2005-06 Jeep OPDA_CPS_Distributor Failure - Page 61 - JeepForum.com
 6Likes
post #901 of 5484 Old 03-28-2011, 10:48 AM
Peterpsc
Have we confirmed the new batch of OPDAs have not been modified in some way (improved)? According to my local dealer, the part number for the OPDA has changed although I don't know if that alone indicates a modification in the part (OPDA).
Peterpsc is offline
post #902 of 5484 Old 03-28-2011, 11:08 AM
meatlord
meatlord's Avatar
Mine ships tomorrow, Ill post some pics when I get it. I will also be modding it.
05 Rubicon "Big Stupid" / 99 XJ on 31s "Nurple" FOR SALE. / 07 WK Limited CRD GDE Hot Tuned DPF delete. / 00 TJ "One Shot Wonder"/ 03 Nissan SE-R 6 speed V spec. / 00 Suzuki DR650.
meatlord is offline
post #903 of 5484 Old 03-28-2011, 12:58 PM
tkki1230
Originally Posted by willydigger View Post
For those of you who have done the FogMOD, have you used any grease besides the Aeroshell? If so do you have any comments on the outcome?
I've run Mobil 222 xhp special, and Mobil 28. The 222 is like the Aeroshell, where the shaft discolored. The 28 is a higher temp grease, but no moly. That one seems to be okay-it has a much higher temp range. There was no reason behind running those 2 greases. I ran them because they were are what we use in our shop in our machinery.
tkki1230 is offline
post #904 of 5484 Old 03-28-2011, 08:40 PM
pumpman55
after i removed the opda i removed the cap from the side and noticed it is not grease it is fiber with oil in it. is the oil suppose to be aborbed into the bushing from the outside diameter of the bushing?
pumpman55 is offline
post #905 of 5484 Old 03-28-2011, 11:48 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
This was while you were doing the FOGMod, right? Wasn’t the top bushing dry on the inside surface? How the lubricant is supposed to get from the reservoir to the inside is the great mystery. From willydigger’s first post you can see that it is normally dry & hard grease. Various greases have been tried & I don’t think there has been a clear winner. dproctor0715 is trying oil. At this point I think anything beats the factory setup.
Lope tried removing the seal. Not sure what the final results are. Of course with the FOGMod you want the seal in place.
Rubi4MyMrs is offline
post #906 of 5484 Old 03-29-2011, 11:28 AM
ChaseB
So no change to the new batch of OPDAs huh? Well it's up to Crown I guess, hope they come through!! Can't believe they increased the price that much....should be illegal
1984 CJ-7 Renegade
2005 TJ X (daily driver)
ChaseB is offline
post #907 of 5484 Old 03-29-2011, 03:32 PM Thread Starter
willydigger
I just received an email from dodge-wholesale saying the OPDA was in stock at $253.12. I sent an email asking about differences. I'm not certain they are the same, but if they were different I think he would have mentioned it. I'm not very optimistic.
willydigger is offline
post #908 of 5484 Old 03-29-2011, 04:12 PM
anderson5290
so i know for sure that the opdas that are back ordered are still the same 53010624ac mine has about 7 miles on it so its brand new
anderson5290 is offline
post #909 of 5484 Old 03-29-2011, 05:16 PM
TJXTWO
I just got an e-mail from dodge wholesale as well saying the opda was in. I called and left a message for them to call me. Hopefully I will get a call back tommorow.
03 TJ Sport, 4.5" RE SuperFlex short arm lift, Tereflfex ST swaybar, 33" MTR's, Body Armor bumpers @ sliders, 5 speed manual... 06 TJ Rubicon, 4.5" RE long arm lift, Currie Antirock front and rear , OR Fab bumpers @ sliders, K@N intake, custom exhaust, 1" BL , 1" motor mount lift, 35" MTR's on Pro Comp Alloys, 6 speed manual.
TJXTWO is offline
post #910 of 5484 Old 03-29-2011, 05:27 PM
ff33
^^ got my email today too, guy I talked to on the phone said they still haven't received them but they should be arriving in the next couple of days and then they will ship them out. Also if you ordered before the gasket starting coming with them just ask them about it and they will make sure it is included.
2006 Rubicon LJ, auto, 2" lift, 1.25 bl, mml, tt, armor, winch, 33's, that's it for now.
ff33 is offline
post #911 of 5484 Old 03-29-2011, 06:22 PM Thread Starter
willydigger
From Dodge-wholesale when asking about any changes. I also asked him to take a photo. See below.
Nothing I can see that they did any changes on it. Same part #, only thing seemed to change was the cost
post #912 of 5484 Old 03-30-2011, 03:24 PM
TJXTWO
I can't seem to get through on the phone, and they have not returned my call from yesterday. I am going to try and respond to them via return e-mail and ask them to ship the part. Anyone else use a return e-mail to order the part?
Edit: Nevermind, got through on the phone finally...
TJXTWO is offline
post #913 of 5484 Old 03-30-2011, 05:17 PM
ChaseB
Same FAIL part
1984 CJ-7 Renegade
ChaseB is offline
post #914 of 5484 Old 03-30-2011, 06:16 PM
PA_LJ
30k miles and I've got th laughing monkey as of 2 hours ago....
PA_LJ is offline
post #915 of 5484 Old 03-30-2011, 06:51 PM
rottenrobert
When my brother and I did the FOGMOD to mine it had oil all the way up the shaft. Past the seal and even reaching the target wheel. It spun free in housing too. BUT there was scorching on the shaft for the lower bushing. So we used a grinding wheel on the thrust washer. So now hopefully more oil gets to the lower bushing.
rottenrobert is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 03:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 09:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 04:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 11:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 08:25 PM
