2005-06 Jeep OPDA_CPS_Distributor Failure - Page 321 - JeepForum.com
 7Likes
post #4801 of 5510 Old 01-21-2014, 12:54 PM
boilerup1998
Originally Posted by Semper Fi 03
if it is bad, can it be rebuilt?
My advice would be buy the Dorman and be done....unless you're doing this purely for academic reasons??
boilerup1998 is offline
post #4802 of 5510 Old 01-21-2014, 02:53 PM
Semper Fi 03
I have already bought it and have it done. I am thinking of doing the old one just in case this other one quits.
Semper Fi 03 is offline
post #4803 of 5510 Old 01-21-2014, 05:23 PM
mgclark6
I think its been about six months or so since i installed my dorman unit.
Still problem free.
Has anyone had any problems with their dorman?
mgclark6 is offline
post #4804 of 5510 Old 01-22-2014, 12:06 PM
Altonymous
2015 JK Wrangler
I just bought an 06 LJ (build date: 01/06) I think I heard this problem yesterday. I started researching it immediately. Ordered the Dorman unit and should see it in a couple days. I'm afraid to do anything with the jeep until it gets here. I've read most of the guide on the first page of the thread and the last few but not the 100 pages in between. I am curious if I need to do anything other than drop the Dorman in? I've installed a new distributor on my 97 TJ before, and it looks like the same procedure.. TDC/align the holes, keep the pin in, etc…
What I don't know is how to replace the cam shaft gear if it's also worn?
Does the Dorman need to have the stripperguy mod applied or any greasing? If you can point me to the page where the Dorman starts getting talked about I'll do the reading.. It's just a PITA to come into this thread 100 pages late.
Altonymous is offline
post #4805 of 5510 Old 01-22-2014, 12:33 PM
jkp
It installs just like a distributor.
Nothing needs to be done to the Dorman.
Only way to change the cam gear is to put in a new cam.
'92 Islander
'06 Rubicon
jkp is offline
post #4806 of 5510 Old 01-22-2014, 12:55 PM
06philaTJ
I'm assuming mine is starting to go too (57k original miles, original OPDA never pulled) as I heard a barely audible "metal on metal" squeaking sound through the grill when I was clearing snow off the grill area for about 2 minutes as the engine was idling/warming up. I've been following the thread in the past so I already have a Dorman unit.
However, I read a set of directions a few pages back and it says I have to unbolt the CPS from the original OPDA housing but can't unplug it? Is this just because people are using their original Mopar CPS vs. the Dorman one or if it gets unplugged will there be an issue? Thanks for any help you can provide.
Here's that part from the first half of the directions I found a few pages back that I wasn't sure on:
Removal:
-Put it in neutral and block tires
-remove opda dust cover/cap
-turn main shaft clockwise (3/4" socket) until holes in opda line up (that is TDC)
-remove cps from side (dont unplug it)
-remove opda retainer clip screw
-lift opda out, inspect for wear / replacement etc.
06philaTJ is offline
post #4807 of 5510 Old 01-22-2014, 01:09 PM
jkp
Yes, that is if you want to use the original Mopar cam sensor with your new Dorman.
Otherwise, unplug the harness on the old one and then plug the Dorman in.
I would then save the sensor out of your old one in case the Dorman sensor fails.
'92 Islander
'06 Rubicon
jkp is offline
post #4808 of 5510 Old 01-22-2014, 01:15 PM
06philaTJ
Ah cool I thought that was the case too based on the videos I saw, thanks again for your help.
post #4809 of 5510 Old 01-22-2014, 05:46 PM
CoRubicon
Parts for sale
I sold my Jeep before I had a chance to upgrade my junk.
New, unused, Stripper Guy mod for sale.
How about $60 shipped to the lower 48?
I also have a used OPDA, removed at 56,000 miles, I assume it the original one from the factory.
The gear is in pretty good shape and it spins free. I pulled it and lubed it up when I got the Jeep then replaced it with a new fog mod unit later on. How about $30 shipped to the lower 48?
CoRubicon is offline
post #4810 of 5510 Old 01-23-2014, 09:20 AM
Semper Fi 03
I just went to the auto parts store. When I told my friend I wanted to buy some AeroShell 33MS grease, he looked at me like I was nuts. He said that stuff is very expensive at not really needed for what I was going to do with it. He then asked why I couldn't use some axle/wheel grease for it? He says that the only reason he could see to use the AeroShell grease is that it has a high temp break down and, the axle grease should be good enough because it is good up to 400 degrees. I bought the axle grease, because of what he said, and he didn't have anything better. Is it going to be ok for our FOG MODD?
post #4811 of 5510 Old 01-23-2014, 09:39 AM
Altonymous
2015 JK Wrangler
Why do the fog mod? Why not just get a dorman. Only $85 bux
post #4812 of 5510 Old 01-23-2014, 09:40 AM
06tjrubi
Opda
PM sent earlier on the OPDA
06tjrubi is offline
post #4813 of 5510 Old 01-23-2014, 10:41 AM
CoRubicon
It's yours. Anybody want the Stripper Guy kit? Offers?
post #4814 of 5510 Old 01-23-2014, 10:49 AM
Semper Fi 03
I have it and I am going to do that MODD unless someone can tell me why I shouldn't do it. Or, how I would be able to tell if I should, or shouldn't need it. I have bought a grease fitting and grease already, just have to go get the grub screw yet.
post #4815 of 5510 Old 01-23-2014, 12:58 PM
06philaTJ
I'd go with the Oil Cup mod vs. the original grease fitting mod if your looking to experiment with the Mopar OPDA. I looked into the original grease fitting mod years ago and you basically have to guess how much grease you need to inject and check the OPDA fairly often. If you overfill it, it could cause binding of the shaft as well and grease has to be added every now and then. I also considered that some types of grease in low temps could possibly cause binding of the shaft with a cold engine since they could be less viscous than regular engine oil. The oil cup mod at least lets you monitor and add to the oil level and you can use regular old 10w30 engine oil, which is dirt cheap generally.
Those were basically the reasons why I declined that and several other modifcations listed here that looked good but seemed like only "band-aid" fixes to the problem in my opinion. Lucky for me, I didn't have a problem with my original, un-pulled/un-modified OPDA until this week and have a Dorman on standby to replace it. Good luck though if you try either modification as it would be interesting to see the results vs. the Dorman OPDA as I'm not 100% sold on a permanent solution to this problem yet.
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
