2005-06 Jeep OPDA_CPS_Distributor Failure - Page 71 - JeepForum.com
 10Likes
post #1051 of 5527 Old 04-21-2011, 10:31 PM
TJJP77
TJJP77's Avatar
^ I hate to say this, but the longer wear marks on the one side of your gear show the typical striation wear of a gear that's worn past the outer hardened layer - I'd suggest trying to get a better look at your camshaft gear - I'd be willing to bet it shows similar wear.
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline
post #1052 of 5527 Old 04-21-2011, 11:03 PM
Heath
2014 JK Wrangler
Originally Posted by Zeep
How was it that you had possesion of the Jeep, if every thing was so trashed, and not the dealer?
( sorry about your loss BTW )
Chrysler agreed to pay for it, and the dealer said i could keep driving it till they could fix it, so that's what I did. I pretty much never drove it on the street (maybe 10-15 miles). But I did wheel it. I drove it to and from the park on a trailer. Once the dealer re synced the OPDA, it rarely would give me problems.
If they would have said to not drive it, I wouldn't have.
2013 JKU Rubicon
Heath is offline
post #1053 of 5527 Old 04-21-2011, 11:12 PM
Heath
2014 JK Wrangler
Originally Posted by Rubi4MyMrs
As Willy says, they are off center. I’m not sure if that was intended or not. That is probably why some replacement gears have only one hole in them (from what I’ve heard). That allows the buyer to finish drilling to match their particular misalignment.
Here’s where I’m at. As an update, I have an early ‘05 LJ that had the gear replaced as a recall. I have 25,000 miles now. I have not experienced any definite symptoms. A couple of times last Dec. I thought I may have heard the laughing monkey briefly but it was gone before I could stop & open the hood so I’m not sure
I just pulled the OPDA & disassembled it. Where to start? The gear had 4 holes (all 3/16") so it was a recalled gear that was re-drilled. I don’t know where they got the replacement gears but they were apparently already drilled. They actually had to be re-drilled as part of the replacement process. I think I read that there even was a drill bit included in the package. I marked the gear to get it back in the correct place. Turns out I didn’t have to do that. With 4 possibilities, only one matches, the others don’t even comes close to matching. There was no binding & the shaft spun freely. The shaft had a little oil film on it including the top near the wheel. Wiping with a paper towel confirmed that. There is slight scoring (meaning not deep) on the lower shaft & signs of some heat to the top area. The bushings look pretty good. There is the typical dark ring on the shaft in the seal area. That ring is not grooved like some have experienced. The gear has a very uneven wear pattern. The contact area is much greater on one side than the other (180 apart). I’m not sure what that means but I suspect just poor manufacturing tolerances. It looks bad but the shinny area is not deep. As I said, I don’t know where Chrysler got the replacement gears used in the recall. Maybe they were left over ‘04s? I couldn’t get a real good look at the cam gear but it looks OK.
I checked the shaft end play. It has about .038” The other set of holes would reduce that to about .028” as the holes are at different distances from the end of the gear. I’m not sure if that was intentional or drilling error by the tech that drilled it.
That tech may have done me a favor. He apparently oiled the shaft before re-installation. I’m basing that on the fact that there was some oil on the shaft & when I removed the factory fill plug the grease in the reservoir was dried but not real hard.
I have now finished a modified FOGMod. I followed Willy’s instructions but I installed an oil cup instead of the grease zerk. If it doesn’t work as expected, I can change it to the zerk.
Heath, Sorry to hear about the ’05 LJ. Sounds like you recovered nicely to find an ’06 LJ Rubi. I’ve only seen one ’05 subject to that recall besides mine & they both had the gear re-drilled so I agree with you that it wasn’t done. I went on Jeep.com but can’t find any verification that it was done on mine.
Thanks.
The dealer and myself both have pictures of the 05s OPDA, and the gear looked nothing like that. It had clearly never been touched. Not that it would have made any difference IMO, but I think it was a large determining factor in Chrysler paying up.
As for my LJ, I love it. It is identical to what my TJ was in every way but its an LJ. Impact Orange, LJ, Rubicon, automatic, dual tops, one owner, pristine with all oil change receipts since new dome a the dealer. The only mod when I got it was EBC pads and rotors. 66k miles and he factory MTRs looked great.
