2005-06 Jeep OPDA_CPS_Distributor Failure - Page 63 - JeepForum.com
 7Likes
post #931 of 5511 Old 03-31-2011, 10:27 AM
chutta
They've been coached to deny to save Chrysler's ***
05x 4.0 6sp 30/35, aussie front, 3.73's, r/c 4"x lift, adv adptr sye, shifter bracket, tw cv ds, 33 t/c skid, 33x12.5 dunlop mud rovers on steelies, psc sport cage/rockers, warn fr bump/steer and 30 diff skid, sirius,cb, hand throttle 1"bl/mml 265/16's pepboys at's on orig moabs for street. Lowrance H20c for gps
chutta is offline
post #932 of 5511 Old 03-31-2011, 10:32 AM Thread Starter
willydigger
Originally Posted by PA_LJ View Post
Kia will be looking at my heep on Monday. My local dodge dealership has no clue what I'm talking about and their database shows national backorder for parts. They could not find info about affected 06 model years either.
Good luck to anyone trying to get this fixed...no one seems to have any clue when u start asking questions.
Dodge-wholesale.com has them in stock with gasket for $253. I assume your deductible for the dealer is $100 so you might not want to go through dodge-wholesale unless you have to.
There is no info to find regarding 2006 models. There is no recall or TSB regarding the OPDA. All they need to have is the part in stock. My dealer in Baltimore also tried the "not covered under warranty" for my 7yr/70K, until I questioned the logic. Be prepared for that fight.
Once you get the OPDA replaced seriously consider the FogMOD to protect the upper bushing. I would also highly recommend you changed to a higher ZDDP oil like the valvoline VR1 or Mobil 1 TDT.
willydigger is offline
post #933 of 5511 Old 03-31-2011, 11:10 AM
PA_LJ
I spoke directly with Dodge-wholesale who quoted me 370 bucks for the OPDA without gasket. Just FYI. Guy there also couldn't explain the price increase.
Guy at Dodge-wholesale had matching part numbers to whats in this thread.
Local DCJ dealer came back with part numbers : Drive Gear - CDC0E051AB (OPDA repair kit? includes gear, roll pin, crush washer, plastic bushing?) and Cam Shaft Assembly (he called this OPDA) CDC0E052AB (revised) for 280.00. When I gave him the part numbers from Dodge-wholesale he acted dumbfounded. EDIT Neither of these part numbers are available. Both on National Backorder. /EDIT
Wanna do the fog mod for me? I am not very inclined to modify an internal component with my minimal mechanical abilities.
PA_LJ is offline
post #934 of 5511 Old 03-31-2011, 11:15 AM Thread Starter
willydigger
The website says $253. I usually deal with Bobby. If it really is $370, pull it and clean it and wait for the dealer to handle it.
Bobby
RT Partsco
1-888-956-6727
The price increase is gouging from Chrysler.
http://dodge-wholesale.com/catalog/p...944dd10dd99e76
post #935 of 5511 Old 03-31-2011, 12:38 PM Thread Starter
willydigger
Bobby
RT Partsco
1-888-956-6727
I emailed Bobby regarding the cost:
List price is $377
Our price is $253.12
Thank You
Bobby
RT Partsco
1-888-956-6727
post #936 of 5511 Old 03-31-2011, 12:53 PM Thread Starter
willydigger
Those PN's match the old repair kit that Chrysler was offering. This was posted way back in the first thread. I didn't think it was made anymore. The PN for the OPDA is 53010624AC. It may be listed as distributor or camshaft position sensor.
http://www.jeepforum.com/forum/f9/ch...ml#post9912225
Below is a link to an early spreadsheet highlighting the info they/we collected early on.
https://spreadsheets.google.com/pub?...=0&output=html
post #937 of 5511 Old 03-31-2011, 01:21 PM
anderson5290
here are some pics of my opda that failed at only 44,500 miles.
let me know if the wear looks bad it does to me
anderson5290 is offline
post #938 of 5511 Old 03-31-2011, 01:35 PM
Shakey
I have a 2005, 82,000 miles, and have never had any strange sounds like people describe in this thread. As a result, it's unlikely I'll pull the assembly and check for wear.
