2005-06 Jeep OPDA_CPS_Distributor Failure - Page 232 - JeepForum.com
 10Likes
post #3466 of 5534 Old 07-16-2012, 10:14 PM
Bigbob
Bigbob's Avatar
Got my parts from stripper guy today. Looks very very promising. He gets the raisen pie I think.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #3467 of 5534 Old 07-17-2012, 08:49 PM
czechsky
Good luck with that BigBob. Still following this thread and running my WillyDigger mod/oil cup at the present time and it is serving me well but, like many, I am hoping this is the final fix.
czechsky is offline
post #3468 of 5534 Old 07-17-2012, 10:06 PM
Bigbob
Bigbob's Avatar
I think it is! I am installing it tomorrow in my oldest OPDA and will run it as is for a while to see how it holds up. I know after I pull it after a couple thousand it will show no wear at all, but I will be looking at the shaft sleeve ETC for any movement or excess play in the shaft/sleeve fit. I will also be looking for any oil seepage where the bearing holder fits against the OPDA housing. (The upper seal is eliminated with this so oil will work it's way up.) If it does seep oil there a dab of silicon should fix things. Eventually I'll try my flow through oil design with it. I still like the idea of extra oil to the pinion gear.
This is a very precision engineered set-up. It fits together like a clock. Pretty slick work. Very simple, but impressive.
LOL I did pull my unit apart today. Removed the stock bushings, yes they are steel and yes there is a seal under that upper bushing. Just silly.
6 Speed, Hardtop
Bigbob is offline
post #3469 of 5534 Old 07-18-2012, 05:41 AM
Gary2
I only had my new one installed while Mike did my old one so it was used for about 20 miles total in the 5 days. I swapped them that afternoon and could not tell the differance between the two as far as feeling for play in the shaft or resistance in rotating the shaft. I would not be surprised if it out lasted the Jeep . Its been in over a week now and its quiet as a ever and runs like a clock.
Gary2 is offline
post #3470 of 5534 Old 07-18-2012, 07:49 AM
cmecha
if any one wants to sell me a spare let me know as i want to send one to Mike
"always upgraded, never replaced."
cmecha is offline
post #3471 of 5534 Old 07-18-2012, 02:10 PM
venturalocal69
Does the OPDA failure occure in the 2006 Wrangler as well? I've got about 27,000 miles on mine...should I check it out???
venturalocal69 is offline
post #3472 of 5534 Old 07-18-2012, 02:13 PM
JustinCHorst
can happen in all 2005's and 2006's...check it out
JustinCHorst is offline
post #3473 of 5534 Old 07-18-2012, 02:17 PM
LRod
If you haven't done it, read page one of this post It will explain the OPDA problem and the oil problem, touching on the gear hardness and wear points.
LRod is offline
post #3474 of 5534 Old 07-18-2012, 02:37 PM
venturalocal69
Son of a *****. Thanks guys.
post #3475 of 5534 Old 07-18-2012, 02:39 PM
Laredo-Alex
Did you check the recalls on your wrangler? I´ve got 32`mls and the recall for the OPDA was not done, so i took it to the dealer and they did all the work => for free inclusive another car for the time they need to work on mine
Here you can check the recalls with your VIN:
https://preview.owners.jeep.com/sub/...52F&Source=%2F
Good luck!!
Proud member of the LJ-Family :) => 2005 LJ Rubicon - YES!
Laredo-Alex is offline
post #3476 of 5534 Old 07-18-2012, 02:41 PM
flying_bosun
Good luck!!
The OPDA was never part of any recall (at least in the U.S.A.)
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #3477 of 5534 Old 07-18-2012, 02:44 PM
Laredo-Alex
my Rubicon is from the US and i checked the vin and got the open recall. Have you tried it?
post #3478 of 5534 Old 07-18-2012, 02:51 PM
JustinCHorst
You need to read...they replced your gear or your opda...doesnt really matter because you still have the same potential problem we all have...yours isnt fixed
post #3479 of 5534 Old 07-18-2012, 02:52 PM
Laredo-Alex
Here you can check it aswell
http://www.jeep.com/webselfservice/j...m%28%27R%27%29
i´ve made a screenshot on the recall ... tomorrow at work i´ll do a scan for you!
post #3480 of 5534 Old 07-18-2012, 03:05 PM
flying_bosun
I'll look for your screenshot post, 'cuz again, there was never an OPDA related recall. There was a technical service bulletin that you might be thinking about, but it was related to the drive gear, not the primary problem this thread is dedicated to, which is shaft binding.
Originally Posted by willydigger View Post
Section 2: Problems
A TSB (Technical Service Bulletin) was issued. There is no RECALL.
2005 JEEP WRANGLER Bulletin - Vehicle Safety TSB ID 9419
http://www-odi.nhtsa.dot.gov/tsbs/results.cfm
NHTSA Item Number: 10013784
Service Bulletin #: 05
Replacement #:
Vehicle/Equipment Make: JEEP
Vehicle/Eqipment Model: WRANGLER
Model Year: 2005
Mfg Component Code: 060000 ENGINE AND ENGINE COOLING
Date of Bulletin: 2005-03-01
Date Added: 2005-04-26
Summary: THE OIL PUMP DRIVE GEAR ON ABOUT 16,000 OF THE ABOVE VEHICLE MAY WEAR OUT PREMATURELY AND CAUSE ENGINE FAILURE DUE TO A LOSS OF OIL PRESSURE. *SC
― Ron Paul
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
