2005-06 Jeep OPDA_CPS_Distributor Failure - Page 222 - JeepForum.com
 7Likes
post #3316 of 5510 Old 06-07-2012, 08:07 AM
55willystruck
Originally Posted by mhopton View Post
Mike, just curious, with all of your down time on this motor, why didn't you pull it and put in a GM V8 long ago? Hell, I'm at 40k on mine and my V8 build plan is coming along nicely, although a year or two away. When my 06 grenades, I want to be ready to go with an L33/LS1/LM7 variant and a 4L65E tranny to install. Geez, I'm so over this 42RLE I'm ready to do the swap even if the engine doesn't grenade!
Believe me, I'd have loved to. I lost my job over 9 months ago now due to health issues and couldn't afford the full v8 swap. I did talk at length with Novak on a few occasions for a 5.3 swap and retaining the rest of my running gear-keeping the 6 speed tranny, rubi case, etc. Just couldn't come up with about $5K to do it yet.
Best of Luck,
Mike
55willystruck is offline
post #3317 of 5510 Old 06-07-2012, 09:44 AM
mhopton
Best of Luck,
Mike
Understood and thanks for the response. I apologize if I didn't seem empathetic. Good luck looki g for employment.
Mike
mhopton is offline
post #3318 of 5510 Old 06-07-2012, 01:09 PM
BeachTJ
OPDA was replaced with a new one from Mopar this morning. Luckily there was no damage to the gear on the OPDA. I did notice it is was very difficult to turn by hand as predicted. The Jeep seems to be running fine however it was at a cost of $325.00 I now wonder if it is better to run a good Synthetic oil such as Mobil One or switch to an oil with ZZDP such as Shell Rotella?
BeachTJ is offline
post #3319 of 5510 Old 06-07-2012, 01:12 PM Thread Starter
willydigger
Changing to a higher ZDDP oil will not prevent future binding.
willydigger is offline
post #3320 of 5510 Old 06-07-2012, 01:12 PM
-sean-
-sean-'s Avatar
1944 CJ2
Seriously, you need to read the thread. Absolutely everything that you have inquired about has been covered and many times over in some cases.
You will find links to any question you may have on the first page.
-sean- is offline
post #3321 of 5510 Old 06-07-2012, 01:19 PM Thread Starter
willydigger
If the Jeep is a daily driver, you'll need to mod it as described on Page 1 (and the many versions), or dissect every so often and manually grease/oil it. The binding/Laughing Monkey is a result of lack of lubrication and galling. The wear is unidentified and may be helped with higher ZDDP and/or less restrictions on the OPDA shaft.
post #3322 of 5510 Old 06-07-2012, 01:37 PM
BeachTJ
I am aware of the OPDA shaft needing lubrication. I am trying to choose the right oil to prevent camshaft/lifter failure
BeachTJ is offline
post #3323 of 5510 Old 06-07-2012, 02:05 PM
BioTex
I orderd my new OPDA direct from the warehose in Tampa, Fl. $90~ I installed it myself. Took all of 10 minutes. Sorry you had to spend so much. Ouch...
'85 CJ7, BDS 4" lift, 1" Body lift, 33x12.5, Shrockworks Sliders, 304 V8 with RV cam., T-176, D300, Dana 30, AMC 20.
06' TJ Rubicon, 4" R.C. springs, BFG/AT 35s M.C. 6" fenders, rockers and surrounds, Currie front & rear adj. tracbars, tattons DC rear shaft, adj. upper - lower CA's. Bilstein 5100's
Current project. Stroker/FI ?
1990 MJ Comanche 4.0L AX15/np231
BioTex is offline
post #3324 of 5510 Old 06-07-2012, 02:11 PM
mhopton
So with a low-mile 06 LJ, I've stayed on top of checking the opda and have not had much concerns yet with 39k. I have used std Royal Purple 10w-30 with good results, but it is a rated oil, APN SN designation. In researching oils on their site, I came across a new blend RP offers called High Performance Street, HPS, which is not APN rated and has, I believe, 1400 ppm of zinc/phosphorous added. I had to call RP to get the details, and was told it is made specifically for either highly modded or flat tappet engines. Anyone used, or had success with the RP HPS?
mhopton is offline
post #3325 of 5510 Old 06-07-2012, 03:06 PM
BeachTJ
I am traveling so I had to rely on the Local repair shop to replace OPDA. Had I been home I would have did the Mod and completed the task my self. We used to own a fleet of Semi trucks mostly with Cat and Cummins engines. We used Pennzoil Long Life 15-40 witch I believe is no longer available and Shell Rotella. Oil and filters were changed every 8K-10K miles. Most of our engines would go 500-600K miles plus before overhaul and when tore them down there would be very little ware witch I attribute to the use of these oils.
BeachTJ is offline
post #3326 of 5510 Old 06-07-2012, 03:10 PM
flying_bosun
From the detailed discussion earlier in this thread and indy research I believe that Valvoline VR1 10w/30 is a great oil for our engines, while others choose Mobil1 Syn, and still others something else. I also think I recall some discussion about Mobil1 altering their formula post the discussion here. This is one link to see what's what on your own, but I think it's also (fairly) commonly understood that proper ZDDP levels are especially critical during the initial break-in of cams and gears to adequately complete the hardening of bearing surfaces, and not so critical after the break-in is complete.
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #3327 of 5510 Old 06-07-2012, 05:07 PM
pwmac
OILs
flying_bosun,
Well you have done it. Dug up some great data. The link answers many of my questions that I have not had time to dig up answers for.
You did good.
Thanks PaulW
pwmac
Durango, CO
06 Rubicon, modified
pwmac is offline
post #3328 of 5510 Old 06-07-2012, 05:24 PM
flying_bosun
Originally Posted by pwmac View Post
flying_bosun,
You did good.
Thanks PaulW
I send them as emails to myself. Here's a couple more about oil and air filters.
minimopar.knizefamily.net/oilfilters/index
K&N Oil Filter Expensive and Good
K&N Air Filter expensive and Bad
― Ron Paul
post #3329 of 5510 Old 06-08-2012, 04:11 PM
06tjrubi
Opda
got a link or a website--$90 is the lowest I've seen.
Thanks
06tjrubi is offline
post #3330 of 5510 Old 06-08-2012, 04:26 PM
flying_bosun
Thanks
I don't know about $90, but the link in my sig netted be some serious savings on my rebuild. "Jeep club" pricing if you ask for it (speak to Mike V., if there's any confusion)
― Ron Paul
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 03:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 09:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 04:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 11:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 08:25 PM
