2005-06 Jeep OPDA_CPS_Distributor Failure - Page 228 - JeepForum.com
 6Likes
post #3406 of 5484 Old 07-04-2012, 10:24 AM
stripperguy
To all:
Here are some photos of the retrofitted OPDA, along with some simple details..
Here are the OEM parts, in all their scored and burnt glory
Here's the pile of parts I made/bought to do the retrofit
Here's the setup for the only required modification: drilling of 3 holes, using the upper bearing housing as a template
Here's a view from the bottom, showing the custom manufactured bronze Oilite bushing pressed in place. It's a light press and could be done with a soft mallet. Also, I am pointing to one of the 3 drilled holes.
Here is the retrofitted OPDA, along with the $400 bore micrometer and custom ground reamer that I needed to do the job correctly.
Here is a top view of the retrofitted OPDA, showing the custom machined upper bearing housing. Not visible are the shaft sleeves and deep groove, sealed ball bearing.
Here is a side view, showing the position of the target wheel. Don't be fooled by the apparent mislocation, that's just an artifact of the camera perspective, the target wheel is in the same position as OEM, since it's location is determined by the thrust bearing and drive gear.
I do not have photos of how incredibly smooth the OPDA shaft rotates, you'll have to take my word for that!!
Also, if you noticed how scored the shaft was at the upper bushing location, that scoring has no effect on this retrofit.
I now need to pull my OPDA and swap around the sensors.
Of course these need beta testing, but I imagine this retrofitted OPDA will never have a bearing or gear wear problem again. NEVER!!
1977 CJ5 almost done!!
2002 TJ gone but not forgotten
2005 TJ also gone
2005 LJ insurance wreck
stripperguy is offline
post #3407 of 5484 Old 07-04-2012, 10:31 AM
Benderff
Benderff's Avatar
Nice work!
Benderff is offline
post #3408 of 5484 Old 07-04-2012, 10:31 AM
Gary2
That makes my day , very nice work !
Gary2 is offline
post #3409 of 5484 Old 07-04-2012, 11:00 AM
Sweeney
Have the beta testers been chosen?
Sweeney is offline
post #3410 of 5484 Old 07-04-2012, 11:35 AM
stripperguy
Some, yes, but not all are spoken for yet...
First set of OPDA's for beta testing will cost only enough to cover my materials, no labor charges. Shipping is OPDA owners' responsibility.
2005 TJ also gone
post #3411 of 5484 Old 07-04-2012, 11:49 AM
Bigbob
Bigbob's Avatar
Well, I'm on this like a fly on stink. If you need a tester I am your guy.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #3412 of 5484 Old 07-04-2012, 12:03 PM
DstroyrOfWrldz
Let me know your material cost and I can test. I've got a new opda on my dining room table ready to go.
Joe
2005 Wrangler Unlimited (Sold)
DstroyrOfWrldz is offline
post #3413 of 5484 Old 07-04-2012, 12:39 PM
meatlord
meatlord's Avatar
I also have a brand new unit I am willing to test. Let me know if you need additional testers.
You sir, are my hero.
05 Rubicon "Big Stupid" / 99 XJ on 31s "Nurple" FOR SALE. / 07 WK Limited CRD GDE Hot Tuned DPF delete. / 00 TJ "One Shot Wonder"/ 03 Nissan SE-R 6 speed V spec. / 00 Suzuki DR650.
meatlord is offline
post #3414 of 5484 Old 07-04-2012, 03:19 PM
LRod
You mean that I can get rid of my pressurized oil supply line and my Half-A$$ed oil drain line soon!!!!
LRod is offline
post #3415 of 5484 Old 07-04-2012, 06:36 PM
BioTex
Stripperguy, Outstanding work! I can't wait for them to become available...
'85 CJ7, BDS 4" lift, 1" Body lift, 33x12.5, Shrockworks Sliders, 304 V8 with RV cam., T-176, D300, Dana 30, AMC 20.
06' TJ Rubicon, 4" R.C. springs, BFG/AT 35s M.C. 6" fenders, rockers and surrounds, Currie front & rear adj. tracbars, tattons DC rear shaft, adj. upper - lower CA's. Bilstein 5100's
Current project. Stroker/FI ?
1990 MJ Comanche 4.0L AX15/np231
BioTex is offline
post #3416 of 5484 Old 07-04-2012, 06:52 PM
-JD-
I have a brand new unit in the shelf that was originally going to be oil-cup modded. I'm willing to be a guinea pig. I can have it UPS to you in a couple of days. Please advise.
2006 Rubicon Unlimited 6-Sp Manual - 285/75/16 Cooper ST MAXX/stock Moab wheels, Savvy Under Armor BL/MML, Savvy Step-Rocker/Sliders, Savvy/Currie Ultimate Steering, Savvy UCAs, Currie LCAs, TBs and BSs, Nth/AEV 3" Springs, Rancho 9000XLs (255s/256s), ARB D44 Diff covers, Savvy/Tom Woods HD Rubicon Rear drive shaft, Genright Safari 31gal Tank Soon: Savvy LED Lights, new engine :-(
-JD- is offline
post #3417 of 5484 Old 07-04-2012, 09:09 PM
tdp3925
I 've been reading this thread for a long time and this news made me register on this forum. It sounds like I might keep my TJ if this mod becomes available. I know this is my first post so I would like to get in line for the mod when ever it might be available. I have a new unit ordered and should have it by the 6th or 7th.
tdp3925 is offline
post #3418 of 5484 Old 07-05-2012, 06:00 AM
JustinCHorst
stunning
JustinCHorst is offline
post #3419 of 5484 Old 07-05-2012, 08:16 AM
firefly21
Thanks for all your hard work. I also have a new one pending oil cup. Will wait for now. very nice work
firefly21 is offline
post #3420 of 5484 Old 07-05-2012, 08:56 AM
domano 68
Wow, amazing thread and tons of information.
"NOTE : This notification applies only to the above vehicles equipped with a 4.0L eligible ("S" in the 8th VIN position) and an engine build code between 902944 (October 20, 2004) and 900325 (February 1, 2005)."
I have the S in the 8th position of my VIN. Where can I find information about this build code?
Just want to determine if my LJ is affected. My VIN is 1J4FA44SX5P349069 TIA!
domano 68 is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 03:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 09:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 04:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 11:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 08:25 PM
