2005-06 Jeep OPDA_CPS_Distributor Failure - Page 331 - JeepForum.com
 7Likes
post #4951 of 5511 Old 07-03-2014, 06:28 PM
psouza1943
For those interested in the technical details of one aspect of the OPDA sensor failures from DOORMAN and possibly Crown, I have included this set of pictures from the work I have done, so far, on the problem.
Other than outright failure to perform, this picture seems to portray the problem. In short the MOPAR sensor positive going data pulses are approximately 1/2 the width of the output of the defective sensors. A total of six sensors, were tested, and the enclosed pics are representative of the total data.
Phil
psouza1943 is offline
post #4952 of 5511 Old 07-03-2014, 11:32 PM
psouza1943
Derived a .jpeg image for those with no access to adult computers.
Caliper calculations show the Mopar duty cycle approx %36 and the Doorman is %61. We will never know what the exact specification from Chrysler/Fiat is, but can guess that the Doorman figure just exceeds the upper limit and hope the Mopar is near the optimum center. Not a spec derivation, but is a half assed reference for relative comparisons..
Phil
post #4953 of 5511 Old 08-06-2014, 08:12 AM
keithert
keithert's Avatar
So should I keep using my oil cup modded OPDA or switch to the Crown unit? Sounds like I should wait a few months and see if the Crown has further issues.
Current: 2016 Ram 1500 Sport - Past: 05 Wrangler LJ, 90 and 92 Trackers and 98 Wrangler SE
keithert is offline
post #4954 of 5511 Old 08-06-2014, 08:23 AM
Rockchucker22
Maybe you should pull your modded unit and see if there is any play in the bushings, if not keep using it, if so switch to the crown. My stock unit looked almost new when I pulled it, and probably didn't need to switch it to the crown, but better safe than sorry.
Rockchucker22 is offline
post #4955 of 5511 Old 08-06-2014, 08:44 AM
svandell
Phil
Are both waveforms taken from the same OPDA just swapping the sensors?
svandell is offline
post #4956 of 5511 Old 08-06-2014, 12:22 PM
KX6D
KX6D's Avatar
It appears the Dorman units are having issues. I'm not familiar with any "Crown" units.
As for the OPDA bearing issues, the SG Mod is the way to go!
Dino Darling - KX6D
Member of the Impact Orange Jeep Group
KX6D is offline
post #4957 of 5511 Old 08-06-2014, 12:35 PM
JStrider
you must not have read this thread recently....
http://www.jeepforum.com/forum/f9/20...l#post23609113
ON-ON
JStrider is offline
post #4958 of 5511 Old 08-06-2014, 02:16 PM
KX6D
KX6D's Avatar
True! Been too busy bringing the SG Mod to mass production!
Dino Darling - KX6D
KX6D is offline
post #4959 of 5511 Old 08-06-2014, 04:33 PM
cmecha
Still using the SG unit no issues.
"always upgraded, never replaced."
cmecha is offline
post #4960 of 5511 Old 08-06-2014, 09:50 PM
KX6D
KX6D's Avatar
The SG Mod SOLVES the poor lubrication issues with all units (Factory/LDI, Dorman, Crown). You will continue to hear about failures of the all the other units, except for the SG Mod.
Dino Darling - KX6D
KX6D is offline
post #4961 of 5511 Old 08-07-2014, 07:14 AM
biffgnar
biffgnar's Avatar
Doesn't the Crown unit included a different bushing and an oil channel to address the lubrication?
Romney in 2020!
biffgnar is offline
post #4962 of 5511 Old 08-07-2014, 07:20 AM
fordtech
That's the way I understand it. They used a design much like the older OPDA/distributors.
fuel in my veins, mountains on the brain......
Current-06 Unlimited. Past- 98 XJ, 95 YJ, some Fords.
BUFFALO NY JEEPERS-
Just your friendly neighborhood x-ford technician...
fordtech is offline
post #4963 of 5511 Old 08-07-2014, 08:01 AM
KX6D
KX6D's Avatar
Those have been done in the past by members here, long before Crown made theirs. The problem is the oil still doesn't get up to the top bearing. The SG Mod eliminates the need to have ANY oil at the top bearing.
Dino Darling - KX6D
KX6D is offline
post #4964 of 5511 Old 08-07-2014, 09:15 AM
Fargo
Like other units, the SG Mod can fail at the lower bushing though. Its not perfect either. I had to replace my SG Mod unit after about a year because the lower bushing was all hollowed out. It was very dissappointing. I think its luck of the draw if you get one that is milled strait or not.
6spd manual
LJ Owners Group member #110
Fargo is offline
post #4965 of 5511 Old 08-07-2014, 12:30 PM
KX6D
KX6D's Avatar
Your failure would have happened with any of the units. At least the Dorman and Crown units followed the SG Mod's lead and used oilite bushings, which is an improvement to the stock bushing. You most likely have an alignment problem that has been documented here but is very rare on most Jeeps.
The SG Mod addresses the upper bearing primarily. This is the huge problem as all other units still rely on grease or mist. The lower bushing, with the mods to open up the oiling holes, are about the same for all three.
Dino Darling - KX6D
KX6D is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
