2005-06 Jeep OPDA_CPS_Distributor Failure - Page 332 - JeepForum.com
 7Likes
post #4966 of 5510 Old 08-07-2014, 07:39 PM
Fargo
Originally Posted by KX6D View Post
Your failure would have happened with any of the units. ... You most likely have an alignment problem that has been documented here but is very rare on most Jeeps..
Yes, you are correct. My point was that just because you have an SG Mod unit, you could still have issues. My SGMod was done by someone on this forum who is very knowledgeable and has done many mods. I think he was even the first one to notice the alignment issue. But even he missed the issue when he built this one for me. So no matter what you do, you still need to be aware of potential issues.
6spd manual
LJ Owners Group member #110
Fargo is offline
post #4967 of 5510 Old 08-15-2014, 03:26 PM
DallastheJeeper
HELP!
My 2 year old camshaft synchronizer seized up and spun (clamp was tight ). I bought a new dorman and it wobbled so exchanged the dorman and it to wobbles (the serial numbers are consecutive). Is this common or is something else messed up?
Vid of the wobble:
https://www.youtube.com/watch?v=ob9A...sQdd4XLNN3FzoQ
|^^^^^^^^^^^^^^^\ ||__
|.......PBR BEER TRUCK.... ||""\_____\
|____________________/||__/----|
#5-06 Salvage Rebuild LJ
Metalcloak Bumper, Overline fenders and Corner guards.
3.5" Sus Lift
1'' Body lift and engine lift
#4-98 TJ Sahara RIP :(
#3-42 GPW Project. Currently on hold Sand blasted the body and it was held together by screen and bondo so new Tub needed
#2-88 Comanche Currently getting a frame off rebuild and a 4bt.
#1-1994 Power Wheels Wrangler
DallastheJeeper is offline
post #4968 of 5510 Old 08-15-2014, 03:30 PM
jkp
What is wobbling? With the unit out of the Jeep, is the shaft loose in the bushings?
'92 Islander
'06 Rubicon
jkp is offline
post #4969 of 5510 Old 08-15-2014, 03:40 PM
DallastheJeeper
Pics of the old
3.5" Sus Lift
post #4970 of 5510 Old 08-15-2014, 03:42 PM
DallastheJeeper
With the unit out nothing seems to be loose or wobbly...
Its lifting the housing up as it turns around, as if its side loading the shaft as it spins or the shaft has a bend.
3.5" Sus Lift
post #4971 of 5510 Old 08-15-2014, 03:46 PM
jkp
Missed the link to the video before. I have never seen that.
Did you have the clamp installed and tight?
'92 Islander
'06 Rubicon
jkp is offline
post #4972 of 5510 Old 08-15-2014, 03:55 PM
DallastheJeeper
Yep, dropped both in multiple times and tightened. Just got done testing the old gear on the new unit and still wobbling (was thinking that the dorman gear was off).
Now in dumbfounded, going to clean up the old shaft and put the old one in to see if it wobbles..
3.5" Sus Lift
post #4973 of 5510 Old 08-15-2014, 03:59 PM
jkp
How does the cam gear look?
I'm at a loss on how it can move around that much.
'92 Islander
'06 Rubicon
jkp is offline
post #4974 of 5510 Old 08-15-2014, 04:05 PM
DallastheJeeper
Looking through the hole it looks fine...
3.5" Sus Lift
post #4975 of 5510 Old 08-16-2014, 01:21 PM
PBRJeepgang
Backlash or up/down thrust movement with the sync wheel? It looks like something within the unit is not aligned properly. If it was from the cam gear, I'd imagine with that much movement, it would be easily visible (wear, broken tooth, etc).
It's amazing that this thing has still not gone past a tech service bulletin with Chrysler. Corporate scumbags...
PBRJeepgang is offline
post #4976 of 5510 Old 08-16-2014, 04:25 PM
DallastheJeeper
I have tried 2 new ones and repaired the old one. All 3 wobble badly...
3.5" Sus Lift
post #4977 of 5510 Old 08-16-2014, 08:05 PM
PBRJeepgang
I hate to even make this suggestion but maybe the oil pump? If all 3 are doing it then it might be a bent or loose shaft in the pump. If not then it could very well be the cam/cam gear.
post #4978 of 5510 Old 08-16-2014, 11:29 PM
DallastheJeeper
Did not think about the oil pump. It's only 2 year old mellings high flow. I'll check that before I mess with the cam.
3.5" Sus Lift
post #4979 of 5510 Old 08-16-2014, 11:54 PM
DallastheJeeper
3.5" Sus Lift
post #4980 of 5510 Old 09-15-2014, 01:16 PM
KX6D
Junior Member
KX6D's Avatar
The problem with the High Volume oil pumps is that they put an increased load on the cam gears that drive it. High Pressure and High Volume pumps have their place in race or high performance applications, but are unnecessary for a stock engine 99% of the time. With the problems with the cam gears in these engines, I'd go back to stock the next time you drop the pan.
Dino Darling - KX6D
Member of the Impact Orange Jeep Group
KX6D is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 03:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 09:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 04:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 11:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 08:25 PM
