2005-06 Jeep OPDA_CPS_Distributor Failure - Page 53 - JeepForum.com
 10Likes
post #781 of 5527 Old 03-12-2011, 01:35 PM
Zetto
Zetto's Avatar
Originally Posted by willydigger View Post
Everything is covered in the first page. M1 turbo diesel truck 5w40. There is valvoline vr1 too.
My local Walmart has the 4qt jugs of Mobil 1 Turbo Diesel Truck 5W-40 for $23.
Zetto is offline
post #782 of 5527 Old 03-12-2011, 06:09 PM
xxxxxMCAD135
Dont have a problem with this. Checked the history on my TJ after I bought it and after 30k miles it still looks new. Talked to the techs at work that said they remembered the recall and mine looks taken care of with no problems. Some slight wear on two of the blades but nothing out of the ordinary.
xxxxxMCAD135 is offline
post #783 of 5527 Old 03-12-2011, 10:08 PM Thread Starter
willydigger
Have you looked at the gear personally? I wonder if the gear was replaced. They drill a new hole in the shaft. Please don't take offense, but I would not rely on a Chrysler tech to tell me anything truthful or helpful.
willydigger is offline
post #784 of 5527 Old 03-12-2011, 10:45 PM
BNLfan
Originally Posted by Zetto View Post
The units will carry the same part number as before and my contact says no changes have been made.
Well, crap. I was being optimistic the increase in price was because they fixed the problem. Now I'm wondering which would be better:
(A) order a new one and do the FOGMOD on it, so it's a brand new gear.
(B) pull mine out and do the FOGMOD on it; if I screw it up then order a new one.
In either option, I'm going to pull it out every oil change and see how it's wearing and replace when fully striated.
I just changed the oil tonight to Rotella 5W-40 synthetic. I found some gallon jugs at AutoZone that still had the old CI-4, SL rating. (1300 ppm zddp). I still need to order the grease, though.
BNLfan is offline
post #785 of 5527 Old 03-13-2011, 06:53 AM Thread Starter
willydigger
How bad is the old one? With the price of the new on (granted it's still cheaper than a new motor) if the old one isn't bad (minor gear wear, NO resistance in the shaft spinning) then do the mod on that one. A lot of guys like having a spare, and that is a good practice, but it is possible to make an existing OPDA last longer. If it is true that the new OPDA is the same and you decide to purchase it, I would absolutely modify it.
post #786 of 5527 Old 03-13-2011, 07:02 AM Thread Starter
willydigger
Another bit of info.
I've been getting a few PMs about squeals in cold weather. When my OPDA began squealing it was in late August. It squealed for a few weeks before I tracked it down and found the info on the boards. In August the temps in MD were 80-100F. That said in the winter and cold time months, I have all sorts of noises. I get Angry Sparrows in the drive shafts, my radiator fan knocks, I have the traditional 4.0 valve tick, and on occasion I have the high pitched belt squeal. These are what I consider Jeep noises. It's what the radio is for.
Relating to the OPDA squeal. I think the Laughing Monkey is the tell tale noise for the OPDA. The noise will be on start up only and will not be weather related. It can last for a few seconds or for a minute or two. It will eventually stop after the motor heats up a bit (assuming it allows stuff to expand and reduce friction). The OPDA will still squeal in the summer.
I hope that helps.
post #787 of 5527 Old 03-13-2011, 08:11 AM
BNLfan
I washed the jeep one day and took it for a spin and heard this high-pitched squeal. Figured it was just the belt got wet from the hose and it went away after I got to speed, and haven't heard it again. Then stumbled across this forum and you guys and my heart sank. Pulled it out and it's worn, but not bad like some of the other pics we've seen.
But in any case, here's a heart-felt thanks to you and The Fog and everybody else who has contributed to the knowledge pool on this one. You guys have been a great help on this one to me and I'm sure a lot of other lurkers on the forum.
