2005-06 Jeep OPDA_CPS_Distributor Failure - Page 26 - JeepForum.com
 10Likes
post #376 of 5527 Old 02-03-2011, 07:40 PM
Jeffro06
Jeffro06's Avatar
Originally Posted by willydigger View Post
I doubt it's the oil or the block heater. Mine didn't squeal for 5 years with regular oil and no heater. When you say cam gear you're referring to the oil pump drive gear?
Yep. All I know is it started squealling like a stuck pig when it got cold out. Since then I've did the oil swap, had the drive gear swap done on Chrysler's dime, and started plugging it in on these colder than cold nights.
It could just be dumb luck that it decided not to squeal anymore. I'm not obsessing about it like I did when it first started, but I'm trying to be prepared if it comes back.
Jeffro06 is offline
post #377 of 5527 Old 02-03-2011, 07:48 PM Thread Starter
willydigger
You've read the posts and I'm sure you understand everything. There was nothing done to the upper bushing so the squeal/binding will be back (hopefully, meaning you'll have warning). Get the new OPDA and make sure to do something to lubricate the upper bushing. Maybe the bushing is just going bad and the heater is preventing it from getting cold enough to cause clearance problems.
willydigger is offline
post #378 of 5527 Old 02-03-2011, 07:55 PM
Jeffro06
Jeffro06's Avatar
Yep, read them, understand them, but can't do anyting until I get new OPDA, which doesn't seem to be anytime soon.
Jeffro06 is offline
post #379 of 5527 Old 02-03-2011, 08:17 PM Thread Starter
willydigger
Just think of how exciting it will be when they do show up!
post #380 of 5527 Old 02-03-2011, 08:46 PM
ChaseB
Can't decide if I want to use mine for the Jeep or use it for a nice display piece for the mantel
1984 CJ-7 Renegade
2005 TJ X (daily driver)
ChaseB is offline
post #381 of 5527 Old 02-03-2011, 08:52 PM
NextJeep
Is there any reason not to just mod the unit I have? I have no symptoms, and have ordered the Aeroshell grease.
As soon as the Aeroshell gets here I was planning to mod the unit I have. I keep seeing how many folks are waiting for a new unit to mod... any reason not to mod the working unit in my 05 TJ? BTW, I paid $20 for that Aeroshell grease Willy. Are you sure you and FOG didn't buy a little Shell stock before starting this whole mess?
NextJeep is offline
post #382 of 5527 Old 02-03-2011, 08:55 PM
ChaseB
Pull your unit and check for binding, also taking the unit apart and checking the bushing and shaft for damage and scoring would be a good idea. But you should be fine to do the mod on your existing unit. The gear would also need to be inspected. I got my grease at sky geek for 14, it was over 20
After shipping though
1984 CJ-7 Renegade
ChaseB is offline
post #383 of 5527 Old 02-03-2011, 09:00 PM
lumpster
lumpster's Avatar
Not that im adding anything revolutionary, but i did the fogmod. It wasnt that mine was making noise, but im about 2500 miles away from being out of warranty, so i wanted to check on the drive gear and cam. They are both in great shape (mobil 1 10-30 synthetic its whole life) I did have some slight galling on the upper bushing and shaft. I took it all apart, drilled and tapped it for a grease zerk, polished the shaft with some norton diamond compund to a mirror finish and put it all back in. I dont notice a difference, but i have some piece of mind. Ill be taking it apart this weekend to see how it all held up this week and to clean out the non moly grease so i can pack it full of valvoline palladium NLGI2 http://www.valvoline.com/pdf/Palladium.pdf
Its doesnt have as high a moly content, but ive done alot of looking and it seems that 3% moly is about as much as it takes to get the full benefit of moly. Also its so much cheaper at napa, i think it was 4 bucks for the tube. The jeep grease that was in the OPDA was very pasty, almost like it had paper fibers in it. I highly doubt it was as good a grease as the palladium, let alone aeroshell 33ms.
Ill post pics tomorrow.
Thanks for the great writeup
lumpster is offline
post #384 of 5527 Old 02-03-2011, 09:01 PM
NextJeep
I bought mine the same place, $8.00 to ship one tube of grease. Just trying to give Willydigger a hard time...