2013 JKU Rubicon
Heath is offline
post #1054 of 5527 Old 04-22-2011, 08:15 AM Thread Starter
willydigger
Very clever. Let us know the results. Also if you will for others please post some links to the where you bought the equipment and prices. I can't say with certainty which is better, but I love the idea.
EDIT: I added this version to the front page under modification. Since the mod principles are the same but with a different lubing system, I thought I should add it. I may have to add an addition section on the front page for alternate ideas.
willydigger is offline
post #1055 of 5527 Old 04-22-2011, 09:21 AM
ChaseB
So how does that oil cup work exactly? Just pour oil into it??
1984 CJ-7 Renegade
2005 TJ X (daily driver)
ChaseB is offline
post #1056 of 5527 Old 04-22-2011, 12:00 PM Thread Starter
willydigger
Is the 2004 CPS gear compatible with the 2005-06 gear without modification? NO.
Can the 2004 CPS gear fit with the 2005-06 gear without drilling a new hole in the shaft? YES.
Please see the attached images.
First is the roll pin. The larger is 3/16 and fills the 2005-06 OPDA shaft hole.
Here is a side by side of the 2004 and the 2005-06 gear. Left is the 2005 (large hole).
With regards to all other specs they look the same.
The hole alignment relative to the tooth location is offset a little. This means if you were to pull the OPDA and use this gear it would not install exactly the way it was removed. I don't believe TDC or the sharpie would match exactly. The below pics show the 2004 gear drilled to 3/16. The 2004 gear is on the left.
To modify the old 2004 gear to fit the larger hole for the 2005-06 shaft you will have to drill out one side of the 2004 gear. Use a 3/16 drill bit. It would be best to have a vise and press. I didn't have any of that at the house so I used a steady hand instead.
Drill one side to 3/16. Once you have the hole drilled, place the gear on the shaft so the holes line up. From there you can insert the drill bit and drill the opposite hole. Without a press and vise the shaft hole may egg a little bit. The roll pin should handle a small imperfection in the hole. I ran the drill through and tapped in the roll pin with no issues.
I believe this is an easier method than an aftermarket gear and drilling a new hole through the existing shaft.
post #1057 of 5527 Old 04-22-2011, 01:00 PM
ChuckT6
I'm concerned that the 2004 hole location relative to the gear tooth being 10 degrees or more off than the 2005 hole location could cause problems. Can someone explain what they are and how to correct for this difference? Obviously the cam sensor wheel will be off 10 degrees or more when the OPDA is reinstalled.
Chuck Thomas
2006 Rubicon
ChuckT6 is offline
post #1058 of 5527 Old 04-22-2011, 01:24 PM
Zeep
Yes, you answered your own question. They used to put those on all types of old machinery. You don't see them as often today.
JEEP THE AR-15 OF THE AUTOMOTIVE WORLD
Zeep is offline
post #1059 of 5527 Old 04-22-2011, 03:37 PM Thread Starter
willydigger
I may have misspoke in the earlier post. Just because it doesn't go back exactly doesn't mean it won't work. All that will happen is the housing will be a little off from the original position to keep the alignment between the sensor and the target wheel accurate.
For example if you had the OPDA set at TDC using the plastic key, when you reinstall it using the new gear the OPDA will still be at TDC, but the housing location relative to the engine block will be off the 10.
For the sharpie method, if you make a match mark to the housing/engine and you make a match mark to the housing/target wheel, when you reinstall the match mark for the housing/target wheel will still match, but the housing/engine mark will not.
I mentioned it in my first post so if people weren't paying attention during install it would look odd. Just remember to keep the target wheel and the sensor the same. All you have to do to account for the difference in the gear is move the housing to keep everything aligned.
post #1060 of 5527 Old 04-22-2011, 03:45 PM
ChicagoRod
So with my '05, I should probably jump on the Rock Auto Camshaft Synchronizer for an '04 and steal the gear since my shaft is fine but my gear is worn. Correct?
