2005-06 Jeep OPDA_CPS_Distributor Failure - Page 51 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 2005-06 Jeep OPDA_CPS_Distributor Failure
1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,Zone Offroad Body and Suspension Lift Kits, Brackets, Disc
Unread 03-08-2011, 09:16 PM   #751
jkp
There are six sets of notches in the target wheel. Each set corresponds to the opening of one of the intake valves and is used by the computer to fire the injector for that cylinder.
'92 Islander
'06 Rubicon
jkp is offline   Reply With Quote Quick reply to this message
Unread 03-08-2011, 09:40 PM   #752
Heath
2014 JK Wrangler
If that is correct then it can all still be phased off the crank. Set the crank to TDC on #1 and "set" or "reset" the box from there. As lng as the box has memory, its all good.
Heath is offline   Reply With Quote Quick reply to this message
Unread 03-08-2011, 10:47 PM   #753
PFCJoker
Crawled and subbed
PFCJoker is offline   Reply With Quote Quick reply to this message
Unread 03-09-2011, 11:36 AM   #754
TJXTWO
I ordered the Shell grease from Sky Geek and received it in three days with normal ground shipping. Great service...
03 TJ Sport, 4.5" RE SuperFlex short arm lift, Tereflfex ST swaybar, 33" MTR's, Body Armor bumpers @ sliders, 5 speed manual... 06 TJ Rubicon, 4.5" RE long arm lift, Currie Antirock front and rear , OR Fab bumpers @ sliders, K@N intake, custom exhaust, 1" BL , 1" motor mount lift, 35" MTR's on Pro Comp Alloys, 6 speed manual.
TJXTWO is offline   Reply With Quote Quick reply to this message
Unread 03-09-2011, 12:27 PM   #755
TotallyScrewed
Let's assume that you could program all of this to "be phased off the crank". Your last line states a problem...How is memory maintained when the battery is removed?
I think that the best solution is a redesign of OPDA to last longer rather than change what does what in the engine...just my two cents.
TotallyScrewed is offline   Reply With Quote Quick reply to this message
Unread 03-09-2011, 01:42 PM   #756
JBD
Adam from Crown is looking for an OPDA to use in his research. Anyone have one?
JBD is offline   Reply With Quote Quick reply to this message
Unread 03-09-2011, 03:05 PM   #757
TotallyScrewed
Originally Posted by JeepScrap View Post
Curious to see what Willy or anyone else thinks about this bronze gear.
This is not an application that I would think a good fit for bronze.
If you think that the steel gear wears too quickly, bronze is multiples less tough. E.g. Bronze hardness (Brinell hardness scale) is about a 100, mild steel about a 300 and hardened steel about 600.Bronze is often used to make sure that other metals are not damaged whatsoever. In this case the cam gear would not be affected at all but the bronze OPDA gear would need to be replaced every 100-1000 miles. Okay, it may not be that ridiculous but I expect it will be bad.
The bronze gear would have to be used in an environment where the stresses were minimal. We believe that we know this is not the case in the current design of the OPDA: where we have mild steel bushings seizing on the hardened steel shaft.
Unread 03-09-2011, 07:55 PM   #758
TJJP77
I agree, however there may be a potential alternative - Comp Cams makes a composite (carbon fiber, I believe) distributor gear for Chevy engines that seems to be popular. They don't make it for our engine, but perhaps Crown could look into that, assuming it would provide adequate life and wear resistance.
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is online now   Reply With Quote Quick reply to this message
Unread 03-09-2011, 08:01 PM   #759
JrJmisn
for what its worth - mine had been ticking for a long time, driving me nuts.
I pulled it, found slight wear on the gear, but definite play in the rotation back and forth and obvious ticking i could feel while running.
I ordered one from the local dealer, it came in two days later. 160 bucks.
After replacing, and correctly positioning, the engine ran perfect and ticking was gone, but check engine was on throwing a cam position code.
Dealer relearned the computer for 20 bucks and its all fixed and running perfect.
(2005 TJ, 103,000 miles at replacement.)
JrJmisn is offline   Reply With Quote Quick reply to this message
Unread 03-09-2011, 08:10 PM   #760
Zetto
Zetto's Avatar
Was this recently? We have not seen a OPDA in stock or sell for $160 in a few months.
Zetto is offline   Reply With Quote Quick reply to this message
Unread 03-10-2011, 06:37 AM   #761
JrJmisn
pretty recent. I did the replacement in maybe September..it actually might have been October. There really wasnt a huge issue. Walked in, told them what part I needed, they ordered it and it came in within a week.
I had the computer relearned during my inspection in January a few months ago. I rode with the check light on for a while.
No hype, no problem in my experience.
Unread 03-10-2011, 09:22 AM   #762
willydigger
willydigger's Avatar
I'm pretty sure the back order started in November. I had no problem and found two fairly easy back in late September early October. There was a back order previously however the price didn't jump like it has this time around.
WHODEY
willydigger is offline   Reply With Quote Quick reply to this message
Unread 03-10-2011, 12:07 PM   #763
ChaseB
Not directly related to the OPDA, but I was thinking about trying one of these filter magnets. There have been other threads on this product. If the OPDA and cam gear are wearing, perhaps this could serve as added protection in trapping some of the metal particles that are too small for the oil filter to catch.
[B]1984 CJ-7[/B] Renegade
[B]2005 TJ X [/B](daily driver)
ChaseB is offline   Reply With Quote Quick reply to this message
Unread 03-10-2011, 12:51 PM   #764
Fusco
interesting, i just placed an order for one.
2006 Jeep TJ Rubicon Impact Orange
Fusco is offline   Reply With Quote Quick reply to this message
Unread 03-10-2011, 01:04 PM   #765
willydigger
I suppose it can't hurt.
WHODEY