I am planning to pull that sucker as soon as the grease comes in and mod it up. I will post pics when I do, and get feedback on wear.
NextJeep is offline
post #385 of 5527 Old 02-03-2011, 09:11 PM
lope
lope's Avatar
I think any grease between the shaft and bushing will be fine, definitely better than no lube which results from the factory design.
lope is offline
post #386 of 5527 Old 02-03-2011, 09:11 PM Thread Starter
willydigger
The Aeroshell was FOG's suggestion.
post #387 of 5527 Old 02-03-2011, 09:17 PM Thread Starter
willydigger
Originally Posted by lope View Post
I think any greashe between the shaft and bushing will be fine, definitely better than no lube which results from the factory design.
Cheap grease will get dry and sticky. It will break down and cause more harm than good. I tried Mobilith 220 and the shaft didn't look so good. The pics are on the results section of the first page. The Aeroshell is thin and stinky. I think we all know how good stinky grease will perform.
post #388 of 5527 Old 02-03-2011, 09:32 PM
solarpower
Originally Posted by TheFog View Post
Here is the poop with timing the OPDA.
However if the OPDA is close but still outside 15 degrees + or - of where it should be the computer will notice it once you get above 2000 RPMs and will throw a check engine light.
Now for the good news, the computer is designed to be able to tolerate, notice and correct for up to 15 degrees +/- of the where the OPDA should be. If your under the 15 degrees the computer will realize it and make a correction much like we see with short and long term fuel trims.
As far as buying a "code scanner" that will give you live data so you can set the OPDA be prepared to open your wallet. To set the OPDA you must have a tool that can actually talk to the computer and request it to perform tests, not just live data. The scan tool/computers that can do this much have a "instruction set" for specific auto maker IE a Toyota set, a Chrsler set, Ford set, ETC.
Scan tools that have this ability like the snap on MODIS are in the thousands of dollars range.
So as long as your not throwing a check engine light your timing is with-in spec and your not going to gain anything by getting your OPDA spot on zero. And when you pay Chrysler to do it they are not zeroing it either, they are just getting it with-in on the DRB-III and locking it down.
FOG
I was under the impression that the smaller (older style units) needed to be within 2 or 3 degrees...I can tell you that my MPG has changed quite a bit on my April built 2004 model (small/older).. and my good friends (2004 october built newer style) equally compared friend threw a code and his was fine next day back to normal MPG. Older computer readings???
Unless there is a substantial failure, I don't think the camshaft gear needs to be changed. The OPDA gear is the wear gear by design so that it wears first (and worse) than the camshaft gear.
Otherwise a modded OPDA should be fine.
I agree...even though you are a Bungals fan living in Ratbird land..Go Steelers
Originally Posted by grnberet2b View Post
As far as the ODPA goes - your '03 will not be affected. The design changed at the end of the 2004 model year, giving 2005 and 2006 TJs the new OPDA with the flaws.
Correct. So make sure people know actual build dates could be from 8-2004 (although should be titled 2005+) to end of production. Front of door jam driver side has build date sticker.
Originally Posted by ChaseB View Post
UPDATE
Well I received a used OPDA today that was found by lope on eBay. Unfortunately it's in pretty bad shape and I don't feel comfortable having it modified.
Yuck. I would not either.
I 100% agree. Don't do anything crazy until you look it over really good. These things are hard to come by and if it's just a matter of cleaning it up, you may want to reconsider "practicing" on it.
agree again..
That's what my original did. I would expect to see some type of sludge or varnish on the shaft like the one Lope had.
If you're not comfortable doing it, don't. Aluminum is not forgiving.
Alum is very forgiving..no memory...replacing alum material by welding does suck though...kind of like some NFL receivers TV shows.
Is there any indication of heat on the upper bushing? What is the dark stuff on the upper bushing? Is it sludge or is the shaft discolored and scored?
That shaft sucks.
The red line makes sense. This is the dead spot in the shaft. The shiny spot below the arrow is the seal so I would expect the arrow to be in contact with the bushing. Normally the bushing and seal are right next to each other. This is generally the most worn spot on the upper bushing from the OPDA's I've seen. I'm surprised it is pitted. Can you look and see if the section in the housing is unusual?
