2005-06 Jeep OPDA_CPS_Distributor Failure - Page 251 - JeepForum.com
 7Likes
post #3751 of 5510 Old 10-05-2012, 08:54 PM
4x4Brit
Originally Posted by MJ12
Any interest in a video install of the stripper mod?
Would love to see one!
Build Thread:
Website:
Facebook Page: https://www.facebook.com/Warmachines702
4x4Brit is offline
post #3752 of 5510 Old 10-05-2012, 09:52 PM
ops5
ops5's Avatar
Same here
ops5 is offline
post #3753 of 5510 Old 10-06-2012, 06:54 AM
Kalten
Just joined so I could PM SG. While I have not heard the typical sound associated with the OPDA problem, Mine is making a bit of a racket, more like a knock. I have a bone stock '06 TJ with just over 50k. Using a poor mans stethoscope I was able to pinpoint the noise to the OPDA. I have not pulled it out to inspect it yet. Is it better to just rebuild a new OPDA with the SG kit or to retrofit the original unit. Reason I ask is concern about the gear wear. Should I pull the existing one now and check on the cam wear before I order a new one? Should I just plan on having a new cam installed as well as a new/modded OPDA.
Kalten is offline
post #3754 of 5510 Old 10-06-2012, 02:50 PM
flying_bosun
Start with pulling it and inspecting both OPDA and cam gears. Post pics, especially of the cam gear.
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #3755 of 5510 Old 10-06-2012, 04:55 PM
Dan the man
After installing a new opda a few months ago I have a sound @ around 10 to 25 mph when accelerating or decelerating. Goes away above and below those speeds.
Could it be bad again ? or something else going on ? Thoughts .
Dan the man is offline
post #3756 of 5510 Old 10-06-2012, 07:59 PM
Ken12
I wouldn't replace parts before confirming they are bad. My recommendation is to pull the OPDA and check the gear. If it's good, the cam should be good, also. If it's worn, check the cam, too. My stock 05 just turned 30K. I pulled the OPDA after reading this thread and found extreme wear. I then checked the cam and saw matching wear. I'm replacing the cam and putting in an SG modified OPDA.
Ken12 is offline
post #3757 of 5510 Old 10-06-2012, 10:56 PM
njseifrick
That would sure be helpful!
njseifrick is offline
post #3758 of 5510 Old 10-07-2012, 07:48 AM
MJ12
Going to pull the OPDA out this afternoon, if cam gear and OPDA gear look ok I will go ahead and make the video tonight/tomorrow if not there may be some delay as I will end up replacing my cam.
Currently looking for:
-Leaf Springs that you want to get rid of.
MJ12 is offline
post #3759 of 5510 Old 10-07-2012, 09:11 AM
xjandyj
rev-f
trying to wrap my head around all this info...i searched and didnt find this..my 06 lj was made during the last wek of production in 6/06..the odpa is marked rev-f....thought the last design was rev-e..
thoughts
xjandyj is offline
post #3760 of 5510 Old 10-07-2012, 12:52 PM
ops5
ops5's Avatar
thoughts
Are you sure the lettering isnt just worn off so it looks like an F?
ops5 is offline
post #3761 of 5510 Old 10-07-2012, 01:43 PM
xjandyj
dang it...i licked my finger and sure enuff,,,a faint lower line...rev-e
i ordered stripperguys kit without even pulling it...
where is the cheapest place to get a new odpa......i want to convert the new and swap...
also if the drive gear is worn..replace with another 05/06 gear, or do the 04 and earlier and drill it?
xjandyj is offline
post #3762 of 5510 Old 10-07-2012, 06:47 PM
Ken12
As I understand it, the problem isn't with the gear itself, it's caused by the bushings in the 05/06 OPDA's not getting enough lubrication. That causes the shaft to bind, which causes excessive wear on the gear. When you mentioned "04 and earlier", did you mean just the gear? I think the gear is the same. The 05/06 OPDA's themselves are different and not interchangeable the 04's and earlier.
Ken12 is offline
post #3763 of 5510 Old 10-07-2012, 07:45 PM
TJJP77
TJJP77's Avatar
That's one interpretation. My OPDA had gear wear but no binding at 9,300 when I bought the Jeep. My contention is that many of these OPDAs had improperly alloyed/hardened gears. The poor bushing design is just icing on the cake.
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline
post #3764 of 5510 Old 10-08-2012, 11:13 AM
xjandyj
Ok. So where is the best/cheapest place to get another one? Didn't see it in the top sticky section
xjandyj is offline
post #3765 of 5510 Old 10-08-2012, 11:28 AM
ops5
ops5's Avatar
I think there is a section titled "acquisition" on page one of this thread with a link
ops5 is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
