4Likes
post #4501 of Old 05-18-2013, 11:59 AM
TroubleNEO
Originally Posted by Ljcrawler05 View Post
I've got 80k on my lj rubicon.. I've noticed a ticking.. sometimes it is very noticeable others not at all it generally is worse right after I crank it and when the engine is still cold. My oil pressure fluctuates between the middle of the gauge to the 3/4 mark depending on my rpm, which just seems odd. Does this sound like the symptoms of the opda? I want to fix it before it leads to other problems
Your ticking could be any number of things as well. Is it an actual tick, or more of a clacking? I have a clacking noise which I suspect is bearing failure from putting the Jeep on its side and not being able to quickly shut off the engine.
Most of the time a ticking that goes away when the engine warms up is exhaust related. A common place to have that happen is the flanges where the mini cats bolt up to the rest of the exhaust. If you can get up in there from the bottom with an impact and some long extensions tighten them up and see if that doesn't help. Also look up the torque specs for the exhaust manifold and torque all the bolts, or at the very least just see if you can tighten them up a little with a wrench or ratchet. Those tend to get loose and cause leaks as well.
Looking for: 03-06 interior plastic trim. PM me.
TroubleNEO is offline
post #4502 of Old 05-18-2013, 04:08 PM
goofus
Originally Posted by TroubleNEO View Post
Even the end that drives the oil pump has a bad notch worn into it from the OPDA binding the oil pump slamming into it when the OPDA slows down.
That wear is EXACTLY what I found on mine and I'm pretty sure the startup tick was right there. I could not pin down the tick to anywhere else. I'm thinking that once the oil pump got warm enough and oil worked up around that spot, the noise faded/stopped. Startup tick disappeared after I replaced the OPDA. There were not other wear/damage symptoms.
When the tick was ticking, I got a stethoscope on the top of the OPDA (the plastic lid) and that was where I heard BANG BANG BANG. Nothing (or very faint sound) on the valve cover, intake, and exhaust manifold.
2013 2500HD
2005 Unlimited
2003 Rubicon
2000 SE
1997 XJ
85 FJ-60
goofus is offline
post #4503 of Old 05-19-2013, 02:19 AM
TroubleNEO
Makes sense. The binding is what causes the scoring and, and one could assume that when the binding occurs that naturally the OPDA would slow down. This would probably allow the quickly spinning oil pump to catch up to it, or at least this is my theory.
Right now I have a pretty bad clacking on startup. It's not even a ticking anymore, it is literally a clacking that almost sounds like bearing failure. Hoping that replacing the OPDA will solve it, because I would be shocked if that were the case and I actually had bearing failure.
post #4504 of Old 05-21-2013, 09:16 AM
TroubleNEO
My new OPDA will be here tomorrow. Anyone know if I can set the timing myself if I have a scan tool? I know there is a special functionality of the DRBIII scantool to do it, but if my scan tool can see the timing can I just put the new OPDA in the same as the old one, and then adjust it until the timing is within spec?
I know a few people said they noticed a large difference when they had the dealership do it.
post #4505 of Old 05-21-2013, 09:30 AM
George2005
Good question! I have a ACTRON Auto Scanner Plus # CP9580. Will this unit do the job? I only used it once to diagnose a ABS issue I had with a Ford pick up.. Box said it displays live engine data!!! Anyone know ?George
2005 Black Rocky Mountain Edition Wrangler 6cyl, 4 speed auto, D44 Rear 3.73's, Tilt, tinted, 7 speaker sound with sub and CD on Ravine Wheels 30X9.50's for now stock..
George2005 is offline
post #4506 of Old 05-21-2013, 11:12 AM
Submariner
When I put mine in.
I turned the main crank by hand/wrench to get the timing mark set TDC, YOu will need to remove the fan belt to get it out of the way so you can see the marks. I just loosened mine up so I could see the marks
I made sure the holes was lined up on the old ODPA. pulled it, dropped the new one, lined up the "holes" using the plastic pin. bolted everything back together,
Never looked back.
I think the Key points here is Make sure you get the fan belt out of the way to make sure you get at TDC marks, hard to see it if you do not get the fan belt out of the way. Set the timing at TDC. Make sure the ODPA "HOLES" are aligned.
This was almost a plug and play operation. Not as easy as changing the battary but close.
Submariner
With 20 years in the US Navy, and nine+ years underwater on Nuc Subs.
And they wonder why I am the way I am!!!!!!