I have looked under a microscope at a better shaft than that..that pitting is most likely the result of enough heat to change the hardness of that particular part of the shaft to point it becomes brittle enough to chip off and flake under friction. Shafts are not made from 1018 CRS for that kind of automotive application generally. 1018 (grade of steel) has a very slight added pitting for those that don't work with steel everyday.
You haven't tried sanding it yet right?
Sanding will only add to pitting and out of concentric the shaft will be in relation to bushing. From what I can tell those bushing are cast into that housing when initially formed so changing actual alignment is impossible. Trying to ream bushings already worn and holding .003 overall makes me giggle.
Ok now to the point of why I have been ragging on willydigger.....
I have a good OPDA to donate to someone that needs. Thanks to the time, effort, and good will of people posted here I'm going to send that unit to a person who needs it. Free of charge.
Catch is that Chase B sends that POS parts OPDA thing ( that are great pictures...my camera sucks but my good opda can be held up next to those pics) to a good home whether it be scrap metal or someone who can test the actual metallurgy of it.
oh and willydigger has to TYPE he will root for Steelers to win Super Bowl this Sunday in this thread...even if it's a lie.
This OPDA has 80,000 miles on it. The gear is worn like a normal 80,000 gear would wear if it was going to last over 200,000 miles. The shaft has very small rings near the top end of bushing and not enough wear to need any polishing.
I was given this OPDA with the hopes of doing some research on it, but my personal time has become more more scarce with the resources needed to pursue a total solution...especially considering that people are driving around that need one...and good people like willydigger, the fog, have spent many hours working on it...... and a great guy from WA state (home of Seattle Seahawks) sent me this OPDA.
This unit will need zerk installed..I could do it if needed but I was going to send unchanged for picture reasons...and again time to do mod at work is rare for near future. If by following fog's good instructions and using good tools no reason a competent person can't install a zerk.
04 TJ "U" package
06 XK Commaddy 4.7
solarpower is offline
post #389 of 5527 Old 02-03-2011, 09:43 PM
Zetto
Zetto's Avatar
I still need to write up and post all the pictures from my FogMod last weekend.
Now that the mod is done I have a 14oz tube of Shell AeroShell 33ms I will never use in a lifetime. I will gladly let ANYONE in the Los Angeles area who is doing the FogMod take some grease so they do not have to also order a lifetime supply.
Zetto is offline
post #390 of 5527 Old 02-03-2011, 09:50 PM
TheFog
The AeroShell far exceeds any grease you can buy off the shelf in auto parts store and is well worth the money. The shipping is a touch high but it give you incentive to buy a couple of tubes at a time. If you have a Warn winch its the spec grease for the planetary gears.
On a side note I was going to pull my OPDA and inspect it but before I did I was curious if greasing it with the motor running makes any difference. So I greased it with the engine idling and pull it out. What I noticed is that the grease is much more uniformly disspersed all up and down the upper bushing as opposed most of it at the bottom half that we see when lubing it with the engine off.
The slow pumping with the OPDA shaft spinning at idle speed allows the grease to creep up the shaft as opposed to taking the path of lease resistance and going out the seal and entering the chamber between the top and bottom bushings.
Which brings me to another discovery/point. If you go nuts with greasing the OPDA with the engine off the grease will flow down past the seal and enter the 3 tubes that oil normally come up. With just 2-3 pumps this won't be a issue but I was curious if I just kept on pumping grease would it fill up the upper bushing and come out the OPDA tone wheel.
So the only way to really get the upper bushing really good and evenly coated is to slowly inject the grease while the engine is running.
NextJeep.. Don't have any stock in Shell, the only stock I own is Sirius sat radio (got it when the market tanked for $.05 a share and now its $1.80) so all you Sirius subscribers literally bough me a new house and paid off my Jeep
In memory of Samantha Sue 1998 to Dec-16-10 at 2:15PM. She may have had 4 legs and a tail but she was the best friend I ever had and helped me through some really tough times. I hope to see her again one day.
TheFog is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