BNLfan is offline
post #788 of 5527 Old 03-14-2011, 05:15 PM Thread Starter
willydigger
I pulled my OPDA after changing the oil. I'll post some pics up later. The bottom shaft looked good. It had oil, but I have a groove. The scoring didn't advance beyond the pic at 500 miles. The upper bushing was okay. The Aeroshell is much better than the Mobil 220. It didn't clean up as well as I'd hoped. The gear teeth looked a bit worse so I think it may be the normal wear.
Here is the gear. The wear spots are small, but larger than before.
Here is the bottom shaft. There is scoring, but it's not bad.
Here is the upper. It is dark, but the grease is wet.
Notice the really dark spot below. This did not wipe away clean. My batteries died on the camera so I didn't get a shot. The entire upper wiped away clean except for the dark spot.
It didn't feel weird. The bushings looked good with minor wear. I would expect the wear on metal to metal contact. Overall the OPDA was in good shaft. The mileage is 69K, 2000 more than the first pics. Below are the before images for easy comparison.
Actually now that I look at the before pics, the gear teeth look the same. The shaft cleaned up nice and shiny like the before pics. I'm disappointed because I wanted to Aeroshell to wipe away with no marks. While it was much better than the 220, it wasn't perfect. Now my experiment is to put a little less grease in. I was pumping it until it got hard to pump. Maybe it was too much grease.
tkki, when you pulled yours did it have any discoloration?
post #789 of 5527 Old 03-14-2011, 06:22 PM
xxxxxMCAD135
Im a Chrysler tech, thanks.
Anyway, yes I looked it at and it looked brand new. The TJ has 30k miles on it and its only been serviced with us. No history of replacement and I know for a fact the old lady that owned it before me didnt do it herself.
post #790 of 5527 Old 03-14-2011, 07:45 PM
tkki1230
Yes, it did get darker, but not as bad as yours. I'm trying Mobil 28 on the latest test, to see if it does better than the Aeroshell. I should be pulling my unit out in a couple of weeks to see how it did.
tkki1230 is offline
post #791 of 5527 Old 03-14-2011, 08:15 PM
solarpower
that gear looks real nice willy. the bad thing is that actual pre-mature wear probably won't be obvious until around 15- 20k I would bet...unless the cam is already tore up.
Great pics
04 TJ "U" package
06 XK Commaddy 4.7
solarpower is offline
post #792 of 5527 Old 03-15-2011, 11:50 AM
westx
is chrysler even trying to fix the problem? i know crown is looking into it but wasnt sure if chrysler was doing anything.
westx is offline
post #793 of 5527 Old 03-15-2011, 11:53 AM
Fropleyqk
Fropleyqk's Avatar
Why would they? Nothing is forcing them to. Its an outdated motor and everyones warranties are expired or expiring. Chrystler doesnt care. Dont believe me? Give em a call and see how they treat you.
Fropleyqk is offline
post #794 of 5527 Old 03-15-2011, 12:11 PM
westx
well that sucks, hopefully we get a fix somewhere.
westx is offline
post #795 of 5527 Old 03-15-2011, 12:19 PM
Bigbob
Bigbob's Avatar
is Chrysler even trying to fix the problem? i know crown is looking into it but wasn't sure if Chrysler was doing anything.
Unfortunately there are a couple issues here. The company that built your Jeep, Chrysler LLC, designed the part and obviously it has flaws. The current company that sells the Jeep line, Chrysler Group, never built a 4.0 engine or a OPDA thingie. And I know the old Chrysler LLC, now called Old Carco, was famous for not fixing flawed stuff they sold.
Originally Posted by Fropleyqk View Post
Why would they? Nothing is forcing them to. Its an outdated motor and everyone's warranties are expired or expiring. Chrysler doesn't care. Don't believe me? Give em a call and see how they treat you.
Yup, it is an outdated deal and there are a very small number of them around anyway. A much lower number still on warranty. I sure don't see them working overtime to design a better mouse trap. But in a sense I am impressed they are trying to get a supplier to build replacements for these. Hey, it's a part they never built or sold!
Customer loyalty and service has never been Chrysler's big ticket item. I have always liked their products and will continue to buy them, but I know I'll never get great customer service.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
