1070 of 5510 Old 04-22-2011, 05:29 PM
tkki1230
Willy-
Here's a shot of the Factory 04 and 06 gears side by side. The 04 is on the right. The holes on both of them are the same.
tkki1230 is offline
post #1071 of 5510 Old 04-22-2011, 06:28 PM Thread Starter
willydigger
Baseplate, I would totally forget about the Hesco bronze gear. It will get eaten away too quickly. I just met with a vendor last week who was talked into buying a bronze gear. He spoke of how his wife was stranded because of the gear failure. The bronze gear is more for specialized applications, not a DD.
tkki, the CPS I got was from RockAuto for $38. It was Dorman from China. I had heard conflicting reports about the hole size so I went ahead and got one. I assume the one you have was pulled from a Jeep? I suppose those needing a gear can try pulling a CPS from an earlier model. Maybe the factory gear is the same as the 2005-06 and the aftermarket ones need the holes opened.
willydigger is offline
post #1072 of 5510 Old 04-22-2011, 06:30 PM Thread Starter
willydigger
That is my plan too. I think eventually a new camshaft will be required. At that point I will for sure use a high ZDDP oil for break in and beyond.
post #1073 of 5510 Old 04-22-2011, 06:41 PM
TJJP77
TJJP77's Avatar
Sweet! Too bad they're so proud of it. I'd be happy with a stock grind roller cam.
Chris
'02 Sahara
TJJP77 is offline
post #1074 of 5510 Old 04-22-2011, 06:53 PM
tkki1230
Yup, it was off of a factory unit.
tkki1230 is offline
post #1075 of 5510 Old 04-23-2011, 08:04 AM
chutta
I searched on their site both for OPDA and CPS no matches
05x 4.0 6sp 30/35, aussie front, 3.73's, r/c 4"x lift, adv adptr sye, shifter bracket, tw cv ds, 33 t/c skid, 33x12.5 dunlop mud rovers on steelies, psc sport cage/rockers, warn fr bump/steer and 30 diff skid, sirius,cb, hand throttle 1"bl/mml 265/16's pepboys at's on orig moabs for street. Lowrance H20c for gps
chutta is offline
post #1076 of 5510 Old 04-23-2011, 09:16 AM Thread Starter
willydigger
Those are aftermarket parts from RockAuto. Tkki pulled his from an 04 jeep. For a perfect unmodified match you'll have to go to a junk yard or maybe the dealer.
post #1077 of 5510 Old 04-23-2011, 10:06 AM
JeepScrap
2. FogMod
My experiment will be to replace my opda and keep running Mobil 1 with 4oz of zddp plus to see how the new gear holds up. I really think that the new oils have a lot to do with the gear wear and I'm very surprised that this issue doesn't get more attention in the Jeep community. After all, it had lots to do with Jeep moving to the v6 in 2007.
Sent from my Droid using JeepForum
"Science will win in a battle with religion because it works." -Stephen Hawking
JeepScrap is offline
post #1078 of 5510 Old 04-23-2011, 10:13 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Huh???...
Knuckelhead is offline
post #1079 of 5510 Old 04-23-2011, 10:49 AM
JeepScrap
Originally Posted by Knuckelhead
Huh???...
The EPA mandated that all auto manufacturers use roller cams to tolerate lower zddp levels in oil which is why Chrysler moved to the V6 in 2007. The flat tappet cam in the Jeep 4.0 or any flat tappet motor REQUIRES zddp.
post #1080 of 5510 Old 04-23-2011, 12:12 PM
Recoil
Recoil's Avatar
1988 MJ Comanche
Anyone replace a cam yet? If so what did you go with?
Recoil is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
