2005-06 Jeep OPDA_CPS_Distributor Failure - Page 315 - JeepForum.com
 10Likes
post #4711 of 5527 Old 01-07-2014, 07:01 PM
boilerup1998
My 2005 Rubi LJ has been making a "squealing" noise, but not the typical "laughing monkeys". Supposedly, it falls outside the effected build dates according to my stealership. I've tried to link a video. Hopefully, the link works. Should I be worried?
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid1202.photobucket.c om%2Falbums%2Fbb368%2Fboilerup1998%2FOPDAsound.mp4 ">
boilerup1998 is offline
post #4712 of 5527 Old 01-07-2014, 07:01 PM
boilerup1998
post #4713 of 5527 Old 01-07-2014, 07:55 PM
Bigbob
Bigbob's Avatar
Link did not work. All 2005-2006 4.0 engines have this problem. The "effected" build dates were for a TSB related to a out of round pinion gear or something. Your factory OPDA is still junk regardless of build day.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is online now
post #4714 of 5527 Old 01-07-2014, 10:00 PM
gebirgziege
I got my new opda.
I saw a link for the Chrysler one for like 120 or something.
But went with the dorman for 175 shipped.
Looked good.
Here's the pics.
The one with the blue punch in it to line it up is the doorman.
Upon removing the stock one, I tried turning it and it was almost impossible. I took it apart and cleaned the cry out of the space between the shaft and bushing. Put it back together with some oil lubed an it spun nice and free but seemed a tad rough. Maybe I will polish it up and try a mod on it and get a new gear from crown for an extra in case the doorman takes a poo.
The camshaft was in surprisingly good shape considering the wear on the opda shaft gears.
But it's only got 33k on it now, and after i heard it, I wasn't cruising around with the monkey in the engine compartment either.
All said and done, the install is easy.
Neutral, remove opda cap, turn main shaft clockwise until holes line up (TDC), remove cps, remove retainer clip screw (a pain to put in), line up oil pump key hole with a screw driver, and re install new opda with new gasket in same order do not turn the engine it was in TDC position to begin with. As long as the new opda holes are pinned and it fits in the oil pump key hole- you're golden.
I used my old cps sensor. No need to replace the old working one with the new spare.
Anyways, I'm a little baffled with why they didn't design this thing to be grease-able. :/
wtf Chrysler/Mopar?
Whatever. I'm kinda happy $175 later.
We will see how long the doorman lasts (Made in Taiwan)... To be continued. I'll post pics of the wear later as we go.
44 Ford gpw rblt all original. 06 LJ Rubicon black on black - project.
gebirgziege is offline
post #4715 of 5527 Old 01-08-2014, 07:54 AM
magnum629c
Can u do the fogmod to the new dorman one?
magnum629c is offline
post #4716 of 5527 Old 01-08-2014, 08:11 AM
pwmac
Yes, but it should not need any mods except to use the oem sender.
Most oem OPDAs need the various mods because they are made wrong.
The thread is long and you should read it.
pwmac
Durango, CO
06 Rubicon, modified
pwmac is online now
post #4717 of 5527 Old 01-08-2014, 08:51 AM
magnum629c
I just ordered one for 79$ why so cheap? Rockauto dorman opda
post #4718 of 5527 Old 01-08-2014, 09:48 AM
Bigbob
Bigbob's Avatar
No need. If fact the grease will work as a seal and keep oil from working it's way up. Best not to do it.
Good news. I bet they are over loaded with them and the market is limited. Only 2 years of Jeeps used these.
6 Speed, Hardtop
post #4719 of 5527 Old 01-08-2014, 01:05 PM
mgclark6
My dorman cost $285.00 about eight months ago. At that price, i might have to buy a spare.
mgclark6 is offline
post #4720 of 5527 Old 01-08-2014, 01:37 PM
magnum629c
78$ just bought one today
post #4721 of 5527 Old 01-08-2014, 01:54 PM
Bigbob
Bigbob's Avatar
Just ordered one from Rock Auto. Like $84.00 shipped. I will of course disassemble this once I get it and see if it does or does not have a seal between the two bushings like the original does.
6 Speed, Hardtop
post #4722 of 5527 Old 01-08-2014, 04:08 PM
boilerup1998
Seems to work on my phone app and laptop?
post #4723 of 5527 Old 01-08-2014, 04:46 PM
auburnhunter
Can't beat that price. I did the SG mod, but at that price I just had to buy a spare.
"The problem with quotes on the internet is that you never know if they are real or not" - Abraham Lincoln
auburnhunter is offline
post #4724 of 5527 Old 01-08-2014, 04:56 PM
Bigbob
Bigbob's Avatar
I did finally get it. Hard to tell what it is via a sound byte. Your best bet is to get the Dorman at that cheap price and install it.
6 Speed, Hardtop
post #4725 of 5527 Old 01-08-2014, 06:50 PM
boilerup1998
Ordered. $78.99 + $8.64 shipping. Not bad considering the alternative to letting the factory junk ruin the engine
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