Submariner is offline
post #4507 of Old 05-22-2013, 07:27 AM
TroubleNEO
Originally Posted by Submariner View Post
When I put mine in.
Never looked back.
Gotcha thanks!
post #4508 of Old 05-22-2013, 01:30 PM
TroubleNEO
Here is a question, why do I need to have the engine at TDC or even touch the belt if I just line the holes up on the old OPDA, remove it, line the holes up on the new OPDA and drop it in? That seems like it would take care of the TDC marks being in the same place on it's own.
post #4509 of Old 05-22-2013, 02:02 PM
ngajeeping
That's all we done to mine good so far a week later
ngajeeping is offline
post #4510 of Old 05-22-2013, 04:19 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
That is correct in most cases. Lining up the TDC marks is more for those that get the P0016 code after installation. That means it won’t be on TDC when the holes line up so TDC must be set, then turn the housing to line up the holes. Also if there is a lot of gear wear it is a good idea to check the marks. As the gears wear the wheel will become somewhat retarded so a slight correction might be needed.
Rubi4MyMrs is offline
post #4511 of Old 05-22-2013, 07:06 PM
SolarOne
... if I just line the holes up on the old OPDA, remove it, line the holes up on the new OPDA and drop it in ...
Here is what I did (A-Z with notes..):
Disconnected the wiring harness connector and retaining clip
Remove cap from OE unit
Turn motor until holes line up
Drop in Allen key / hex wrench
Removed the retainer and bolt
Pulled the OE unit out soft and smoothly allowing the unit to spin out off the cam gear
Took mental note of sensor position once released from the cam gear
Checked condition of gears, cam didn't even look wrn (have had a feeling previous owner put in a new cam.)
Grabbed dorman and put in same position while its retention pin was in place
Gently slid new dorman in allowing the unit to spin on the cam gear
Installed retainer and bolt
Pulled retention pin from new unit.
Connected wiring to wiring harness and retainer
Primed oil and fired up
Allowed engine to warm up while I listened for any noises
None were heard, and no codes on the dash
Went for a test drive, noticed an improvement to drivablity I'm still enjoying
In short take everything out in time, and replace with new unit in time and everything will be fine.
.. __________
./____l__[\___\___
[/---\_l___l/--OlllllllO
.(o))--(o))_(o))--(o))
SolarOne is offline
post #4512 of Old 05-23-2013, 09:39 AM
Submariner
I did that first, figured it would be just as good. Went ahead and looked at the TDC, was off by 2 degrees, not much but just enough to cause a problem. turn the crank to tdc, hole was off just a smidgen.
So check your tdc, align the holes and go for it.
Submariner
post #4513 of Old 05-23-2013, 01:01 PM
jeepinhokie
just FYI, my 04 wear patterns didnt look much different than your 05-06's. 130k miles on the OEM one.
jeepinhokie is offline
post #4514 of Old 05-23-2013, 05:22 PM
TroubleNEO
Replaced the OPDA with the Dorman unit today. Probably going to need to have a relearn done with a DRBIII tool, runs like the timing is out some and I haven't been able to get it back in by hand. It runs though, definitely good enough to drive.
The last few times I fired it up though the clacking that I thought was bearing failure was not present. It usually started when you started it cold and then went away when the engine warmed up but now....nothing. Add another item to the list of weird **** a worn OPDA causes I guess. Some people have said theirs was a knocking noise, but this was literally like rod knock or bearing failure. Pretty much just "CLACK CLACK CLACK CLACK" until the engine warmed it. It was getting bad enough that I was considering pulling the engine and having it rebuilt.
I lined the holes up, dropped an allen key in, pulled the OPDA, and dropped the new one in. Pulled the pin on the new one, spun it out of the way, put the hold down and bolt back on loosely, spun the opda back and stuck the pin back in. Then I tightened the hold down and finally yanked the pin. I didn't end up removing the belt to find TDC, which could be why it runs why the timing is slightly out.
post #4515 of Old 05-24-2013, 05:51 AM
keithert
keithert's Avatar
That looks a whole lot better than most of the 05-06 I've seen with half that many miles.
Current: 2005 Wrangler Unlimited - Past: 90 and 92 Trackers and 98 Wrangler SE
keithert is offline
Currently Active Users Viewing This Thread: 7 (5 members and 2 guests)
biffgnar , Dirty Backroads , Jaminjer , jkp , Redfish7
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
You may not post new threads
You may not post replies