What is the likely damage if it fails? If it's just cam, lifters and OPDA, I can live with that because at that point I'll be really close to 100,000 miles and ready for an engine build involving upgraded parts.
And not that I don't believe this is a problem, but I assume there were approximately 200,000 Wranglers made in 2005-2006. At this point, many of those models are nearing 100,000 miles (like mine). Does anyone have any numbers showing actual OPDA failures?
Edit: I re-read the original TSB and noticed it referenced only 16,000 Jeeps impacted by the issue. Is there any reason to believe the problem goes beyond those 16,000 identified for the TSB?
Shakey is offline
post #939 of 5511 Old 03-31-2011, 01:39 PM
mattwings
I just ordered on from RT partsco. I have not pulled mine yet, but have 60 k miles so assume it is on it's way out. Is the fogMod proving to work? I would be hesitant to try it myself, as I have a limited shop at home, but would take the offer to do it for me if the mod is working
mattwings is offline
post #940 of 5511 Old 03-31-2011, 02:02 PM Thread Starter
willydigger
The mod is in the early stages and there is no guarantee that it will prevent the gear wear. What it will do is reduce friction on the upper bushing that should help prolong and potentially eliminate the binding issue (which in turn should reduce wear on the gear by proxy). tkki, Fog, and myself have had good results with upper bushing and shaft wear.
What did you pay from dodge-wholesale/RT Partsco?
post #941 of 5511 Old 03-31-2011, 02:54 PM
tkki1230
Here's what I know for sure-the top bushing will run out of lubrication sooner or later. That's a fact. It's not a matter of if. The design of the unit sucks.
I'm not saying that the unit will fail. I'm saying that it will get to the point where that shaft is spinning metal on metal after the factory grease runs out. Whether or not the unit actually fails when that happens is another question.
As for me, I'm so anal, just knowing that a ticking time bomb waiting to go off is attached to my TJ gives me stress. Just doing the modifications gives me some peace of mind. Not much, but a little.
tkki1230 is offline
post #942 of 5511 Old 03-31-2011, 03:01 PM
Baseplate
My OPDA is on its way from Mopar-Wholesale
Part Number Part Description Quantity Price Total
J3181288 SEAL DISTRIBUTOR 1 $1.90 $1.90
53010624AC DISTRIBTR OIL PUMP 1 $253.12 $253.12
This will be the first FOGMOD OPDA in Australia!
Baseplate is offline
post #943 of 5511 Old 03-31-2011, 04:35 PM
Zeep
If your perfectly willing to accept blown 4.0 at 100k, thats fine. I believe the majority of people on this forum, were expecting at least twice that amount. The 4.0 has a rock-solid dependability record, that is now being flawed by one single component (OPDA), that Chrysler changed out in the last 2 yrs of production.
You may not be aware that if your cam, lifters, OPDA, oil pump are wiped out, the resulting sraptnel in your engine, will make a rebuild next to impossible! Both mechanically or economically.
JEEP THE AR-15 OF THE AUTOMOTIVE WORLD
Zeep is offline
post #944 of 5511 Old 03-31-2011, 04:48 PM
mattwings
I think the zinc/phosphorous additive issue is partially to blame for the camshaft and oil pump gear issue as well. It is well documented that older, flat tappet engines do not do well without the additive. There a a very few "off road only"' oils that maintain high levelsmof Zinc/Phosphorous as detailed in other threads on his forum. I am going to run Valvoline high milegemsynthetic which, based onnthe info I have found, contains almost the same levels of additive oldermoils contained. Mobil 1 synthetic high mileage appears to be similar as well.
post #945 of 5511 Old 03-31-2011, 05:47 PM
mhcurlee
Just put in a bottle of inexpensive STP oil treatment. It has a lot of ZDDP
mhcurlee is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
