2005-06 Jeep OPDA_CPS_Distributor Failure - Page 220 - JeepForum.com
 10Likes
post #3286 of 5527 Old 06-06-2012, 02:33 PM
BeachTJ
I understand that but since it just started i hope that's not the case. Can the OPDA be replaced as a single assembly?
BeachTJ is offline
post #3287 of 5527 Old 06-06-2012, 02:37 PM
flying_bosun
Yes, the OPDA is replaced as a unit and it can be done in about 10 minutes if you know what you're doing, but i takes first timers quite a bit more.
Mine laughed one morning and within 4 or 5 days of fairly short trips it was over. Complete cam failure at 65 mph.
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #3288 of 5527 Old 06-06-2012, 02:39 PM
BeachTJ
I will see if they can replace the entire unit tomorrow. How did you know you had complete cam failure? Loss of oil pressure?
BeachTJ is offline
post #3289 of 5527 Old 06-06-2012, 02:49 PM
pwmac
Lets try to explain one more time.
1)The best way is to remove the OPDA Using the marking pen method (Sharpie).
If the OPDA gear is good
2)then just disassemble the OPDA and examine the shaft and take what action you need to make it perfect.
3)Then use your small flashlight and examine the cam gear.
If the OPDA gear is good then expect the cam gear will be good, just verify it.
If you think the dealer or independent mecanic will do the above then have them do it. Good luck.
When cams fail the engine will run terrible and theortetically you will get a MIL/CEL on your dash. It happens all the time because guys do not check their OPDA/gears as described above.
PaulW
pwmac
Durango, CO
06 Rubicon, modified
pwmac is offline
post #3290 of 5527 Old 06-06-2012, 02:54 PM
BeachTJ
I never knew anything about OPDA until I first herd the noise. This engine only has 30,000 miles and runs perfectly. I called the local repair shop and they will have OPDA assembly tomorrow. Hopefully we can just swap it out. Thanks for all the great info.
BeachTJ is offline
post #3291 of 5527 Old 06-06-2012, 02:56 PM
biffgnar
biffgnar's Avatar
How many actual cam failures have been reported in this thread? Obviously some averted because of the modifications developed in this thread though. Every time I come to this thread I struggle to get a handle on how much of an epidemic this problem is or is not. For people affected by it, that question doesn't matter but intellectually trying to understand it in the bigger picture for DC (although I agree with prior posts that since it isn't necessarily a big safety issue that there's probably not a lot to be gained by them taking any responsibility or action).
biffgnar is offline
post #3292 of 5527 Old 06-06-2012, 03:26 PM
BeachTJ
Because of this issue and others in the past I would be hard pressed to buy a new Chrysler Product. Since my noise just started and it only last 30 seconds or so, Is it really possible there could already be camshaft damage?
BeachTJ is offline
post #3293 of 5527 Old 06-06-2012, 03:49 PM
BioTex
1979 CJ7
When you pull the OPDA, you can visually inspect the gear on the cam with a flashlight. The oil pump drive gear on the end of the OPDA is made of softer metal than the cam gear, so it will wear faster (hopefully).
What is destroying the cam gears is that as the upper portion of the OPDA shaft is not getting lubed, and so the metal to metal thing causes the shaft to get harder and harder to turn until it just welds itself together from friction heat. The cam gear at this point will get stripped.
The laughing monkey is an early warning system chrysler engineers designed into the flawed system so owners would know it's time to empty your pockets one more time.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #3294 of 5527 Old 06-06-2012, 03:58 PM
jeep06
jeep06's Avatar
2015 KL Cherokee
1)The best way is to remove the OPDA Using the marking pen method (Sharpie)PaulW
I have to say that myself, I think the alignment pin method is more accurate over the sharpie. Granted the sharpie may be easier but being my first time swapping out my OPDA, I believe the pin is pretty much fool proof. Either way if any members put it off, you are asking for trouble. Mine never had any signs of laughing monkeys at 64k but the OPDA gear had pretty heavy wear as you can see in my previous post.
2015 Cherokee Limited (granite) 4x4, 2.4L, 8.4AN, luxury group, wireless charge pad.
jeep06 is offline
post #3295 of 5527 Old 06-06-2012, 04:02 PM
BeachTJ
So the actual Laughing Monkey noise I am hearing is from the shaft part of the OPDA running dry? Its not the cam gear making noise, correct?
BeachTJ is offline
post #3296 of 5527 Old 06-06-2012, 04:06 PM
55willystruck
X2, interested to know the bigger picture as well.
Best of Luck,
Mike
55willystruck is offline
post #3297 of 5527 Old 06-06-2012, 04:06 PM
flying_bosun
Correct. Here's a dissection.
Engine simply shut down at 65mph.
― Ron Paul
post #3298 of 5527 Old 06-06-2012, 04:08 PM
BeachTJ
You guys are great, Thanks for all your help
BeachTJ is offline
post #3299 of 5527 Old 06-06-2012, 04:15 PM
flying_bosun
We're not all religious, but many of us will pray for your Jeep anyway. Good luck.
― Ron Paul
post #3300 of 5527 Old 06-06-2012, 04:36 PM
njseifrick
My original opda failed on my 06 LJ two years ago at 16,000 miles. We heard the laughing monkey in Amarillo, TX and south of Vernon, while my wife was driving the vehicle stopped. "oh yes, that red light was blinking for a while, dear". Towed to Vernon, diagnosed as failed opda. They replaced opda, cam, lifters, and oil pump. All under extended warranty with $100 deductible including rental car for a week. No problem since with 34,000 miles on vehicle. I have discussed with service reps at 3 different dealerships and none reported more than 2 o3 occurrences of this defect. I would be interested if anyone has seen a repeat after an initial replacement. If not , this could be a bad lot of original parts, perhaps the shaft was slightly off. In any event I signed up for an extended service contract and other break downs have all ready paid for more than half of the contract. I am hesitant to modify my opda due to the service contract so I also got a spare. It would be undesirable to experience a major breakdown at 12,000 ft on an old mining trail. I have found this vehicle to be quite unreliable, but one of a few equipped for the type of off-roading we do.
njseifrick is offline
2005 jeep tj needs help Smith TJ Wrangler Technical Forum 19 03-08-2013 02:49 PM
Jeep Fire - Catastophic Failure tjone2 JK Wrangler Technical Forum 83 07-11-2012 08:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
Emissions Failure : 89 Jeep HC & CO sports100 YJ Wrangler Technical Forum 12 04-30-2009 10:48 AM
2005 Jeep COLORS????? rem TJ Wrangler Technical Forum 2 08-21-2004 07:25 PM
