2005-06 Jeep OPDA_CPS_Distributor Failure - Page 231 - JeepForum.com
 10Likes
post #3451 of 5527 Old 07-16-2012, 06:06 AM
JeepScrap
Maybe crown should hire stripperguy? Those fools over there have apparently been working on a new unit for a year. Thanks for the dedicated work stripperguy.
"Science will win in a battle with religion because it works." -Stephen Hawking
JeepScrap is offline
post #3452 of 5527 Old 07-16-2012, 06:09 AM
cmecha
yeah someone should. But i think the real issue is that the part is patented so crown can't make improvements with out infringing on patents. Stripper guy is not selling units, only selling services to Mod them.
"always upgraded, never replaced."
cmecha is offline
post #3453 of 5527 Old 07-16-2012, 07:38 AM
BioTex
1979 CJ7
I'm curious if the drive gear is/was used on another model. Would be nice if we could get exact replacements for those. Anybody work at a parts house that could do some research into this?
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #3454 of 5527 Old 07-16-2012, 07:49 AM
cmecha
yup wished we could get a bronze drive gear.
cmecha is offline
post #3455 of 5527 Old 07-16-2012, 08:02 AM
JustinCHorst
my understanding is that you dont want the gear to be harder than the cam gear because then the cam gear will wear faster/fail
JustinCHorst is offline
post #3456 of 5527 Old 07-16-2012, 08:06 AM
Gary2
I thought bronze was softer than the steel the cam gear is made out of ? Learn something new everyday
Gary2 is offline
post #3457 of 5527 Old 07-16-2012, 08:19 AM
cmecha
my assumption was bronze was softer than steel as well. or is it brass?
cmecha is offline
post #3458 of 5527 Old 07-16-2012, 08:24 AM
Gary2
I thought they both were .
Gary2 is offline
post #3459 of 5527 Old 07-16-2012, 08:33 AM
JustinCHorst
Honestly Im not sure...I was actually making a reference about some others that want a harder gear....but in fact I think the brass is softer then the steel
post #3460 of 5527 Old 07-16-2012, 08:39 AM
cmecha
if the ODPA freely spins then there should be very little wear
cmecha is offline
post #3461 of 5527 Old 07-16-2012, 11:50 AM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Crown makes a replacement that is as close to the OEM as you will get. Since the hole in our shafts is drilled off center & not the same amount from one to another you will not be able to find one that doesnít require some work. That is why replacement gears have only one hole in them. You have to fit them to your shaft & drill the other one. The Crown gear is that way & since it is listed as being for the earlier yrs that had distributors, I assume they had irregular offset holes as well. Donít believe me, try taking the gear from a new OPDA & fitting it to your old one & see if the holes line up. I have 2 & you cannot interchange the gears. Then the only other difference with the Crown gear is you have to tap the wheel down a little to get the recommended end play. I also found it to be a little too tight on the shaft & honed it out a bit but overall consider it to be a good option to complete OPDA replacement if only the gear is bad on the original.
Here is a link to the Crown gear hardness test
http://www.jeepforum.com/forum/f9/ch...ml#post9987898
Here is a link to the simple process for endplay adjustment.
http://www.jeepforum.com/forum/f9/20...l#post11897830
The spec (according to the bulletin) is 0.010" to 0.030"...
Here is a link to my earlier post explaining the gear replacement.
http://www.jeepforum.com/forum/f9/20...l#post12053245
There is a bronze gear for these. Hesco makes it (#HES29425 $89 as I recall).
Rubi4MyMrs is offline
post #3462 of 5527 Old 07-16-2012, 12:02 PM Thread Starter
willydigger
Stay away from bronze gears. They are for racing applications where you use them and dispose of them. Bronze is too soft and would be reduced to nothing in short time. If you want to replace the gear, go with Rubi4MyMrs's suggestion and make the Crown gear work. Do not use bronze gears.
willydigger is offline
post #3463 of 5527 Old 07-16-2012, 12:04 PM
BioTex
1979 CJ7
Thanks for all that info. I knew about the crown gear and having to drill the hole, but I admit I didn't know the whole story. Now I do.
Currently:
BioTex is offline
post #3464 of 5527 Old 07-16-2012, 12:07 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
I completely agree with willy about the bronze gear. I was just pointing out that one exists.
post #3465 of 5527 Old 07-16-2012, 12:19 PM
cmecha
did not know that a bronze gear would be eaten up.
cmecha is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
