2005-06 Jeep OPDA_CPS_Distributor Failure - Page 7 - JeepForum.com
 10Likes
post #91 of 5534 Old 01-21-2011, 10:11 AM
Zetto
Zetto's Avatar
Originally Posted by willydigger View Post
I made this thread so everything was consolidated on the first page. Any extra info from members is welcomed and encouraged.
All I can say is come on nice weather so I can make a "how to pull your OPDA without issue" video. I'm glad you got it worked out.
willydigger, based on the pictures I supplied does the wear seam severe enough to need to be replaced ASAP?
Since the OPDA are back ordered 261 units as of yesterday I do not see one becoming available soon. For the time being I plan to replace the gear and install the FogMod. I just need to dedicate a Saturday to do it.
Zetto is offline
post #92 of 5534 Old 01-21-2011, 10:56 AM Thread Starter
willydigger
There will be wear. You'll have to decide what you're comfortable with. Based on the images I'd say it's not too bad, but it's definitely more than it should be. Can you do the FOGMod on the unit you have?
If not get some oil into the top bushing to buy some time. Change your oil to a higher ZDDP if you haven't already to prevent more damage.
willydigger is offline
post #93 of 5534 Old 01-21-2011, 11:29 AM
steitsma
"how to pull your OPDA without issue" video would be a great thing!!! Please advise when you have one available!
steitsma is offline
post #94 of 5534 Old 01-21-2011, 12:16 PM Thread Starter
willydigger
It will be 25F in Baltimore tomorrow. I might try to do a quicky, but it might be hard to hear with my teeth chattering.
post #95 of 5534 Old 01-21-2011, 12:38 PM
ChaseB
I wouldn't wish that on anyone! It's not pulling it that has me confused, it's putting the new one in after I have the old one out
1984 CJ-7 Renegade
2005 TJ X (daily driver)
ChaseB is offline
post #96 of 5534 Old 01-21-2011, 12:48 PM Thread Starter
willydigger
That's just as easy, but admittedly, a little worrisome. I had the same feeling when changing mine out. I marked, double marked, and triple marked it. I took pictures and did the panic dance. Then I put in the new one and it went in on the first try. Sometimes I worry myself out of doing things. It's the same reason I waited so long to do gears.
post #97 of 5534 Old 01-21-2011, 01:18 PM
Zetto
Zetto's Avatar
Hi willydigger,
I am going to try replacing the gear and install the FOGMod this weekend if I can find the gear locally (Any ideas where I might find it in? I understand Napa has a gear and the dealer may also have a gear/repair kit). When I first heard of the issue back in June I switched to Mobil 1 HM 10w30 with a K&N Gold filter that I have been changing every 3,000mi.
Zetto is offline
post #98 of 5534 Old 01-21-2011, 01:51 PM Thread Starter
willydigger
Hi willydigger,
I didn't use an aftermarket gear. From what I've read on the boards it is troublesome. Unless you are pretty good with machining (matching holes, drilling straight, getting things right the first time) I would suggest avoiding it. Maybe someone who has done it can offer some advice. You can do the FOGMod and keep the existing gear. When new OPDA's become available get one as a back up. Protecting the upper bushing is key. With the amount of damage on your existing gear you may be fine.
All that said, please take some photos of your OPDA shaft specifically the upper bushing area. I'd like to get more "used" images for the thread for reference. You can post them to photobucket or email me and I'll post them up. Good luck.
post #99 of 5534 Old 01-21-2011, 03:48 PM Thread Starter
willydigger
I'm working on downloading a video now. It went well. I haven't seen it to know how it looks but at the very least it will get people headed in the right direction. There was an issue with reinsertion and the oil pump not lining up. It's better that way, so people can see what can go wrong. Unfortunately it caused a 10 minute delay which ate up my daylight. Once it gets done loading I'll try to put it on Youtube and link it here. It was freezing out.
Edit: Converting to movie is extremely slow.
post #100 of 5534 Old 01-21-2011, 04:02 PM
ChaseB
Awesome! The video in addition to the pictured instructions will be very helpful!
1984 CJ-7 Renegade
ChaseB is offline
post #101 of 5534 Old 01-21-2011, 04:11 PM
Jeffro06
Jeffro06's Avatar
I had my OPDA checked at the dealer today, and it was determined it needed to be replaced, but was caught in the early stages. I was told I'll have to pay no more than 50% of the cost. If Chrysler doesn't ask for the original one back the dealer said they'd give it to me.
Still no more chirpping. If you have an '05 or and '06 I'd strongly suggest doing the switch to synthetic Mobil 1 TDT 5W-40 asap, especially if you live where it gets eskimo cold.
Jeffro06 is offline
post #102 of 5534 Old 01-21-2011, 04:22 PM
TJXTWO
I assume this is because of the higher ZDDP levels? I am running Mobil 1 10-30 full synthetic and adding ZDDP to the oil. Is there another reason to run the TD oil?
03 TJ Sport, 4.5" RE SuperFlex short arm lift, Tereflfex ST swaybar, 33" MTR's, Body Armor bumpers @ sliders, 5 speed manual... 06 TJ Rubicon, 4.5" RE long arm lift, Currie Antirock front and rear , OR Fab bumpers @ sliders, K@N intake, custom exhaust, 1" BL , 1" motor mount lift, 35" MTR's on Pro Comp Alloys, 6 speed manual.
TJXTWO is offline
post #103 of 5534 Old 01-21-2011, 04:26 PM Thread Starter
willydigger
Do they have one? How much is 50% of the cost? You'll still have to modify it otherwise it will eventually fail again.
post #104 of 5534 Old 01-21-2011, 04:31 PM
TJXTWO
The video should be helpful Willy. Your a trooper to be out there in freezing weather doing that.
TJXTWO is offline
post #105 of 5534 Old 01-21-2011, 04:36 PM
Jeffro06
Jeffro06's Avatar
Modifying the replacement, before they install it, won't be possible. The dealer has to install it, I have to pay for it, then I get reimbursed. Not the best scenario, but if I get the original back, modification of both could be possible.
I was told the part is available, but I guess I'll know when it's in when they call me. I was told there was very little signs of wear, and the cam looked fine. I wasn't there to look at it, but I trust the shop.
I wasn't given an exact dollar amount, in fact the guy handling the claim wouldn't even give me a dollar amount, just that I should have to pay anymore than 50%. The dealer told me I shouldn't have to pay anymore than $100. I believe the dealer has the ability to help customers as with these things too, and I don't know if they are or not, didn't ask either.
Being as how my part chirpped just a couple of times before I changed the oil, and hasn't since I think, and the dealer thinks, I caught it very early.
One thing is for certain, I'm sticking with Mobil 1, despite it's price.
Jeffro06 is offline
jbrubi05
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
