2005-06 Jeep OPDA_CPS_Distributor Failure - Page 52 - JeepForum.com
 6Likes
post #766 of 5484 Old 03-10-2011, 01:14 PM
westx
i just wish i had known about this issue a few days ago, i just got my 06 and couldnt be happier until i found out about this. wish i could take it back.
if its a known issue they shouldnt be selling me a jeep with defects. i got it from a jeep dealership, i figure they should have some info on this.
westx is offline
post #767 of 5484 Old 03-10-2011, 01:47 PM
JeepScrap
Think they care if your Jeep breaks down? Its all about the almighty buck. Besides, car dealers are the biggest scum bags on the planet.
Don't worry about it man. Order an opda so you have one on hand and just drive the Jeep and have fun. I was super stressed about this issue when I bought my Jeep back in November as well but I've come to grips with it. Just check it periodically and replace as necessary. I'm sure someone will eventually put out an aftermarket opda that fixes it for good.
Sent from my Droid using JeepForum
"Science will win in a battle with religion because it works." -Stephen Hawking
JeepScrap is offline
post #768 of 5484 Old 03-10-2011, 01:49 PM
westx
thanks for the advice, i love this thing already so its a little hard to hear any bad news about the jeep, hope a permanent fix comes soon for all of us.
westx is offline
post #769 of 5484 Old 03-10-2011, 02:29 PM
pizzle
pizzle's Avatar
I have one that doesn't have the gear on it, since we took that gear off and used it on my original OPDA that we Fog-modded. Willydigger modded it with/for me.
I would absolutely need to get the OPDA unit back from him when he's done however, since the supplier has decided to screw us over on the price of these things!
Send me a PM with his contact info and I'll see what his thoughts are on using my OPDA.
Originally Posted by JBD View Post
Adam from Crown is looking for an OPDA to use in his research. Anyone have one?
pizzle is offline
post #770 of 5484 Old 03-10-2011, 02:36 PM
TotallyScrewed
Problem with Filter Mag??
1) This is a poled magnet that fits around the oil filter. There is no way to determine its effectiveness, unless you have a see-through oil filter and clear oil.
2) Because it is a poled magnet, only two places will have high flux concentration. Remember the horseshoe magnet and iron filings demonstration. Only a relatively small portion of the thing (I'm guessing <10% of the surface area) could possibly attract and hold magnetic particles.
3) The oil is thick and the particles are likely to be irregular in shape and size. Only the big particles will have enough mass to be attracted. Only the really close to the magnetic poles particles will have enough attraction to move through the oil, against the normal flow of oil and then remain attached to the wall of the oil filter.
4) A properly maintain oil filter, that is changed at the proper intervals, will trap the larger particles. So they won't be in the fluid for long anyway.
5) The small particles aren't a big problem.
TotallyScrewed is offline
post #771 of 5484 Old 03-10-2011, 03:07 PM
ChaseB
at 80 bucks it's pretty expensive. I have seen demonstrations where people have cut open the filter and there was a metallic film held in place by the magnet.....not sure how beneficial trapping liquid metal would be
1984 CJ-7 Renegade
2005 TJ X (daily driver)
ChaseB is offline
post #772 of 5484 Old 03-10-2011, 03:12 PM Thread Starter
willydigger
I think Adam has one already.
willydigger is offline
post #773 of 5484 Old 03-11-2011, 12:31 PM
Zetto
Zetto's Avatar
I have good news and bad news. I received an update from my contact at Chrysler this week. According to them the OPDA supplier is going to be shipping at least ~300 units to dealers this month. These units are for vehicles that are sitting on dealer lots and for customers that have placed an order. They said there is a potential that the supplier could ship up to 5,000 units by the end of the month.
The units will carry the same part number as before and my contact says no changes have been made.
According to my contact the increase in price is likely due to a new supplier/contract (I know LDI is still in business but they may have gone elsewhere for the order).
I highly recommend anyone who purchases the unit take Chrysler to small claims court due to the increase in cost. Additionally, if your vehicle has sustained additional damage or you have been left without a vehicle while the unit was back ordered you should seek additional damages. It is a simple process to file a claim and unlikely that they will show.
Zetto is offline
post #774 of 5484 Old 03-11-2011, 03:30 PM
chutta
I just re-inspected my OPDA again today. The gear is showing more wear, approx 1/2 across teeth, internal gear seems to be same as a month ago.
I did notice(first time disassembling the part) that oil was in fact up under the wheel, the black washer being wet and oil at the base of the outside of the bushing.
Looks to me that in fact the top bushing is getting lubed. I did measure a groove on the shaft where the bottom edge of the top bushing rides of .002", body of shaft being .528"
I don't think this is due the top bushing being dry, otherwise why the oil up top?
05x 4.0 6sp 30/35, aussie front, 3.73's, r/c 4"x lift, adv adptr sye, shifter bracket, tw cv ds, 33 t/c skid, 33x12.5 dunlop mud rovers on steelies, psc sport cage/rockers, warn fr bump/steer and 30 diff skid, sirius,cb, hand throttle 1"bl/mml 265/16's pepboys at's on orig moabs for street. Lowrance H20c for gps
chutta is offline
post #775 of 5484 Old 03-11-2011, 03:37 PM Thread Starter
willydigger
If you haven't grooved the shaft it must be a seal failure. There is no way the upper bushing is getting oil with the current seal placement. Could it have seeped up during disassembly?
What is the miles differential between the first and second inspection? Can you give us pics of the new wear?
post #776 of 5484 Old 03-11-2011, 06:17 PM
chutta
I have to say, I did not see a seal internal at the base of the upper bushing. While I was not specifically looking for it, cleaning out with q-tips and insp with a led, nothing was obvious. Being unemp and bored along with fixating on this, hearing noises on coasting to stops I need to stay on top of it.
Maybe 700-900 miles between inspections tops.
I did take pix this time, just haven't loaded yet.
chutta is offline
post #777 of 5484 Old 03-12-2011, 07:50 AM
Zeep
Originally Posted by ChaseB View Post
Not directly related to the OPDA, but I was thinking about trying one of these filter magnets. There have been other threads on this product. If the OPDA and cam gear are wearing, perhaps this could serve as added protection in trapping some of the metal particles that are too small for the oil filter to catch.
No need to spend that much on a magnet! For years i've been using magnets that I retreived from magnatron tubes, in disguarded microwaves.
You can get 2 very strong magnets from each one. I simply RTV one on the end of the oil filter, cut off on the next oil change, and reuse.
I would post pic's, but my camera is down.
P.S. Sorry for the hijack.
JEEP THE AR-15 OF THE AUTOMOTIVE WORLD
Zeep is offline
post #778 of 5484 Old 03-12-2011, 08:33 AM
grogie
M-F: Cell Block #4533
grogie's Avatar
Isn't that just great of Chrysler and it's supplier to produce the same defective part.
And to think my wife wants a WK2.
Red Jeep Club #345
2006 TJ Sport -
2004 KJ Limited
2013 Off-Road Trailer -
from the onslaught of young idealists. -- Don Colacho
grogie is offline
post #779 of 5484 Old 03-12-2011, 11:44 AM
westx
i need to do the oil change today, what oil should i use? i remember reading something about diesel engine oil, but not sure if thats right.
westx is offline
post #780 of 5484 Old 03-12-2011, 12:40 PM Thread Starter
willydigger
Everything is covered in the first page. M1 turbo diesel truck 5w40. There is valvoline vr1 too.
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 03:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 09:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 04:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 11:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 08:25 PM
