2005-06 Jeep OPDA_CPS_Distributor Failure - Page 281 - JeepForum.com
 7Likes
post #4201 of 5510 Old 01-11-2013, 08:13 PM
jkp
Check the tensioner and idler pulleys, my tensioner pulley sounded just like the OPDA monkey.
'92 Islander
'06 Rubicon
jkp is offline
post #4202 of 5510 Old 01-11-2013, 08:18 PM
ericshere03
Thanks for the tip! I originally found that my tensioner was worn and making a little rattle noise, but wasn't the monkeys... I need to check all the pulleys cold... Only problem is, IT'S COLD! Expecting lows below freezing temps IN SAN DIEGO!!! I know some one from Minnesota is going to tell be about their front door and frozen lakes :-P ...
2006 Jeep Wrangler Unlimited, Silver, 6 Speed, Dorman OPDA, Silverstar Sealed Beams, STOCK Everything Else (This List Will Grow!)
ericshere03 is offline
post #4203 of 5510 Old 01-11-2013, 09:04 PM
ninjaturtle0
Ok guys I ran into a guy at Autozone he is a mechanic at the Jeep dealership here. I asked him about the opda issue on the 05s he said its not a recall but he described to me why it was happening in a lot of technical words I can't repeat but he said not all the TJs built for the 05 06 are bad and said I didn't have to pull it out to check just touch the opda housing while the engine is running and if its vibrating that means your opda is wearing.
ninjaturtle0 is offline
post #4204 of 5510 Old 01-12-2013, 06:13 AM
Dean7276
I would double check that it is not coming from your trans. I had what I thought at first was a loose squealing belt, then thought it was the beginning of "laughing monkey", then possibly a squealing throwout bearing. Turned out to be worn pads on shifter assembly inside the trans (NSG370).
Dean7276 is offline
post #4205 of 5510 Old 01-12-2013, 08:09 AM
LarryJ00
flyingjeff and ericshere03...thanks for the replies. I ordered a replacement and a kit from stripperguy
LarryJ00 is offline
post #4206 of 5510 Old 01-12-2013, 01:02 PM
ericshere03
OK, It is NOT the belt drive or anything its attached to (no belt, still noise). the sound is indeed coming from the tranny, but more the bell housing area ... The jeep warmed up and the noise went away before I can further test... I have done tests here thinking it was this initially but i will retest...
post #4207 of 5510 Old 01-12-2013, 01:02 PM
ericshere03
I dont think it can be the shifter pads because the input shaft (there fore the whole tranny is not moving.
post #4208 of 5510 Old 01-13-2013, 12:19 AM
flash1034
Is there a link somewhere which outlines how to put in a NEW OPDA.
Thanks,
Flash
2006 Jeep Wrangler Rubicon Unlimited
flash1034 is offline
post #4209 of 5510 Old 01-13-2013, 05:40 AM
flyingjeff
Changing out the OPDA
How to "clock". Very important.
This was this initial "how to". I include it so you can see some of the details of removal/installation.
Removing the air cleaner housing makes life a bit easier.
1.Take photos. Install position is not critical. Alignment between OPDA and engine timing IS critical.
2.Remove cap. T20 torx
3.Clock engine/OPDA
4.Insert pin from new unit OR insert something similar like a small screwdriver to keep the alignment.
5.Unplug the wiring connector. Slide red tab. Then press the standard release mechanism.
6.Unbolt retainer with 1/2" wrench. Set bolt and retainer clip aside.
7.Lift OPDA. It WILL rotate counterclockwise as you lift it. Don't fight it. That's the design. It turns less than a 1/4 turn. Note OPDA housing alignment in relation to engine.
8.Find the gasket.
Going to be away for a while? Cover the hole in the engine with a rag.
To reinstall.
1.Make sure pin is in place in the housing. Put the gasket over the hole or find a way to adhere it to the OPDA.
2.Reinstall is just the reverse of the removal. Expect the rotation--clockwise this time. If the unit does not slide/rotate EASILY into position (remember that first photo?) the oil pump slot needs some adjusting. Use a large flat blade screw driver to turn it. Small increments. It may take a couple of tries to get back into alignment. When you do get the oil pump slot in the correct position, the OPDA will almost drop into place. Frequently, no fiddling will be required. But it happens (see video #2.)
3.Double check that the OPDA is fully seated then reinstall that damn retainer. It's a pain but it will go. Tighten the bolt but don't go gorilla on it.
4.Pull the pin.
5.Reinstall the cap.
6.Reconnect the wiring. The plug is tight. Make sure it's connected. Slide the red tab.
Reinstall air cleaner housing, if you removed it.
flyingjeff is offline
post #4210 of 5510 Old 01-13-2013, 09:12 AM
efm-7
I'd like to offer a tip if it helps anyone who isn't very big or strong:
I'm a borderline midget (2" too tall to be one "legally") and found it very difficult to turn the engine with a wrench to line up the hole/tdc. What I ended up doing was the following:
1) got the jeep onto jackstands.
2) put it in 4HI
3) put it in 6th
4) wedged a block of wood under the front driver side wheel.
5) grabbed the front passenger-side wheel and turned clockwise until I could see that the hole matched up.
quick, easy peasy!
efm-7 is offline
post #4211 of 5510 Old 01-13-2013, 10:18 AM
SSAdrenaline
2) put it in 4HI
3) put it in 6th
quick, easy peasy!
Great idea thanks for sharing brother.
Also here is a How to guide for the installation of the SG mod.
http://www.jeepforum.com/forum/f9/op...ation-1461851/
Cheers.
SSAdrenaline is offline
post #4212 of 5510 Old 01-15-2013, 09:56 PM
Fargo
2) put it in 4HI
3) put it in 6th
quick, easy peasy!
Or you could take the cover off the OPDA and follow these simple steps
1) Check if the if the holes line up. If not:
2) Get in Jeep and give the key a quick flick. The OPDA turns at 1/2 engine speed. It won't spin past the hole with small quick flicks of the key.
3) Get out of Jeep and repeat step 1.
Once the holes are lined up, pull the key from the ignition so no one turns it over. Put them in your toolbox or somewhere so you don't either. Then drop a small screwdriver or nail or something in the holes and proceed as indicated in the video. This is what I did. I think my holes were off by about a 1/4 turn when I started and it took about 3 quick flicks of the key to line them up.
6spd manual
LJ Owners Group member #110
Fargo is offline
post #4213 of 5510 Old 01-15-2013, 10:49 PM
ericshere03
Crap, I think my issue was the throw out bearing ... Damnit, that job sucks.
post #4214 of 5510 Old 01-15-2013, 11:43 PM
ericshere03
To you guys with a keen ear, can you try to identify the noise ? Similar to the OPDA ...
http://www.jeepforum.com/forum/f9/ne.../#post14797781
post #4215 of 5510 Old 01-17-2013, 01:15 AM
rubithebeast
could you just use the original hole that the plug is in on the opda housing and put an oil bath in that way. or is something else in the way? i know i would still have to tap it but looks about the same height as the other hole that has been drilled in the modded opda.
rubithebeast is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 03:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 09:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 04:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 11:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 08:25 PM
