2005-06 Jeep OPDA_CPS_Distributor Failure - Page 369 - JeepForum.com
 10Likes
post #5521 of 5527 Old 05-22-2017, 06:45 PM
imustbenuts
Originally Posted by setarubi View Post
Originally Posted by Bigbob View Post
The Delo is good oil. The reason so many run syn high mileage oil is for the added zinc. The 4.0 is one of the only engines running and I think the last engine sold that uses flat tappets. The newer oils are geared towards emissions and being newer engines have roller tappets the need for zinc is not as great. Less friction with rollers. Everything I have seen dictates added zinc in the 4.0 due to the valve train. Check what the zinc in the delo is. IIRC 10K-11K PPM is the recommendation.
SAE Grade 15W-40
Product Number 222220
SDS Number 17108
Density at 15C, kg/L 0.8806
Viscosity, Kinematic
mm/s at 40C 131
mm/s at 100C 15.7
Viscosity, Cold Crank, C/mPa.s -20/6400
Viscosity, MRV, C/mPa.s -25/26,400
Viscosity Index 126
Flash Point, C(F), minimum > 204(> 399)
Pour Point, C(F) -33(-27)
Sulfated Ash, mass % 1.0
Base Number, mgKOH/g,
ASTM D2896 9.3
Phosphorus, mass % 0.12
Sulfur, mass % 0.32
Zinc, mass % 0.13
I think it's 1300 which is fine. My 10-11K above is incorrect. It's 1000-1100 PPM that works well.
I would be very surprised if that oil has the higher ZDDP needed. EPA required oil manufactures to reduce it. Your old mobile one has low ZDDP. I use the valvoline ZR1 conventional racing oil for this purpose because I can't get other oil in California with proper ZDDP levels for our engine. I do believe the oil does impact the OPDA gear and CAM gear. My OPDA spun fine, no laughing monkey, but both gears were shot. Had bad lifter and lobe too. Installed high volume oil pump when CAM and lifter were replaced.
imustbenuts is offline
post #5522 of 5527 Old 05-22-2017, 11:10 PM
LRod
Doesn't the ZDDP clog the Cats???
LRod is offline
post #5523 of 5527 Old 05-22-2017, 11:18 PM
imustbenuts
Yes too much ZDDP can clog the cats. That's why auto makers have pushed for the new regulations. I believe the warranty on cats is lifetime. This engine requires higher ZDDP due to the flat tappets. However too much of a good thing is bad. That's why I choose to use the VR1 oil and not an additive.
post #5524 of 5527 Old 05-22-2017, 11:33 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Nope...
Knuckelhead is offline
post #5525 of 5527 Old 05-23-2017, 04:59 AM
JEK3
JEK3's Avatar
Originally Posted by Knuckelhead View Post
Nope...
8/80
JEK3 is offline
post #5526 of 5527 Old 05-23-2017, 08:17 AM
biffgnar
biffgnar's Avatar
Once upon a time I spent the $$s and bought a case of Brad Penn which has high ZDDP. I honestly thought my jeep ran and sounded worse with it. I really wanted the opposite too so I don't really think confirmation bias in play. Back to whatever 5W-30 is on sale at the parts store when I do a change. And my OPDA was at 155k plus with no symptoms when I finally changed it out for a Crown. Besides the questions regarding the design which apply to all OEM units I think the differences in OPDA performance off the lot all come down to manufacturing tolerances. They just weren't consistently precise enough. Once you get down the road though, things like damage to the cam start coming in to play also.
JStMarie likes this.
biffgnar is online now
post #5527 of 5527 Old 05-23-2017, 08:56 AM
imustbenuts
I'm certainly no expert. Whatever caused my failure at 25k miles sucks arse!
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
