2005-06 Jeep OPDA_CPS_Distributor Failure - Page 320 - JeepForum.com
 7Likes
post #4786 of 5511 Old 01-16-2014, 03:33 PM
meatlord
Maximum Disaster
meatlord's Avatar
Originally Posted by Semper Fi 03 View Post
OK, I have got the Jeep running. Let me tell you what has happen and, ask questions that maybe you guys can answer.
1. The Jeep is making the Laughing Monkey sounds.
2. Driving down the road at about 50 to 55 mph and the Jeep shuts down after a little spitting and sputtering.
3. I order and replace, the OPDA exactly the way it is said to do in the thread and on the videos.
4. Jeep will not start after the OPDA is replaced. The only way I could get it to run, at this point, is to spray starting fluid in the throttle body. It started and ran very very fast and then, bang, Backfired out of the throttle body. At this point, we all thought it was out of time but, I replaced the OPDA the way I was told to. Even after I wrenched the engine to aline the holes in the OPDA before removal.
5. I take the Jeep to a mechanic and, after he gets it to run, he calls me to tell me the Jeep is running. I asked what he did to it. He says it was out of time.
How did my Jeep get out of time if all I was doing was driving down the road at 50 or 55 mph? I pulled the OPDA out and replaced it with a new one in the exact same position. What happen???
Is it possible you are 180* out with your OPDA? I thought I had mine dead on, went to local shop to check it and they did a "resync" for $15. Mine was 180 out.
05 Rubicon "Big Stupid" / 99 XJ on 31s "Nurple" SOLD. / 07 WK Limited CRD GDE Hot Tuned DPF delete. / 00 TJ "One Shot Wonder"/ 12 Altima 3.5 SR CVT / 00 Suzuki DR650.
meatlord is offline
post #4787 of 5511 Old 01-16-2014, 03:36 PM
jkp
It will run without the cam position sensor. The cam sensor is used to fire the injectors sequentially. If the signal is lost, it goes into limp mode, batch fires the injectors, and limits RPM to 2500. Happened to me over Thanksgiving. I think I am the only one whose cam position sensor failed before the OPDA shaft and gear. My gear looked OK with 115K on it.
'92 Islander
'06 Rubicon
jkp is offline
post #4788 of 5511 Old 01-16-2014, 07:08 PM
Semper Fi 03
I don't know if I had it at TDC but, I rotated the engine, with a wrench, until the holes in the OPDA were aligned and the removed it and replaced it with the new one. Here are some pics of the gears on the one I removed. Taken with my cell phone so I am sorry about the quality of them. The last 2 pics, the OPDA has a mark on it. Is this proof that it may have moved and I just replaced a new one right where it has moved to?
Semper Fi 03 is offline
post #4789 of 5511 Old 01-16-2014, 07:26 PM
Semper Fi 03
I am thinking about taking it apart and doing the grease fitting and use it again. Do you think it is worth it?
post #4790 of 5511 Old 01-16-2014, 07:50 PM
jkp
Depends on the condition of the shaft and bushing. And you have some wear on the gear.
I can't tell from the pics, but did the clamp slip and push up metal on yours? Mine does not have any marks on it like that.
'92 Islander
'06 Rubicon
jkp is offline
post #4791 of 5511 Old 01-16-2014, 08:12 PM
Semper Fi 03
yes, I think the clamp let it slide and that is what that little "clump" of metal is from. I think it let it slide and knocked it out of time. I can try to take better pics of it tomorrow if you guys want me to.
post #4792 of 5511 Old 01-17-2014, 03:58 PM
Semper Fi 03
here are some better pics of the gears, they don't look bad, and how far this thing shifted on me to knock it out of time.
post #4793 of 5511 Old 01-18-2014, 12:15 AM
gebirgziege
I just had this problem happen to me but, I have not read where anyone has said that there Jeep quit running one them.
I had the Laughing Monkey sound for a couple of days, maybe a week. That lasted for about 10 minutes until the Jeep was nice and warm.
I drove it to my friend to ask him what was wrong. He was not sure but, we knew where the sound was coming from. On the drive home from his place, less then 10 miles, the Jeep shut down. I have tried to start the Jeep several times and it won't start. It sounds like it wants to but won't.
After reading all of the posts about the noise I heard, I ordered a new OPDA. I got lucky and found one on E-bay for $100, and I just got it today.
I have read and understand the removal of the old one. I even understand the marking of the old one to be removed. What I am not sure of, is how does the new one go in? If the "holes" are lined up, with the factory plastic plug, do I put the new one in. Or do I have to try and make them look the same before I put the new one in?
I have just bought this 2006 Wrangler Rubicon LJ with 29,000 miles on it in October. It only had 26,000 miles on it when I bought it. Now it is sitting in my driveway not running. This is my 10th Jeep and it is making me very upset! I only but around 3000 miles on it before this happen. Can anyone please help me!?!?
Mine hade 34 k miles with the issue and squeak.
44 Ford gpw rblt all original. 06 LJ Rubicon black on black - project.
gebirgziege is offline
post #4794 of 5511 Old 01-19-2014, 08:45 AM
boilerup1998
Just replaced the factory OPDA with the Dorman. Thanks to all the good instructions on the forum, it took about an hour. Would have been 30 minutes if the stupid clip retainer bolt wasn't such a PITA to get to for removal of the old unit!
boilerup1998 is offline
post #4795 of 5511 Old 01-19-2014, 09:23 AM
Bigbob
Bigbob's Avatar
On that bolt there are 2 hints that help a lot in the removal/access to it. First, if you have a stock factory airbox remove it. It has like 3 screws and a couple hose clamps. Makes a lot more working room.
Second, once you get the 2 holes lined up and everything looks kosher to remove the unit take the pin or screwdriver out and loosen the bolt. Now you can turn the housing clockwise and gain a lot more access to the bolt to remove it. Ditto with install. Set the unit in so the holes are lined up and then remove the pin and turn it clockwise. Just do the finally tightening once you get it lined up again.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #4796 of 5511 Old 01-19-2014, 06:47 PM
Semper Fi 03
I talked with my friend today about placing a zerk fitting on the OPDA so I can grease it, he is a mechanist. He asked me if I wanted to have the groove cut in the shaft also and, what that groove was supposed to do. I told him about the seals and the fact that oil/grease is not getting where it needs to. I also sent him the web-site so he can read up on it.
Does the groove need to be put in the shaft and, doesn't that allow the grease to flow on the shaft?
Is my old one, the one in the pics, ok to be disassembled, cleaned, repaired and replaced?
post #4797 of 5511 Old 01-19-2014, 07:05 PM
jkp
You won't know till you take it apart. But the shaft is probably scored and the bushing damaged if it was tight enough to spin the housing.
Knock the pin out of the gear and it will come apart.
'92 Islander
'06 Rubicon
jkp is offline
post #4798 of 5511 Old 01-19-2014, 07:07 PM
Semper Fi 03
if it is bad, can it be rebuilt?
post #4799 of 5511 Old 01-19-2014, 09:41 PM
Bigbob
Bigbob's Avatar
A good machinist will first of all laugh at the steel bushings and then after measuring everything come up with the top bushing and shaft are too wore to be used. But amaze him at the poor design of this thing.
6 Speed, Hardtop
Bigbob is offline
post #4800 of 5511 Old 01-20-2014, 07:43 AM
jkp
X2.
The distributor on my YJ had over 200K on it when I replaced it because it was cheaper to buy the whole distributor than just the cam sensor in it. It was fine mechanically.
'92 Islander
'06 Rubicon
jkp is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
