2005-06 Jeep OPDA_CPS_Distributor Failure - Page 45 - JeepForum.com
 10Likes
post #661 of 5527 Old 02-20-2011, 08:38 PM
keithert
keithert's Avatar
Originally Posted by tkki1230 View Post
How did you get the plug orientation perpendicular to the engine? Mine is at a 45 degree angle.
Current: 2016 Ram 1500 Sport - Past: 05 Wrangler LJ, 90 and 92 Trackers and 98 Wrangler SE
keithert is offline
post #662 of 5527 Old 02-20-2011, 09:54 PM
tkki1230
You can have the unit facing pretty much where ever you want, just like a distributor. Right now, it is almost at the maximum limit in the clockwise direction before the plastic cover hits the block.
tkki1230 is offline
post #663 of 5527 Old 02-20-2011, 10:24 PM
Heath
2014 JK Wrangler
What about drilling and tapping a couple of holes opposite of each other on the timing sprocket on the end of the cam, and mounting the reluctor wheel there? Then modifying the timing cover to accept the camshaft position sensor. then you could stick whatever you wanted in the place of the opda just to turn the oil pump. Someone could sell that setup as a kit with a already modified cover, and a drilled and tapped sprocket, and a reluctor machined to fit. Or even machine the timing sprocket with the reluctor wheels pattern on the face. It seems like at this point, that would be just as easy as the major mods everyone is doing to the opda units.
Heath is offline
post #664 of 5527 Old 02-21-2011, 12:26 AM
Zetto
Zetto's Avatar
Installed FogMod 1.0 a few weeks ago and made the switch from Mobil 1 10w30 High Mileage(900 PPM of Phosphorus and 1000 PPM of Zinc) to Mobil 1 5w40 Turbo Diesel Truck(1100 PPM of Phosphorus and 1200 PPM of Zinc) oil today (48,000mi on the rig). Next up is replacing the actual gear and then periodically checking wear.
Is there a source for a good quality gear besides ordering a complete 04 or older unit?
Zetto is offline
post #665 of 5527 Old 02-21-2011, 05:46 AM
uf20wop
the orientation to the engine doesn't matter
all that matters is that the sensor remains at the same location on the target wheel
uf20wop is offline
post #666 of 5527 Old 02-22-2011, 03:32 PM
CRJeepin
I think I read a few pages ago that the Dorman replacement OPDA unit has a low quality gear, and the Crown gear is better (but requires shimming). I didn't see an answer to a question that was asked about what to use for a shim though....
CRJeepin is offline
post #667 of 5527 Old 02-22-2011, 07:52 PM
05LongJeep
I bought the dorman unit. The gear had heavy deep pitting throughout the casting. I chose to send it back & order the crown gear from quadratec for modification. I have not had a crown in my hands yet to see the quality of it.
Stock till its paid off 2008 Jeep Wrangler Unlimited 4dr. JK
Loved & Lost due to Faulty OPDA--2005 Jeep Wrangler Unlimited LJ. Rough Country 2.5" Lift w/Stearing Stab. R/C sway bar discos. 31x10.50, Hella Windshield Lights & A Never Ending List of Dreams
05LongJeep is offline
post #668 of 5527 Old 02-25-2011, 05:22 PM
05LongJeep
The quality of the Crown gear is 50X better than the import gear. Heavy, solid. Only had one hole drilled in it? It doesn't go through the shank.
post #669 of 5527 Old 02-25-2011, 07:19 PM Thread Starter
willydigger
No. You line up the single hole with the hole in the shaft and then drill the remaining hole. It's to insure the hole is straight. I think the crown gear will require you to drill a new hole through the shaft because the hole in the gear is different than the stock gear.
willydigger is offline
post #670 of 5527 Old 02-25-2011, 10:25 PM
05LongJeep
Yea, We have a full machine shop at work. I plan on redrilling in the next few days. Unless I trade the LJ in on a JK 4DR. Its in the works with the Wife.
post #671 of 5527 Old 02-25-2011, 11:31 PM
amcjeepman
amcjeepman's Avatar
Will be checking my '05 this weekend.
James Belcher, Jr
Carolina Trailblazers PR
86 CJ7 401 TF999
81 CJ7 360 T177
05 Rubicon Unlimited
and others ;)
amcjeepman is offline
post #672 of 5527 Old 02-26-2011, 07:17 AM
CRJeepin
I have a Dorman on order, if it's crap I'm gonna do the Crown gear too...having it drilled will mean a trip to the machinist though. Are you guys just measuring the preload / gap between the existing gear and the thrust washer, and having that duplicated when drilling the new hole?
CRJeepin is offline
post #673 of 5527 Old 02-26-2011, 08:34 AM
CRJeepin
Hey man, would you mind posting up the part number for the Crown gear? I thought I saw it somewhere in this thread, but can't find it now!
CRJeepin is offline
post #674 of 5527 Old 02-26-2011, 09:31 AM
sixshooter05
I just ordered mine thru 4WD Hardware, Crown part #83504635. This gear is for older TJ's that is why there is only 1 hole and it's not in the correct position. You will have to modify it to make it work on an 05 & 06.
Sent from my iPod touch using JeepForum
Blue Jeep Club #145
2005 Wrangler X Patriot Blue 4.0L 6 speed
RC 2.5 lift w/ 3/4" front spacers, 2.2 shocks & steering stabilizer. JKS disco's
3.07 gears 31x10.5x15LT Firestone Destination AT
sixshooter05 is offline
post #675 of 5527 Old 02-26-2011, 06:09 PM
mcicero
Junior Member
mcicero's Avatar
2014 JK Wrangler
Originally Posted by willydigger View Post
Quick Update:
When I removed the OPDA shaft using the Mobilith 220 I reinstalled it with Aeroshell 33MS, but I forgot to clean the shaft back to new. I pulled it again today to sand it with some 2000 grit sand paper. The top bushing was covered in MS33. It had squeezed out the top and globbed around the black plastic washer. While the 220 had very minimal contact the 33MS was everywhere. I was very impressed with the coverage.
I polished the shaft clean. I added some oil to the inside of the OPDA to make sure it didn't dry start. Once I get 5000 miles I'll post up the start shaft pics and the used shaft pics for comparison. To keep the thread clean until I get "after" images I'll put the "before" image here.
How did you get that groove machined in the shaft? Is it completely necessary? Plan on picking one of these up and doing your mods when I get home. Thanks for all the great info.
mcicero is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