Rod
05' LJ
ChicagoRod is offline
post #1061 of 5527 Old 04-22-2011, 04:00 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Thanks, Willy. I appreciate the support. I only made 2 changes to your FOGMod. I used a 5/16-18 x 3/8” grub & tapped the other hole to 5/16-24 for the adapter to 1/8 pipe to fit the oil cup threads. I was a little hesitant to tap that hole to 1/8 pipe as it looked like the hole might be too big for the size of that area of the OPDA. That 11/32 bit looks really big! Looking at it now with the hole there, I think the 1/8 pipe might work. I don’t have an extra OPDA so I wanted to be conservative.
I gave the guys (4 of them) at the local industrial hardware store a real challenge. We finally came up with using a 1/8 compression to 1/8 pipe thread adapter to get what I needed. The threads on the 1/8 comp. fitting are 5/16-24. That end goes into the OPDA. It is not a taper thread so it won’t self-seal. For now, I have an O ring there until I see how this is going to work. I also drilled out the fitting some because the hole was small & this is only a gravity fed system.
The cost of the parts was $12. The oil cup w/1/8 pipe male threads, a 1/8 to 1/8 coupler, the 1/8 comp. to 1/8 pipe male thread adapter & an O-ring plus the grub. I didn't end up needing the nipple seen in the invoice photo below.
The cap on the oil cup is spring loaded. Opening the cap allows oil to be added. My main concern with this method is how much oil will be consumed. I guess it depends on how well the seal holds the oil. I didn’t want a bigger cup (they make them) because I wanted the oil level to stay below the top of the top bushing. The oil cup might be the hardest part to find. Some call them “GITS” cups. I got the parts at McFadden-Dale Industrial Hardware in Anaheim, Ca. They have others around the country. The Anaheim # is 714-630-6390.
I agree. I also wonder about mating a new gear to a worn cam gear. If the wear isn’t great (deep) is it better to keep the mated surfaces together rather than changing one. Of course both new is ideal but certainly a lot costlier.
Willy, Good info on the ’04 gear. Is the height of the hole the same, meaning is the end play the same when the gear is installed?
As far as the position being different, that is a case for using the TDC & pinning the wheel procedure. I think that anytime the gear is replaced it is best to pin the wheel. That is why I pinned mine as well as marking it. On removal, I had no idea whether the gear needed replacing.
When the OPDA goes back in with the wheel pinned, the proper relationship to the CPS is maintained. The position of the OPDA to the engine may change but that is unimportant.
Since there are 13 teeth on the gear, & mine was re-drilled at 90o, I’m sure the OPDA had to be turned slightly on re-installation.
Willy, sorry, you added while I was typing. You are right, it's the wheel-to -housing position that matters. Pinning or marking. Maybe less confusing with the pin???
Rubi4MyMrs is offline
post #1062 of 5527 Old 04-22-2011, 04:10 PM Thread Starter
willydigger
The height of the hole is the same. The 2004 and 2005 looked to have the same up/down play.
Rubi, what type of oil do you plan to try?
post #1063 of 5527 Old 04-22-2011, 04:27 PM
Peterpsc
That oil cup is clever. Thank you for the effort. I did the fogmod but darn if I don't like the oil-cup idea. Has it leaked?
Peterpsc is offline
post #1064 of 5527 Old 04-22-2011, 04:44 PM
Baseplate
I purchased an 2005 OPDA gear off my Chrysler dealer in Australia
PART #: KCDC0E051AB
DESCRIPTION: GEAR, OIL PUMP-05 TJ
I'll see if Bobby at Mopar-Wholesale has or can get these.
Baseplate is offline
post #1065 of 5527 Old 04-22-2011, 04:55 PM
Baseplate
Email sent to MW
Hi Bobby
As you probably have worked out, there are some issues with the Oil Pump Drive on 05 and 06 Jeep Wranglers (TJ).....the part is still faulty but we all know that.
There are two issues we are all having with the part:
1. The upper bushing on the drive assembly does not seem to get oiled adequately and it binds up, this impacts on issue two..
2. The drive gear on the bottom of the part meshes with the gear on the cam - this gear (on the cam and the OPDA) is wearing excessively.
One solution is for us to keep buying the complete assembly but another is for us to buy the OPDA gear as well and replace them frequently.
Is it possible for you guys to stock the gear please - I know you would sell plenty of them - I for one would order around 5 myself.
Here are the details of the part:
PART #: KCDC0E051AB
Thanks Alex.
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
